POV-Ray : Newsgroups : povray.beta-test : [Linux] -h doesn't seem to work. Server Time
30 Sep 2024 13:22:27 EDT (-0400)
  [Linux] -h doesn't seem to work. (Message 1 to 10 of 12)
Subject: [Linux] -h doesn't seem to work.
Date: 8 Mar 2002 13:46:00
Message: <slrna8i1n0.fli.steve@zero-pps.localdomain>
povray 3.5 beta 12 on Linux RH7.2, 320M RAM, on PII 266.
The command line help doesn't seem to work with any of
the numbers as specified in the man page.
I've tried:
povray -h0
povray -H0
povray +h0
povray +H0
and tried other numbers too.
It's asthough it's still looking for an input file name on the command
line.
#local i=.1;#local I=(i/i)/i;#local l=(i+i)/i;#local ll=(I/i)/l;box{<-ll,
-((I/I)+l),-ll><ll,-l,ll>pigment{checker scale l}finish{ambient((I/l)/I)+
(l/I)}}sphere{<i-i,l-l,(I/l)>l/l pigment{rgb((I/l)/I)}finish{reflection((
I/l)/I)-(l/I)specular(I/l)/I}}light_source{<I-l,I+I,(I-l)/l>l/l} // Steve
Subject: Re: [Linux] -h doesn't seem to work.
Date: 8 Mar 2002 14:12:24
Message: <3c890d18$1@news.povray.org>
In article <slr### [at] zero-ppslocaldomain> , Steve
> I've tried:
> povray -h0
> povray -H0
> povray +h0
> povray +H0
> line.
You are mistaking the image height with help.  Take a look in the manual for
the correct syntax because if the above really is in the man page, the man
page is incorrect.
    Thorsten
Date: 8 Mar 2002 22:13:34
Message: <3c897dde$1@news.povray.org>
>> The command line help doesn't seem to work with any of the numbers as
>> I've tried:
>> povray -h0
>> povray -H0
>> povray +h0
>> povray +H0
>> line.
> for the correct syntax because if the above really is in the man page,
> the man page is incorrect.
OK, but then so is the Usage function in optout.  "povray -h" still gives
a full usage summary, as does "povray" alone or with "-?" or "-help".
"povray -h[0-7]" doesn't give a subset, as described sketchily in the man
page and in greater detail in the usage summary.  This worked in 3.1g, and
it's easy enough to figure out whether -h[0-7] is the only option, so it
shouldn't be too hard to make it work again.
Now that I poke at it, I see that some of the Unix-specific (mostly
X-related) command-line options aren't working, either.  I'll look into
fixing that for the next beta.
-Mark Gordon
Date: 9 Mar 2002 09:42:22
Message: <slrna8k7lo.i39.steve@zero-pps.localdomain>
-h[0-7] told me that it needed an integer so I assumed I was typing the
command wrong there and didn't include it in the examples I posted.
Those screens are quite useful in 3.1g so it'll be nice to have them
back.
                                             or http://start.at/zero-pps
  2:37pm  up 3 days, 16:35,  1 user,  load average: 1.00, 1.00, 1.00
Date: 9 Mar 2002 11:36:13
Message: <3c8a39fd$1@news.povray.org>
> back.
They are there, just type -h, -help or -? without a number.
    Thorsten
Date: 9 Mar 2002 12:27:34
Message: <3c8a4606$1@news.povray.org>
I'm using a Unix shell globbing construction. By "-h[0-7]" I mean "-h0 or
-h1 or ... -h7".  -h alone gives the full usage summary, as Thorsten
mentions, so what's broken currently is the ability to get subsets of the
usage summary.
-Mark Gordon
Date: 18 Mar 2002 20:01:08
Message: <3c968dd4$1@news.povray.org>
> or -h1 or ... -h7".  -h alone gives the full usage summary, as Thorsten
> the usage summary.
OK, there's a change in the syntax.  From now on, use -?0, -?1 ....  This
should be less confusing to the user than overloading -h.  The usage
summary and the man page have been updated.
This bug is effectively fixed in the current beta.
-Mark Gordon
Date: 18 Mar 2002 21:21:40
Message: <slrna9d74i.8et.steve@zero-pps.localdomain>
>> the usage summary.
Thanks mark.  Just finished d/ling it 2 minutes ago.
sphere{z*5,1pigment{rgb.5}finish{reflection.3specular.5}}box{<-50,-3,-50>
<50,-2,50>pigment{checker/*\__\\__/  * \_\\__*/scale 2}finish{ambient.7}}
light_source/*__\\__\\__\\__\\__\(    ~ )\__\\__\\__\\__\\*/{<2,5,1>*4,1}
/*\\__\\__\\__\\__\\__\\__\\__\\__\~  -/__\\__\\__\\__\\__\\*//* Steve */
Date: 19 Mar 2002 08:33:37
Message: <3c973e31@news.povray.org>
  I suppose that you are aware that ? is a wildcard character in most command
line shells, which may cause problems if written as-is (ie. unless you put
the parameter into quotation marks, ie. eg. "-?0").
Date: 19 Mar 2002 20:56:53
Message: <3c97ec65$1@news.povray.org>
>   command
> put the parameter into quotation marks, ie. eg. "-?0").
OK, I've tested this on a couple of different systems.  Seems to work fine
under sh/bash/ksh (assuming you don't have a file matching that pattern in
.,which seems a reasonable bet), but it breaks under csh/tcsh/zsh:
% echo -?0
echo: No match.
So the problem isn't quite as widespread as first suggested, but it's
still broken.  I'd only tested this under bash, not having considered the
possibility that the shell might have other plans for the '?'.  I agree we
need to continue to offer an alternative to -?[n], and I'm currently
inclined to favor reverting to -h[n].
-Mark Gordon
