POV-Ray : Newsgroups : povray.beta-test : identifier of function Server Time
23 Sep 2025 00:49:57 EDT (-0400)
  identifier of function (Message 1 to 5 of 5)
Subject: identifier of function
Date: 19 Sep 2001 08:20:34
Message: <s83hqt01d1q4r9u4b7tr8e3cg0nfoo25fe@4ax.com>
platform info: WinNT4, PII 233, 128MB, POV3.5b2
Is name of function treated as identifier like for objects, pigments
and others ?
I'm trying to create such thing:
  #declare func=function(x,y,z){x+y+z}
  #macro Test(Func)
    #local New=function{Func}
  Test(func(1,2,3)) // call with parameter as float - works
  Test(func) // call with parameter as function - wrong syntax
Second call is wrong but I hav not found notation about it within
documentation. There is note "PARAM_IDENTs are a list of zero or more
formal parameter". Is identifier of function formal parameter ?
more about functions in another post
ABX
Subject: Re: identifier of function
Date: 19 Sep 2001 18:47:51
Message: <3ba92097@news.povray.org>
IIRC there's some kind of problem in passing function names as macro
paramters. AFAIK currently it's not possible.
Date: 19 Sep 2001 19:10:25
Message: <slrn9qi9f4.93p.ron.parker@fwi.com>
It may not become possible any time soon, either.  The problem is that it
requires more than a single token of lookahead to disambiguate between these
two macro calls:
#macro Foo(G)
  G
#declare F=function(x,y,z){x,y,z}
#declare H = Foo(F)
#declare I = Foo(F(1,2,3))
#local R=rgb 99;#local P=R-R;#local F=pigment{gradient x}box{0,1pigment{gradient
y pigment_map{[.5F pigment_map{[.3R][.3F color_map{[.15red 99][.15P]}rotate z*45
translate x]}]#local H=pigment{gradient y color_map{[.5P][.5R]}scale 1/3}[.5F
pigment_map{[.3R][.3H][.7H][.7R]}]}}}camera{location.5-3*z}//only my opinions
Date: 19 Sep 2001 19:14:38
Message: <slrn9qi9n1.94a.ron.parker@fwi.com>
>two macro calls:
However, this parses correctly and does what you expect.  I suggest that it
might want to be written up as either a FAQ entry or as a documentation
thingamawhatzis.  Watch out for the returning-locals-from-a-macro bug, though:
#macro Foo( Bar )
  #declare X = Bar(Y);
#declare Y=1;
#declare Baz=function(n){n+2}
Foo(function(n){Baz(n)})
#debug str(X,5,5)
#debug "\n"
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
Date: 20 Sep 2001 03:07:36
Message: <605jqt0hmv94mamuc847i19f9mnil2p3kf@4ax.com>
On 19 Sep 2001 19:14:38 -0400, ron### [at] povrayorg (Ron Parker)
> #macro Foo( Bar )
> #end
> #declare Y=1;
> #debug str(X,5,5)
> #debug "\n"
as I understend this solution means  function within function (via
parameter declaration) and it is very "expensive" as Thorsten wrote in
<3ba8bda3@news.povray.org>
but of course it is better than nothing
I want thank you all for parameters in functions
it is similiar to my propositions sended some time ago to p.u-p and I
like it very much
ABX
