POV-Ray : Newsgroups : povray.beta-test : 'bug' report from "Mahalis" <donttrythis@fakey.com> Server Time
2 Nov 2024 13:20:02 EDT (-0400)
  'bug' report from "Mahalis" <donttrythis@fakey.com> (Message 1 to 1 of 1)
Subject: 'bug' report from "Mahalis" <donttrythis@fakey.com>
Date: 30 Nov 2001 10:26:06
Message: <s19f0u4jbsngbi2bqvkilvnlvd565cou3k@4ax.com>
(the following was posted incorrectly to povray.bugreports)
Alan
ako### [at] povrayorg
a k o n g <at> p o v r a y <dot> o r g
To: bug### [at] povrayorg
Subject: Very wierd bug
Date: Fri, 30 Nov 2001 06:35:34 -0500
I' not sure exactly what I do to make this pop up, but when I'm editing a
file, the Start menu pops up and down and then, if I have the new version of
Windows Explorer open, the mouse is reversed- only in Windows Explorer. I
can't be absolutely positive 3.5 is causing it, bt I never had that problem
with 3.1.
POV-Team: Great piece of software, whatever bugs there may be. Keep op de
goot woik!
//Mahalis
camera{location<0,0.25,-2> look_at 0.5*y} #declare T=texture{pigment{crackle
scale 0.5 rotate 90 turbulence 0.75 color_map{[0 rgb 1][0.05 rgb 1][0.1
rgb<1,0.25,1>][0.25 rgbf 1][1 rgbf 1]}} finish{ambient 1}} #declare
c=difference{torus{0.5,0.1 rotate -90*x}box{<0.7,0,0.2>,<-0.7,-0.7,-0.2>}}
merge{object{c translate<0.5,0.5,0>} object{c translate<-0.5,0.5,0>}
cylinder{<1,0.5,0>,<1,0,0>,0.1} cylinder{<-1,0.5,0>,<-1,0,0>,0.1}
cylinder{0.5*y,0,0.1} texture{T}}
