POV-Ray : Newsgroups : povray.beta-test : Timed out waiting for worker thread startup Server Time: 3 Dec 2008 02:11:19 GMT
  Timed out waiting for worker thread startup (Message 1 to 8 of 8)
Subject: Timed out waiting for worker thread startup
Date: 2 Mar 2008 09:37:48
Message: <47ca756c$1@news.povray.org>
Hello,
while looking for the reason of "Timed out waiting for worker thread
startup" error message (I'm on Gentoo ~amd64), I got a strange feelings.
Under ddd (gdb X11 interface), no problem.
Under normal shell, it happens (and a lot, after the first run).
Looking at vfeSession::Initialize (in vfe/vfesession.cpp), the lock on
which the timed_wait is performed (and failed in case of that issue), is,
if my C++ is not too rusty, built using m_InitializeMutex, a protected
member of vfeSession (class in vfe/vfesession.h)
And it seems it is never initialized (only one reference) explicitely, so
only the constructor of vfesession might in fact create that mutex.
It might be that g++ is over-optimizing the constructor of vfesession by
simply mapping the memory area, without resetting the mutex ?
I'm trying to re-compile with other g++ versions (my current is 4.2.3)
and see if it is better...
Subject: Re: Timed out waiting for worker thread startup
Date: 2 Mar 2008 15:08:30
Message: <47cac2ee$1@news.povray.org>
A heisenbug!
http://en.wikipedia.org/wiki/Unusual_software_bug#Heisenbugs
Date: 4 Mar 2008 09:29:59
Message: <slrn.fsq5k4.7m9.steev@hot.pl>
Tako rzecze Le Forgeron :
> [...] "Timed out waiting for worker thread
> startup" error message (I'm on Gentoo ~amd64), [...]
Same thing here.
Fedora 8 / 32bit
Tested with :
gcc version 4.1.2
icc Version 10.1
Slawek
  ________ Segmentation fault. Core dumped.
_/ __/ __/ But the memory remains. -- Bart
 \__ \__ \_______________________________________________________________
 /___/___/ Slawomir Szczyrba                          steev/AT/hot\dot\pl
Date: 4 Mar 2008 11:17:56
Message: <47cd2fe4@news.povray.org>
the mutex is a class in its own right and thus has its own constructor,
which is invoked when vfesession is constructed. so that's not likely to be
the issue.
looking at the code, I can see one possibility that jumps at me: it may be
I misread the usage for boost::condition at the time, or simply slipped up,
but it appears that if the worker thread created via 'new boost::thread()'
 at line 1082 of vfesession.cpp#23 was able to run as far as its call to
'm_InitializeEvent.notify_all()' (line 638) *prior* to the next line of
vfeSession::Initialize() executing, the notify_all would have no effect and
the subsequent timed_wait would time out*. (if this happens at all, it
would be more likely to occur on machines with a single core).
to test this theory, please try adding a printf to line 1082 which reads
like this:
  fprintf(stderr, "%p %d\n", m_Frontend, m_BackendState);
so you will then have:
  m_WorkerThread = new boost::thread(vfeSessionWorker(*this));
  if (m_InitializeEvent.timed_wait(lock, t) == false)
if all is well you ought to get 0 and 0 as the output. if you get an
initialized pointer and a backend state that's not 0, it's highly likely
that what I am describing is what is happening (if so, it won't be
difficult to fix, and probably should be irregardless of the outcome of
your test).
-- Chris
* I do note I have a 'FIXME' on the worker thread code at around that
  point, indicating I was not happy with it at the time (e.g. just from
  glancing at it now I see the exception thrown at line 636 is unlikely to
  ever be seen; throwing it would also trigger a timeout in the waiting
  code; and what's worse m_LastError is not set in that case. yuck!).
Date: 4 Mar 2008 13:26:20
Message: <slrn.fsqjf7.6g4.steev@hot.pl>
Take the red pill, Chris Cason...
Usually it displays:
./povray
0x83024b8 1
(first number differs, of course :)
and sometimes :
./povray
(nil) 0
No input file provided
> -- Chris
Slawek
  ________
_/ __/ __/ BOFH excuse 48: bad ether in the cables
 /___/___/ S³awomir Szczyrba                          steev/AT/hot\dot\pl
Date: 4 Mar 2008 17:58:59
Message: <47cd8de3@news.povray.org>
> ./povray
> 0x83024b8 1
> and sometimes :
> ./povray
> (nil) 0
I presume that in this latter case there is no pause ... that pretty much
nails it. it's a race condition not yet catered for. a temporary
work-around that will catch most instances is fairly simple: change
to read
  if (m_BackendState == kUnknown && m_InitializeEvent.timed_wait(lock, t)
    == false)
this is not a 100% solution as it still leaves a race condition, but the
window is much narrower and ought to get you going in most instances until
it's fixed properly.
-- Chris
Date: 4 Mar 2008 18:49:00
Message: <47cd999c@news.povray.org>
Le Wed, 05 Mar 2008 04:58:56 +1100, Chris Cason a modifié des petits
morceaux de l'univers pour nous faire lire :
> until it's fixed properly.
> -- Chris
It's a working workaround for me. Good job.
(Additional information, if needed later: amd64 3500+ (2.2GHz), one core,
Linux Gentoo, gcc 4.2.3, 64 bit binary(x86-64), kernel 2.6.23-gentoo-r9
(stable kernel, remaining ~amd64: unstable, usually), libstdc++ 5.0.7 v3)
fprintf display:
(nil) 0
0x.... 1
(nil) on first run, 0x... thereafter. Might be linked to code already in
cache. Or something totally different.
At least now, it works here.
Date: 4 Apr 2008 14:35:13
Message: <47f64ab1@news.povray.org>
I get this error fairly often (and randomly) as well.  I am running the
new beta25 Gentoo ebuild on x86.
					-Joe
Copyright 2003-2008 Persistence of Vision Raytracer Pty. Ltd.
