POV-Ray : Newsgroups : povray.beta-test : Subset_Start_Frame doesn't work? Server Time
18 Nov 2025 03:18:40 EST (-0500)
  Subset_Start_Frame doesn't work? (Message 1 to 2 of 2)
Subject: Subset_Start_Frame doesn't work?
Date: 3 Nov 2006 11:05:00
Message: <web.454b67a8defacc9bf2985afc0@news.povray.org>
When I render an animation using an INI-file that contains the following
lines:
   Final_Frame=675
   Subset_Start_Frame=125
   Subset_End_Frame=276
I get frames 1 through 276, instead of 125 through 276.
Apparently, Subset_Start_Frame does not work and Subset_End_Frame does.
Same behaviour when I use +SF125.
Same behaviour when I use the commandline.
Am I missing something?
I'm running 3.7.0.beta.16.msvc8.win64
Thanks for your help and your time.
Subject: Re: Subset_Start_Frame doesn't work?
Date: 3 Nov 2006 12:34:41
Message: <454b7db1@news.povray.org>
> lines:
>    Final_Frame=675
Confirmed, seems I missed that when fixing the Initial_Frame problem. Will be
fixed in next beta.
-- Chris
