POV-Ray : Newsgroups : povray.beta-test : problem with reflecting transparent isosurface Server Time
17 Feb 2026 02:14:48 EST (-0500)
  problem with reflecting transparent isosurface (Message 1 to 3 of 3)
Subject: problem with reflecting transparent isosurface
Date: 4 Feb 2008 14:15:01
Message: <web.47a76202449242641bd6cd0c0@news.povray.org>
When rendering the isosurface shown below in beta 25 (or 24 for that matter), I
get 'missing' render blocks both in the preview and in the final picture which
are completely or partially replaced by gray stripes. When I remove either the
transparency (in pigment) or the reflection (in finish) the problem disappears.
Enlarging the container seems to change the pattern but doesn't eliminate it. In
addition, the present box should be ample and anyway this sample works fine as
it is in 3.6.
Jeroen.
// Isosurface sample
camera { location 10*y look_at 0 }
light_source { 50 color rgb 1 }
#declare fn_surface = function { pattern { ripples } }
isosurface {
  function { y-fn_surface(x,0,z) }
  accuracy 0.005
  max_gradient 5
  contained_by { box { <-10,-4.9,-5>,<10,2,5> } }
  pigment { color rgbt 0.9 }
  finish { reflection 0.7 }
Subject: Re: problem with reflecting transparent isosurface
Date: 4 Feb 2008 14:36:35
Message: <47a76943$1@news.povray.org>
RTFM - all_intersections
Date: 5 Feb 2008 05:05:50
Message: <47a834fe$1@news.povray.org>
Please accept my apologies for the terseness of Thorsten's reply.
You may like to check all_intersections here:
  http://www.povray.org/documentation/view/3.6.1/300/
-- Chris
