POV-Ray : Newsgroups : povray.beta-test : Compiling Unix sources on OS X Tiger (re-post from p.unix) Server Time
16 Jan 2026 01:45:04 EST (-0500)
  Compiling Unix sources on OS X Tiger (re-post from p.unix) (Message 1 to 8 of 8)
Subject: Compiling Unix sources on OS X Tiger (re-post from p.unix)
Date: 18 Mar 2008 01:40:01
Message: <web.47df62da5801fef5b80d39510@news.povray.org>
I'm trying to compile the Unix beta sources under Tiger and I've installed the
boost libraries, the configure is detecting them, but I keep getting a
configuration error "Could not link against boost_thread"
I have to use --with-boost=/users/mac just to get it to recognize that boost is
installed and I've been trying to use --with-boost-thread in just about every
combination.
I tried specifying BOOST_ROOT, but it doesn't work.
my pre-compiled thread libraries seem to be in /users/mac/lib
Being more of a GUI user until OS X came along, I'm not what you would call
conversant with Terminal, so if anyone could help me
with this problem, I'd be grateful.
A.D.B
Subject: Re: Compiling Unix sources on OS X Tiger (re-post from p.unix)
Date: 22 Mar 2008 01:20:01
Message: <web.47e4a48f8cf307a477a62f940@news.povray.org>
> combination.
> A.D.B
Modern versions of boost on OSX seem to want to compile their boost_thread as
boost_thread-mt. Try something like this:
../configure COMPILED_BY="me### [at] myemailcom" --with-boost-thread=boost_thread-mt
Date: 24 Mar 2008 11:25:01
Message: <web.47e7d4df8cf307a4b80d39510@news.povray.org>
> > combination.
> > A.D.B
Tried it.  No joy.
A.D.B
Date: 2 Apr 2008 09:05:12
Message: <47f39298$1@news.povray.org>
> combination.
	According to your config.log you are misusing the --with-boost-thread
configure option.  You specified:
--with-boost-thread=libboost_thread-mt-d-1_34_1
while it should be:
--with-boost-thread=boost_thread-mt-d-1_34_1
i.e. without the "lib" prefix.  Note that 'configure --help' gives the correct
syntax for this option.
	HTH,
	- NC
Date: 2 Apr 2008 21:15:00
Message: <web.47f43d418cf307a4b80d39510@news.povray.org>
I've tried every combination.  I used the libboost name because that's how the
files are named in my directory.  I've tried the configure several different
times, and if you look above, you'll see that I did try it your way.
A.D.B
> > combination.
> while it should be:
>  HTH,
>  - NC
Date: 3 Apr 2008 08:39:44
Message: <47f4de20$1@news.povray.org>
	It might be worth inspecting the respective config.log files then.
Search for the "boost" string (without quotes) and go to the last match
in the file; the answer should be lying around.
	- NC
Date: 6 Mar 2009 14:10:01
Message: <web.49b173978cf307a4924999d30@news.povray.org>
>  - NC
Hi Nicolas,
I had the same problem (Povray 3.7, Boost 1_38) and this is what worked for me:
 --with-boost-thread=boost_thread-gcc43-mt-1_38
Specifically, the configuration script checks for your Boost thread libs via the
lines:
configure:7988: checking for exit in -lboost_thread
configure:8023: g++ -o conftest  -pthread  -I/usr/include/boost-1_38  -L/usr/lib
conftest.cpp -lboost_thread   -pthread  >&5
Wherever your libs are, you should have a file along the lines of:
/usr/lib/libboost_thread-gcc43-mt-1_38.a
(or sounds like in your case
PATH_TO_BOOST_INSTALL/libs/libboost_thread_WHATEVER.a)
or something similar.  Find out what that file is called on your system and
either make a link that is called libboost_thread.a to that file in order to
make POVRAY happy or add a configuration option like the one above.
Best,
Tim
Date: 6 Mar 2009 15:25:00
Message: <web.49b186208cf307a4924999d30@news.povray.org>
Not sure if this helps anyone along these lines, but I had to add the line:
#include <boost/thread/condition.hpp>
in the files
/source/backend/scene/view.h
/source/backend/support/taskqueue.h
/vfe/vfe.h
to overcome the error:
error: 'condition' in namespace 'boost' does not name a type
and
change all instances of
catch(exception& e)
to
catch(std::exception& e)
in /source/backend/support/task.cpp
   /vfe/vfecontrol.cpp
   /vfe/vfesession.cpp
