POV-Ray : Newsgroups : povray.beta-test : Change threads in 3.7 Beta linux-x86_64 Server Time
4 Mar 2026 12:29:50 EST (-0500)
  Change threads in 3.7 Beta linux-x86_64 (Message 1 to 2 of 2)
Subject: Change threads in 3.7 Beta linux-x86_64
Date: 5 Oct 2006 22:55:01
Message: <web.4525c4f0244de66758035aeb0@news.povray.org>
I am currently deploying pov-ray on a system with 8 physical cores, however
when executed, povray will only use 2 threads to render the entire image.
Is there some .ini file I need to edit or some commandline parameter to
enable more threads when rendering?
Subject: Re: Change threads in 3.7 Beta linux-x86_64
Date: 6 Oct 2006 00:06:00
Message: <4525d628$1@news.povray.org>
Not sure I can answer with 100% certainty, yet maybe if you run POV adding
to the command-line /threads 8 (or whatever number). Been a while since I
even checked into this sort of thing.
I think this is correct for Windows but I'm not sure about it for different
platforms.
There's also a WorkThreads=8 INI variable, or -wt8 (again, using whatever
number needed) on the command-line to limit the maximum used, as I
understand it anyhow.
Maybe somebody could correct me if wrong, please?
