Hi group,
1/ Trying POV-Ray 3.7.0.beta.25 on Slackware 12.0 with 2.6.21.5-smp kernel,
Intel(R) Core(TM)2 Duo CPU E6550 @ 2.33GHz stepping 0b
I get a Segmentation fault with every .pov file I try, but which run fine
with Povray 3.6. Even a completely empty .pov causes the Segmentation fault.
The dialog ends with:
Library paths:
/usr/local/share/povray-3.7
/usr/local/share/povray-3.7/ini
/usr/local/share/povray-3.7/include
==== [Parsing...] ==========================================================
Segmentation fault
2/ BUT povray --version, povray --help and povray --benchmark all run OK.
I attach the entire dialgue from --benchmark below.
3/ Anybody else having this problem?
Any suggestions how to solve?
4/ I have tried this on 2 different Slackware 12.0 installations on the same PC.
In the first I installed it as user (to avoid getting tangled with existing
Povray 3.6).
In the second I installed it as root (no existing Povray installation).
But get the same problem with both.
5/ Had a lot of enjoyment using Povray, and looking forward to getting both my
cores rendering.
Cheers,
Peter
povray --benchmark
povray: this pre-release version of POV-Ray for Unix expires in 45 day(s) and 4
hour(s)
POV-Ray 3.7.0.beta.25 (icpc 10.1 @ i586-pc-linux-gnu)
Entering the standard POV-Ray 3.7 benchmark version 2.01.
This built-in benchmark requires POV-Ray to be installed on your system
before running it. There will be neither display nor file output, and
any additional command-line option except setting the number of render
threads (+wtN for N threads) and library paths (+Lpath) will be ignored.
To get an accurate benchmark result you might consider running POV-Ray
with the Unix 'time' command (e.g. 'time povray -benchmark').
The benchmark will run using 2 render thread(s).
Press <Enter> to continue or <Ctrl-C> to abort.
povray: creating /tmp/pov4851.ini
povray: creating /tmp/pov4851.pov
Running standard POV-Ray benchmark version 2.01
Persistence of Vision(tm) Ray Tracer Version 3.7.0.beta.25 (icpc 10.1 @
i586-pc-linux-gnu)
This is a time-limited beta test version. No re-distribution
of any sort is permitted.
POV-Ray is based on DKBTrace 2.12 by David K. Buck & Aaron A. Collins
Copyright 1991-2003 Persistence of Vision Team
Copyright 2003-2008 Persistence of Vision Raytracer Pty. Ltd.
Primary POV-Ray 3.6/3.7 Developers: (Alphabetically)
Chris Cason Thorsten Froehlich Christoph Hormann Nathan Kopp
Contributing Authors: (Alphabetically)
Steve Anger Eric Barish Dieter Bayer Steve A. Bennett
David K. Buck Nicolas Calimet Aaron A. Collins Chris Dailey
Steve Demlow Andreas Dilger Alexander Enzmann Dan Farmer
Mark Gordon Christoph Hormann Mike Hough Chris Huff
Kari Kivisalo Lutz Kretzschmar Jochen Lippert Pascal Massimino
Jim McElhiney Douglas Muir Juha Nieminen Ron Parker
Bill Pulver Eduard Schwan Wlodzimierz Skiba Robert Skinner
Yvo Smellenbergh Zsolt Szalavari Scott Taylor Massimo Valentini
Timothy Wegner Drew Wells Chris Young
Other contributors are listed in the documentation.
Support libraries used by POV-Ray:
ZLib 1.2.3.3, Copyright 1995-1998 Jean-loup Gailly and Mark Adler
LibPNG 1.2.15beta, Copyright 1998-2002 Glenn Randers-Pehrson
LibJPEG 62, Copyright 1998 Thomas G. Lane
LibTIFF 3.8.2, Copyright 1988-1997 Sam Leffler, 1991-1997 SGI
Boost 1.34, http://www.boost.org/
OpenEXR 1.2.2, Copyright (c) 2004, Industrial Light & Magic.
