POV-Ray : Newsgroups : povray.beta-test : -no-arch-check required for Opteron, -GA stopped working. Server Time
18 Nov 2025 08:58:45 EST (-0500)
  -no-arch-check required for Opteron, -GA stopped working. (Message 1 to 3 of 3)
Subject: -no-arch-check required for Opteron, -GA stopped working.
Date: 30 Jun 2004 22:40:00
Message: <web.40e37871d32ee73b7e1586210@news.povray.org>
On install, Linux 2.4.19-SMP on Opteron system was not recognized as a Linux
PC. Required an install with -no-arch-check. No problems after that.
The -GA option on the command line seems to have quit working.
Not sure if either is intended behavior or not.
Please regard this as feedback rather than any defect report.
CB
Subject: Re: -no-arch-check required for Opteron, -GA stopped working.
Date: 1 Jul 2004 03:55:02
Message: <cc0fs1$21b$1@chho.imagico.de>
That is to be expected.  Although the official binary will probably run
on an opteron it is surely better to compile from source (which will be
available soon).
That's somewhat unprecise, you mean '+GAfile' does not generate a file
with the whole text output?
Since beta phase has ended this is in fact the wrong group for such a
posting (povray.unix would be correct).
Last updated 01 May. 2004 _____./\/^>_*_<^\/\.______
Date: 1 Jul 2004 08:39:45
Message: <40e40611@news.povray.org>
  -GA should suppress almost all the output. It did. It doesn't.
