POV 3.5 b 11 icl on WinNT Sp 6 PII 233 with 128 MB
Following script causes crash in POV-Ray 3.5 b 11.
Two notes:
1) When I remove "u0,v0," from parameters and calls (becouse it's not used at
all in posted example) then this not crash.
2) When I replace "Pattern(u1,v1,0)" with "u1+v1" in Sub[0] assigment then
this not crash.
Could it be becouse all entries of array of functions have to have the same
number of parameters ?
Any confirmation ?
// START
#local Level=6;
#local Dist=1/(2^Level-1);
#local Pattern=function{pattern{agate}}
#local Sub=array[Level];
#local Sub[0]=function(u0,v0,u1,v1){Pattern(u1,v1,0)};
#local Sub[1]=function(u0,v0,u1,v1,u2,v2){
min(
Sub[0](u0,v0,u1,v1),
Sub[0](u0,v0,u1,v2),
Sub[0](u0,v0,u2,v1),
Sub[0](u0,v0,u2,v2)
#local C=2;
#while (C<Level)
#local Sub[C]=function(u0,v0,u1,v1,u2,v2){
min(
Sub[C-1](
u0,v0,
u1,v1,
(u1+u2)/2-Dist,(v1+v2)/2-Dist
Sub[C-1](
u0,v0,
u1,(v1+v2)/2+Dist,
(u1+u2)/2-Dist,v2
Sub[C-1](
u0,v0,
(u1+u2)/2+Dist,v1,
u2,(v1+v2)/2-Dist
Sub[C-1](
u0,v0,
(u1+u2)/2+Dist,(v1+v2)/2+Dist,
u2,v2
#local C=C+1;
#local F=function{Sub[Level-1](x,y,x-1,y-1,x+1,y+1)};
plane{
z 0
pigment{function{F(x,y,z)}}
translate z*4
finish{ambient 1}
// END
ABX
Right, posted source was far from brief report. I posted it in that form to be
sure that I don't miss any of elements of complexity. It still was a shortcut
of real source. Anyway here is further and shorter investigation.
For L=2 and L=3 it works.
For L=4 it reports parse error "Problem in Evaluate_TPat"
For L=5 and greater it reports access violation exception
Any confirmation ?
Here is script (short enogh ?)
#local L=6;
#local S=array[L];
#local S[0]=function(u0,v0,u1,v1){Pattern(u1,v1,0)};
#local S[1]=function(u0,v0,u1,v1){S[0](u0,v0,u1,v1)};
#local C=2;
#while (C<L)
#local S[C]=function(u0,v0,u1,v1){S[C-1](u0,v0,u1,v1)};
#local C=C+1;
#local C=S[L-1](0,0,-1,-1);
ABX
