POV-Ray : Newsgroups : povray.beta-test : selective component loading..... Server Time
28 Mar 2026 16:43:25 EDT (-0400)
  selective component loading..... (Message 1 to 10 of 10)
Subject: selective component loading.....
Date: 21 Oct 2007 13:35:00
Message: <web.471b8d4aa1752c5efedbe4b90@news.povray.org>
is there such a system in the scene control language?
IE...  a very large file of many textures takes up too much memory
is there anyway to only load "specific" lines from an include file? not the
whole file.
Subject: Re: selective component loading.....
Date: 21 Oct 2007 18:00:00
Message: <471bcbe0@news.povray.org>
Andycadd nous apporta ses lumieres en ce 2007/10/21 13:32:
> whole file.
Nothing built-in.
What you can do: make your own custom include file from the bits and pieces from
the various includes you use. That way, you only concerve the deffinitions that
you actualy use, plus some that you think you may need further in the devlopment
of your scene.
A Bill of Rights is what the people are entitled to against every
government, and what no just government should refuse, or rest on inference.
Thomas Jefferson
Date: 22 Oct 2007 19:08:29
Message: <471d2d6d@news.povray.org>
> whole file.
Totally wrong newsgroup; setting followup to povray.general.
You could either keep it in separate files, or use #if statements.
On main scene:
#declare UseHighQualityModels=no;
#declare UseHighQualityTextures=no;
On an included file:
#if(UseHighQualityModels)
  #declare Model = union {
   ...something BIG
#else
   ...simplified model...
object {
  Model
  #if(UseHighQualityTextures)
    ...something BIG
  #else
   color Yellow
Date: 23 Oct 2007 20:55:00
Message: <web.471e96f67dcd5e2ffedbe4b90@news.povray.org>
> > whole file.
> On main scene:
>    ...something BIG
> #else
> #end
> object {
>   Model
>    texture {
>     ...something BIG
>   #else
>   pigment {
>    color Yellow
>   #end
Thank you for your very useful routines for step 2
BUT....    step 1.  Is there a partial load possible for ".inc" files?
a file access keyword to let me search for specific textures/materials from
within the parser, rather than loading the entire ".inc" file.
the SCENE DESCRIPTION LANGUAGE equivalent to:
(fileopen "XXX" "rw")
(wcmatch "XXXX" file)
(readfile ....  " xx ;" )
I want to do this because I have a few thousand texture maps and definitions
which overload the stack if I load them all simultaneously.
Or better would be a "purge" type function to clear out unused textures from
the stack before rendering.
I have a collection of many thousand finishes and architectural elements, in
texture/material definitions some are in bitmap form.  I slapped them
together with excel into a dozen or so ".inc" files that are cumbersome to
work with.  So selective loading would minimize my cumber with regards to
using my library.
The best would be a "purge" type function, to remove the excess items.  This
would be the most useful and trouble free, especially if it could be called
repeatedly from within an ".inc" file.
oh and where is the proper group for this discussion?
Date: 23 Oct 2007 21:10:01
Message: <web.471e9b2d7dcd5e2ffedbe4b90@news.povray.org>
> > whole file.
> On main scene:
>    ...something BIG
> #else
> #end
> object {
>   Model
>    texture {
>     ...something BIG
>   #else
>   pigment {
>    color Yellow
>   #end
Date: 24 Oct 2007 12:31:00
Message: <471f7344@news.povray.org>
Andycadd nous apporta ses lumieres en ce 2007/10/23 20:51:
>>> whole file.
>> On main scene:
>>    ...something BIG
>> #else
>> #end
>> object {
>>   Model
>>    texture {
>>     ...something BIG
>>   #else
>>   pigment {
>>    color Yellow
>>   #end
> using my library.
There is NO WAY that you can only load some parts of an include file. There is
NO "purge" command.
At the present time, your options are:
  - Load the entire include files.
  - Make your own custom, expurged, includes. Those can be trimmed down to only
the deffinitions that you actualy use.
Please note that this topic does NOT belong to the beta-test group, but to the
advanced-users group.
You know you've been raytracing too long when you have ever brought your
computer to its knees by mistakenly launching 64 simultaneous frames to be
traced, while trying to maximizing the benefits of parallelizing them.
Carsten Whimster
Date: 24 Oct 2007 17:07:58
Message: <471fb42e@news.povray.org>
No. But you can do:
#if (something)
#include "file.inc"
Conditional including is possible. Partial including is not.
Date: 24 Oct 2007 21:10:00
Message: <web.471feca07dcd5e2ffedbe4b90@news.povray.org>
> No. But you can do:
> #if (something)
> #include "file.inc"
> #end
Yes Yes is there a glossary/appendix for the syntax somewhere?
thank you
Date: 14 Nov 2007 01:35:00
Message: <web.473a95fa7dcd5e2ffedbe4b90@news.povray.org>
> > No. But you can do:
> > #if (something)
> > #include "file.inc"
> > #end
> thank you
Selective texture loading is possible...
1. Generate a list of the materials used (manually)
2. declare those materials/textures as simple low res textures
3. load the big long ".inc" file containg large numbers of textures, most of
which you wont load.
4. each material definition is wrapped in a conditional
#if   #then  using the "MATERIALNAME" so that only previously defined materials
are loaded / REdeclared.  all the other material names in the include file will
not be read in because the ifthen statement filtered them out.
5. you have just selectively loaded a material definition libraryfile.
6. definition file can contain large numbers of bitmaps or other
complex files.
PS  im sure i've seen this system somewhere anyone
Date: 19 Nov 2007 16:10:27
Message: <4741fbc3$1@news.povray.org>
>>> whole file.
>> On main scene:
>>    ...something BIG
>> #else
>> #end
>> object {
>>   Model
>>    texture {
>>     ...something BIG
>>   #else
>>   pigment {
>>    color Yellow
>>   #end
> using my library.
I tend to keep a global variable, IsTest, in the scene file, prior to any
includes.  The include files can then use this variable to use "final" and
"test" versions of their objects.
Any object, texture, etc. that wanted to use this functionality would use the
#if directive.  You could just as easily use several test variables for
"stubbing" various groups of objects.
David Wallace
TenArbor Consulting
"Just In Time Cash"
www.tenarbor.com
1-866-572-CASH
