POV-Ray : Newsgroups : povray.beta-test : frequency keyword conflict Server Time
30 Sep 2024 11:18:14 EDT (-0400)
  frequency keyword conflict (Message 1 to 4 of 4)
Subject: frequency keyword conflict
Date: 24 Mar 2002 08:21:40
Message: <slrna9rkn4.d3i.yeti@monoceros.physics.muni.cz>
Not exactly a bug, but still needs fixing:
The `frequency' keyword is used for two completely different
things
- in colour_maps to specify how many times they should be
  mapped over the [0,1] interval
- in ripples and waves patterns to specify the wave
  frequency
They conflict.  Consider
  camera { location <0, 20, -30> look_at <0, 0, 0> }
  light_source { <30, 30, -30>, White }
  plane {
    y, 0
    pigment { ripples frequency 5 scale 20 }
    clipped_by { box { <-20, -1, -20> <0, 1, 40> } }
  plane {
    y, 0
    pigment { Gray70 }
    normal { ripples frequency 5 scale 20 }
    clipped_by { box { <-20, -1, -20> <20, 1, 40> } }
As normals (right), the ripples are OK, but as pigment
(left) they are broken, because `frequency' was used for
both wave frequency and colour_map frequency.
I suggest using a separate keyword like `wave_frequency' or
so for wave frequencies.  Consider one can't use ripples
in isosurface now (well, can, but can't set frequency).
Yeti
Subject: Re: frequency keyword conflict
Date: 24 Mar 2002 13:36:15
Message: <3c9e1c9f@news.povray.org>
"David Necas (Yeti)" <yet### [at] monocerosphysicsmunicz> wrote in message
news:slr### [at] monocerosphysicsmunicz...
Not so sure, myself.
> things
>   frequency
---snip---
 (Notice that you accidentally made the clipping box for the normal extend
to -20 and it needs to be 0 so the two planes show. Just so people know
that.)
---snip---
The number_of_waves global setting usually controls this, not frequency. Of
course that doesn't apply to non-ripples and non-waves patterns.
Consider the following, taking your example and changing it a bit:
 global_settings {
        number_of_waves 5
  light_source { <30, 30, -30>, 1 }
  plane {
    y, 0
    pigment { ripples sine_wave frequency 2 scale 5 }
  plane {
    y, 0
    pigment { rgb .7 }
    normal { ripples 7 sine_wave frequency 2 scale 5 }
    clipped_by { box { <0, -1, -20> <20, 1, 40> } }
This shows wave_type matters as well, but anyhow I can get a close match. If
there's truly a problem or difficulty in the usage of frequency I couldn't
say if it matters or not. This is just my observation at the moment.
bob h
Date: 24 Mar 2002 16:43:54
Message: <slrna9si4p.it1.yeti@monoceros.physics.muni.cz>
In article <3c9e1c9f@news.povray.org>, bob h wrote:
>---snip---
>that.)
>---snip---
I'm sorry.
No, number_of_waves controls number of waves (i.e wave
centers), while frequency controls their frequency.
> Of
> global_settings {
>        number_of_waves 5
>  plane {
>    y, 0
>  plane {
>    y, 0
>    pigment { rgb .7 }
Using sine_wave and integer frequency _hides_ the problem,
but it's still there.  sine_wave makes the pigment smooth,
not right (and it distorts the wave shapes, one has to use
asin()-like colour_map to get original shapes).  Just try
frequency 1.5 instead of 2 in your example and you'll see
what I mean.
However, one perhaps could get by with your solution in most
practical cases.
Yeti
Date: 25 Mar 2002 02:29:55
Message: <3c9ed1f3@news.povray.org>
Followup-To povray.general, since this is likely to be off-topic for the
beta. For now anyway.
> what I mean.
I can see your point, I was trying to think of something at the spur of the
moment about your message post.
Keeping in mind that a pigment is unlike a normal, they probably can't be
used in identical ways. I was hoping someone else would have discussed this
before I got back to it though, since I don't understand the underlying
factors for the differences. Just apparent that normals don't adhere to the
same method as pigments for how they are formed. Someone must know why that
is.
sphere_sweep{b_spline 20<-2,-2,4>.1<-2,-1,4>.15<-1.5,1,4>.1<0,0,4>.1
<-2,0,4>.1<0,-1,4>.1<-2.5,-1,4>.1<-.5,-1,4>.1,<0,0,4>.1<1,-.5,4>.1
<0,-1,4>.1<-.5,-.5,4>.1<0,0,4>.1<1,-1,4>.1<1.5,-.25,4>.1<2,0,4>.1
<2,-.75,4>.1<1,-1,4>.1<1.5,1,4>.1<1.5,1,4>.1pigment{rgb 9}}//v3.5
