POV-Ray : Newsgroups : povray.beta-test : Compiling beta 25 on Solaris X64 Server Time
28 Mar 2026 14:43:50 EDT (-0400)
  Compiling beta 25 on Solaris X64 (Message 1 to 10 of 10)
Subject: Compiling beta 25 on Solaris X64
Date: 2 Mar 2008 09:40:00
Message: <web.47cabc1cb1731ef4f0289400@news.povray.org>
After a few years of not povving I started do some work again with it and I am
delighted to see that a multi-threaded version is in beta!!! Great work POV
team!!! Thanks.
I downloaded the source code last week and tried to compile it on a Solaris X64
machine and ran into a few problems:
*) I had to install the boost library from http://www.sunfreeware.com/ and set
the --with-boost-thread=boost_thread-gcc34-mt flag for ./configure.
*) The ./configure script didn't like the version of the libz I had installed.
It complained it couldn't figure out which version it was even though it was a
good one. I suspect that this is an autoconf/Solaris issue though. Not quite
sure what to do about it. Same problem for the libpng, libtiff and libjpeg.
*) ./configure failed the size int test; it turned out I had to set
LD_LIBRARY_PATH manually to the libboost path (/usr/local/lib).
*) My system only had gmake and no make installed and I had to fix the Makefile
manually in a few places to make sure it used gmake instead of make.
*) Due to the a formentioned libz problems I went for the options to compile it
with out libz (and libpng etc.) yet the code still expected it to be there.This
was the failure:
Undefined                       first referenced
 symbol                             in file
uncompress                          ../source/base/libbase.a(povmscpp.o)
ld: fatal: Symbol referencing errors. No output written to povray
I worked around it by compiling the file manually with libz and that worked
fine.
*) It turned out that my system didn't have ar installed, once installed it
worked fine, but I only found out during the compile. ./configure didn't check
for the binutils (not really important, since I suspect it will be installed on
most systems).
In the end this was my ./configure command:
../configure COMPILED_BY="XXXXXX" --with-boost-thread=boost_thread-gcc34-mt
--without-zlib NON_REDISTRIBUTABLE_BUILD=yes --without-libpng --without-libjpeg
--without-libtiff
Once compiled it all worked multi-threaded on my dual CPU machine...
unfortunately not such luck on an 8-way (octacore/octocore???) machine :( a bit
more investigation needed.
Also, gcc generated quite a few warnings (casts if I remember correctly). If
anyone wants more information let me know and I can post it for you.
Thanks again POV team!!!
Subject: Re: Compiling beta 25 on Solaris X64
Date: 2 Mar 2008 09:50:00
Message: <web.47cabe6c6dcb6c85f0289400@news.povray.org>
ooh and just to mention it; I got a 32 bit executable:
$ file povray
povray:         ELF 32-bit LSB executable 80386 Version 1 [CMOV FPU],
dynamically linked, stripped
Would it be worth for ./configure checking 32/64 bit OS and adjusting make files
accordingly?
Date: 2 Mar 2008 10:09:51
Message: <47cac33f$1@news.povray.org>
It should actually use $(MAKE), so that it uses the correct one
automatically.
Date: 2 Mar 2008 11:57:08
Message: <47cadc64@news.povray.org>
	Please mail me the config.log file that configure generated.
	That's odd, there should be *no* explicit reference to make within
any Makefile.  Can you tell where you had to apply those changes?
	Ah-ah, indeed this one needs to be wrapped too.  Thanks!
> most systems).
	Thanks I will be adding an extra check.
	They are harmless.
	Thanks again for reporting,
	- NC
Date: 2 Mar 2008 12:28:10
Message: <47cae3aa@news.povray.org>
  If I'm not completely mistaken, gcc 3.4 has no support for creating
64-bit Sparc executables. I don't know if gcc 4 has.
  If it doesn't, the only way you can create a 64-bit Sparc executable
is by using Sun's own C++ compiler. However, unless they have brought it
up to date recently, it probably won't compile POV-Ray.
Date: 2 Mar 2008 12:29:57
Message: <47cae415@news.povray.org>
  What do you mean with that? It didn't compile? It didn't run? It crashed?
  If what you mean is "even though there are 8 cores POV-Ray is still using
only 2" then the answer is that you have to give "-wt8" as parameter to
POV-Ray.
Date: 3 Mar 2008 07:02:26
Message: <Xns9A567A36D76CAveentukibmcom@203.29.75.35>
Warp <war### [at] tagpovrayorg> wrote in news:47cae3aa@news.povray.org:
This is Solaris X64 and thus uses Intel x86-64 or Opteron chips not Sparc.
Turns out that gcc-3.4.3 was installed on the box and that can produce 64
bit code apparently, but haven't tried that yet.
We have the Sun compiler (for x86) here, but I haven't tried it.,, and not
sure if I will have time to do so.
Date: 3 Mar 2008 07:06:20
Message: <Xns9A567ADFB8BBveentukibmcom@203.29.75.35>
Warp <war### [at] tagpovrayorg> wrote in news:47cae415@news.povray.org:
>> machine :( a bit more investigation needed.
>   crashed?
>   using
> to POV-Ray.
The machine in question doesn't have the Boost libraries installed and just
copying the multi-thread bit and pointing LD_LIBRARY_PATH to it didn't fix
the problem. The program terminated directly failing to locate the library.
So I think I can fix this by installing the library unfortunatly I can't do
that on the 8 way machines :(
Date: 3 Mar 2008 07:12:03
Message: <Xns9A567BD83F13thomasvdv@203.29.75.35>
Nicolas Calimet <pov### [at] freefr> wrote in
news:47cadc64@news.povray.org:
>> installed. It complained it couldn't figure out which version it was
>> even though it was a good one. I suspect that this is an
>> autoconf/Solaris issue though. Not quite sure what to do about it.
DOH User error... Looking at the config.log it turned out the libz etc
test needed the LD_LIBRARY_PATH set as well. All ok now.
>> the Makefile manually in a few places to make sure it used gmake
>> instead of make.
>      within
In the Makefile in the main directory and in the source and unix
directory are these lines:
MAKE=make
SET_MAKE = MAKE=make
I changed them to MAKE=gmake and then it all worked fine.
>> uncompress
>> ../source/base/libbase.a(povmscpp.o) ld: fatal: Symbol referencing
no problem... I was probably the first to compile it that way
(understandably).
>> installed it worked fine, but I only found out during the compile.
>> ./configure didn't check for the binutils (not really important,
>> since I suspect it will be installed on most systems).
>      They are harmless.
>      - NC
Thanks,
Date: 3 Mar 2008 07:21:40
Message: <47cbed53@news.povray.org>
  I see. I suppose then it's just a question of whether gcc can create
the 64-bit executables in a format compatible with Solaris. I assume it can.
  I suppose that the configure script could somehow detect that the system
is an x86-64 running Solaris and test if 64-bit binaries can be compiled.
Of course there should still be an option to compile a 32-bit binary
anyways, if the user wants one.
