Subject: Re: SMP positive response with minor problem animating PNG files CRASH
Date: 8 Oct 2006 10:20:02
Message: <45290912@news.povray.org>
Warp wrote:
> Andycadd <And### [at] comcast net> wrote:
>> not so Strange that it works just fine with 3.6 but not 3.7 as 3.7 probably
>> uses a little more memory overhead
> No, there's nothing in 3.7 which should use more memory than 3.6. It is
> not normal. If you can come up with a good example scene, it would be very
> helpful.
You are mistaken, it is normal. The image output was changed, which does
matter if you have a 8K x 2K pixel image - that image will consume 320M
bytes of memory right now, as disk buffering has not been implemented yet.
Thorsten
Date: 8 Oct 2006 12:54:51
Message: <45292d5a@news.povray.org>
Ah, I thought it already did that...
Date: 9 Oct 2006 11:52:35
Message: <452a7043$1@news.povray.org>
Andycadd nous apporta ses lumieres en ce 08/10/2006 00:25:
>>> Is there a reason for the default "block style" rendering in 3.7 rather that
>>> the "scan-line style" of 3.6?
>> Yes: SMP.
>>> But..... both of the Beta renders crashed after the first frame
>>> (rendering to png with default settings) while the 3.6 render continued onto
>>> the next frame. I haven't tried any other output formats yet but I probably
>>> will.
>> Could you provide a short scene (and rendering settings) that shows this?
>> - Warp
> When I remove some of the model it renders just fine in animation mode
> when I crank the resolution down it runs just fine in animation mode
> probably if I turn off display it would work fine also
> It must be that a GIG of ram is just on the line for a successful render at
> 8000 X 2000 with a rather large model file
> Strange that it would start and render/display the first frame
> what follows is the log for the first frame a very large model (I put a
> cropped portion in the images directory titled "future hotel") rendered in
> 3.6
> Render Options
> Quality: 9
> Bounding boxes.......On Bounding threshold: 3
> Antialiasing.........On (Method 1, Threshold 0.040, Depth 3, Jitter 1.00)
> Render Statistics
> Image Resolution 8000 x 2000
> Pixels: 17004000 Samples: 4247388 Smpls/Pxl: 0.25
> Rays: 21251388 Saved: 0 Max Level: 1/6
> Ray->Shape Intersection Tests Succeeded Percentage
> Cone/Cylinder 1294518 0 0.00
> CSG Merge 215753 0 0.00
> Mesh 21797976 1498108 6.87
> Sphere 42502776 42502776 100.00
> Triangle 1718215371 28586386 1.66
> Bounding Box 2302667593 1172313524 50.91
> Shadow Ray Tests: 884757 Succeeded: 338247
> Shadow Cache Hits: 338169
> Smallest Alloc: 0 bytes
> Largest Alloc: 0 bytes
> Render Time:
> Photon Time: No photons
> Radiosity Time: No radiosity
> Trace Time: 0 hours 8 minutes 45 seconds (525.734 seconds)
> using 4 thread(s) with 991.436 CPU-seconds total
> End of First Frame
> here is the error messages
> Possible Parse Error: Cannot find file 'C:povtsstone9bel11.pov', even after
> trying to append file type extension.
> Parse Error: Cannot open input file.
> Possible Parse Error: Cannot parse input.
> Render failed
> CPU time used: kernel 78.80 seconds, user 8602.11 seconds, total 8680.91
> seconds.
> Elapsed time 4525.23 seconds, CPU vs elapsed time ratio 1.92.
I've been hit by that error somes times doing animations. Render some frames,
then it looks like the path to the source file get lost. The can't find file
error message always reffers to the actual scene file. It looks like the file
gets actualy parsed, then the error pops up.
Inside every older person is a younger person wondering what happened.
> > helpful.
> Thorsten
Disk buffering ..... that is working in 3.6 currently?
How come the windows virtual memory doesn't just pick this up?
PLEASE excuse my ignorance.
Date: 10 Oct 2006 09:18:02
Message: <452b9d8a$1@news.povray.org>
There is no "disk buffering". What POV-Ray 3.6 and earlier do is write the
file to disk line by line. While POV-Ray 3.7 also writes the file in a
temporary format to disk to support a continue trace in case of a crash, it
further keeps a whole copy in memory as it will now write the final image to
disk at the end of the render, rather than write it incrementally and
(mis)use it as continue trace buffer like 3.6 and earlier did.
The problem with using any fixed image format for continue trace in 3.6 and
earlier is that image formats do not actually store all the information
necessary to properly continue a trace, in particular with anti-aliasing
enabled. Hence this problem has been addressed in 3.7.
Because you still only have 2 GB to 3GB (depending on Windows version) of
address space for a 32 bit application.
Thorsten
Subject: Re: SMP positive response with minor problem animating PNG filesCRASH
Date: 10 Oct 2006 14:52:17
Message: <452bebe1@news.povray.org>
> Thorsten
If it's really a problem with memory addressing, as you seem to be
suggesting, perhaps a more suitable error message could be introduced?
...Chambers
> Thorsten
Is there an option to not keep a full copy in memory (freeing up that 320MB
mentioned above) with or without a running display ? I know this would be a
speed hit but Rambus memory ain't cheap. Or maybe just keep the previous
row in memory and flush the extra?
Date: 10 Oct 2006 18:11:46
Message: <452c1aa2@news.povray.org>
As I said before: "disk buffering has not been implemented yet." So this
issue will go away really "soon"...
Thorsten
> Thorsten
Sorry bout that I misread to be clear I love the SMP features makes my Dual
2.4 Xeons useful again. I also own an older Quad Xeon w/1MBcache EA proc
does the SMP feature use all 4 procs? They are only 550Mhz ea but big
cache size could help. should I put it back together?
Date: 12 Oct 2006 07:55:24
Message: <452e2d2b@news.povray.org>
That's a strange question, don't you think?