Parser Options
Input file: /tmp/pov4851.pov (compatible to version 3.50)
Remove bounds........On
Split unions.........Off
Library paths:
Building mesh2:
- vertex_vectors
- normal_vectors
- uv_vectors
- face_indices
Parse Warning: gamma_correction not specified or inferred so is turned off for
compatibility w
Parser Statistics
Finite Objects: 40
Infinite Objects: 2
Light Sources: 2
Total: 44
Parser Time
Parse Time: 0 hours 0 minutes 0 seconds (0.000 seconds)
using 1 thread(s) with 0.894 CPU-seconds total
Bounding Time: 0 hours 0 minutes 0 seconds (0.000 seconds)
using 1 thread(s) with 0.000 CPU-seconds total
Render Options
Quality: 9
Bounding boxes.......On Bounding threshold: 3
Antialiasing.........On (Method 1, Threshold 0.300, Depth 3, Jitter 0.30)
==== [Rendering...] ========================================================
Rendered 262144 of 262144 pixels (100%)
Render Statistics
Image Resolution 512 x 512
Pixels: 294912 Samples: 661338 Smpls/Pxl: 2.24
Rays: 1568965 Saved: 5255 Max Level: 12/12
Ray->Shape Intersection Tests Succeeded Percentage
Box 14877799 12821111 86.18
Cone/Cylinder 24854828 9634152 38.76
CSG Intersection 18650564 7330015 39.30
CSG Merge 409802 49300 12.03
Fractal 1148626 177484 15.45
Height Field 1637641 176684 10.79
Height Field Box 1637641 1252137 76.46
Height Field Triangle 6108714 182109 2.98
Height Field Block 10379810 3136043 30.21
Height Field Cell 42138857 3353316 7.96
Isosurface 21751825 785119 3.61
Isosurface Container 21752343 21752339 100.00
Isosurface Cache 247338 12611 5.10
Mesh 1214031 110671 9.12
Plane 20556002 1217980 5.93
Sphere 3523221 2254226 63.98
Superellipsoid 341574 80089 23.45
Torus 3289801 730878 22.22
Torus Bound 3289801 839963 25.53
True Type Font 35387 12677 35.82
Clipping Object 2817743 1330192 47.21
Bounding Box 391226762 160023811 40.90
Isosurface roots: 21738790
Function VM calls: 299814490
Crackle Cache Queries: 657453
Crackle Cache Hits: 653939 ( 99 percent)
Roots tested: 839963 eliminated: 563717
Shadow Ray Tests: 21975924 Succeeded: 7573615
Shadow Cache Hits: 2983586
Reflected Rays: 242321 Total Internal: 2
Refracted Rays: 161530
Transmitted Rays: 204105
Render Time:
Photon Time: 0 hours 0 minutes 0 seconds (0.350 seconds)
using 5 thread(s) with 0.407 CPU-seconds total
Radiosity Time: No radiosity
Trace Time: 0 hours 3 minutes 56 seconds (236.119 seconds)
using 2 thread(s) with 460.579 CPU-seconds total
povray: removing /tmp/pov4851.ini
povray: removing /tmp/pov4851.pov
POV-Ray finished
Subject: Re: Segmentation fault - POV-Ray 3.7.0.beta.25 on Slackware 12.0
Date: 15 Feb 2008 14:14:58
Message: <47b5e4b2$1@news.povray.org>
> Hi group,
> Library paths:
> Segmentation fault
Maybe a stacktrace would help developers track it down; although I don't
know if it's compiled with debugging information.
If you were running povray as:
$ ./povray -Isomefile.pov +w640 +h480 -whatever-other-options
Try this:
$ gdb povray
(gdb) set args -Isomefile.pov +w640 +h480 -whatever-other-options
(gdb) run
Wait for the segfault, and type 'bt' on the (gdb) prompt.
Nicolas Alvarez <nic### [at] gmail is the best com> wrote:
> > Hi group,
> > Library paths:
> > Segmentation fault
> Try this:
> $ gdb povray
> (gdb) run
Mon Dieu, that was a quick response!
Don't think there's any useful debug info.
For what it's worth I had tried gdb and strace - they gave me:
gdb:
Library paths:
[New LWP 10856]
Program received signal SIGSEGV, Segmentation fault.
[Switching to LWP 10856]
0xb3f9c679 in ?? ()
(gdb) bt
#0 0xb3f9c679 in ?? ()
#1 0xb3f61824 in ?? ()
#2 0xb403fc44 in ?? ()
#3 0x088d396c in ?? ()
#4 0x088d3268 in ?? ()
#5 0xb769bd34 in ?? ()
#6 0x08550ec0 in ?? ()
#7 0xb3f89fd0 in ?? ()
#8 0x088d3268 in ?? ()
#9 0xb5311b80 in ?? ()
#10 0x00000006 in ?? ()
#11 0x00000001 in ?? ()
#12 0x00000000 in ?? ()
strace ended with:
gettimeofday({1203103844, 324474}, NULL) = 0
clock_gettime(CLOCK_REALTIME, {1203103844, 324498344}) = 0
futex(0x886fe94, FUTEX_WAIT, 1, {0, 199975656}) = 0
futex(0x886fe70, FUTEX_WAIT, 2, NULL) = 0
futex(0x886fe70, FUTEX_WAKE, 1) = 0
write(2, "Parser Options\n", 15Parser Options
) = 15
write(2, " Input file: fred.pov\n", 23 Input file: fred.pov
) = 23
write(2, " Remove bounds........On \n", 27 Remove bounds........On
) = 27
write(2, " Split unions.........Off\n", 27 Split unions.........Off
) = 27
write(2, " Library paths:\n", 17 Library paths:
) = 17
write(2, " /usr/local/share/povray-3.7\n", 32 /usr/local/share/povray-3.7
) = 32
write(2, " /usr/local/share/povray-3.7/"..., 36
) = 36
write(2, " /usr/local/share/povray-3.7/"..., 40
) = 40
write(2, "==== [Parsing...] =============="..., 77==== [Parsing...]
) = 77
gettimeofday({1203103844, 375939}, NULL) = 0
clock_gettime(CLOCK_REALTIME, {1203103844, 375959947}) = 0
futex(0x886fe94, FUTEX_WAIT, 3, {0, 199979053}) = -1 EINTR (Interrupted system
call)
+++ killed by SIGSEGV (core dumped) +++
Process 10977 detached
Cheers,
Peter
"geep999" <nomail@nomail> wrote:
> Hi group,
WORKAROUND: compiling from the newly available 3.7.0.beta.25b source works fine!
> Library paths:
> Segmentation fault
> Povray 3.6).
> cores rendering.
> Cheers,
> Peter
> povray --benchmark
> hour(s)
> i586-pc-linux-gnu)
> Parser Options
> Library paths:
> Building mesh2:
> - vertex_vectors
> - normal_vectors
> - uv_vectors
> - face_indices
> compatibility w
> Parser Statistics
> Finite Objects: 40
> Infinite Objects: 2
> Light Sources: 2
> Total: 44
> Parser Time
> Render Options
> Quality: 9
> Render Statistics
> Render Time:
> POV-Ray finished
