POV-Ray : Newsgroups : povray.beta-test : [doc] language basics in quick ref Server Time
10 Apr 2026 21:44:26 EDT (-0400)
  [doc] language basics in quick ref (Message 1 to 7 of 7)
Subject: [doc] language basics in quick ref
Date: 12 Mar 2002 07:22:59
Message: <mspr8uggk6rr2ifipn9r6o8dfgkp7emqi6@4ax.com>
POV 3.5 b 12 for Win
10.1.3.1  Floats
  says that NUMERIC_EXPRESSION can be VECTOR.DOT_ITEM
  where DOT_ITEM is x|y|z|t|u|v|red|green|blue|filter|transmit|gray|hf
  while #warning str(<1,2,3,4,5>.hf,0,-1) works for all dot items except hf
  (I suppose .hf is valid only inside user defined functions)
10.1.3.4  User defined Functions
  min(FLOAT, FLOAT), max( FLOAT, FLOAT )
  should be probably something like
  min(FLOAT, FLOAT ...), max( FLOAT, FLOAT ...)
  going follow syntax identifiers I can't find how to prepare function
  with object pattern
  going follow syntax idnetifiers I can't find combination to allow
  function { pattern { brick turbulence 1 } } or
  function{ pattern{ agate warp{repeat x } } } (afaik both are valid)
ABX
Subject: Re: [doc] language basics in quick ref
Date: 12 Mar 2002 21:14:23
Message: <3c8eb5ff@news.povray.org>
NOTE:  My changes are to the Quick Reference found at my web site,
http://www.donovansweb.com/~chaffe/quickref.html .
I believe someone with the moniker "ingo" is in charge of modifying the
distributed documentation.  ;-)
news:mspr8uggk6rr2ifipn9r6o8dfgkp7emqi6@4ax.com...
> 10.1.3.1  Floats
hf
I have added one of my peach colored notes below the DOT_ITEM syntax:
    The  hf  item may be used only in a user-defined function.
Tsk, tsk.  Copy-Paste error.  In the FN_FLOAT_FUNCTION list I now have:
    max (FN_FLOAT,FN_FLOAT[,FN_FLOAT]...) | min
Note that I use FN_FLOAT to distinguish it from the other FLOAT that is not
quite the same as the one for user-defined functions.
>   with object pattern
Didn't know we could use it.  See modifications below.
Well, I didn't know that either.  I have changed the FLOAT_USER_FUNCTION
syntax, the pattern part, to the following:
    function { pattern { PATTERN [PATTERN_MODIFIERS] } }
I have also modified the PATTERN syntax to look like this:
    MAP_PATTERN  |  brick [BRICK_ITEMS]  |  checker  |  hexagon  |  object
{ LIST_OBJECT }
The same change was made to the appropriate BITMAP_IMAGE items.  That would
be in section 10.1.10.8 Pattern Modifiers in the docu.
Thanks for finding these.  Let me know if anything else needs to be
corrected.
Robert Chaffe
Date: 13 Mar 2002 01:03:13
Message: <Xns91D0481C9FEFAseed7@povray.org>
I'll pick them up from your site,
Thanks Robert,
Ingo
Date: 13 Mar 2002 05:08:25
Message: <vf8u8uon70doq2f87t8d259nv1ppmi9ng7@4ax.com>
On Tue, 12 Mar 2002 20:15:21 -0600, "Robert Chaffe"
I believe this to :-)
> > 10.1.3.1  Floats
This is not end of the problem. AFAIK .x .y .z and rest of operators cannot be
used on typical vector expression inside user defined function. So my
proposition is something like this:
in Float Expressions:
NUMERIC_EXPRESSION: (....) | VECTOR.DOT_ITEM | (....)
DOT_ITEM: x|y|z|t|u|v|red|green|blue|filter|transmit|gray (hf excluded)
in User-Defined Functions:
EXPRESSION: (....) | VECTOR_FUNCTION_INVOCATION.FN_DOT_ITEM |
COLOR_FUNCTION_INVOCATION.FN_DOT_ITEM | (...)
FN_DOT_ITEM: DOT_ITEM | hf
To the team - is this corect ?
Yes, I noticed this, just typing mistake :-)
That is probably becouse conventional syntax frame is rather ascetic in this
matter.
> corrected.
I plan to validate one subchapter of your quick ref per day. For example
"language directives" issues will be send after moment.
ABX
Date: 13 Mar 2002 06:34:43
Message: <3c8f3953@news.povray.org>
I think so.
    Thorsten
e-mail: tho### [at] trfde
Date: 13 Mar 2002 21:30:23
Message: <3c900b3f@news.povray.org>
> > > 10.1.3.1  Floats
I like that better anyway.  In the Float Expressions section I have removed the  hf
from DOT_ITEM and removed my item note.
The EXPRESSION in the User-Defined Functions section has been modified as suggested
above, and the new FN_DOT_ITEM has been
added as well.
Robert Chaffe
Date: 14 Mar 2002 06:25:47
Message: <aev09us85o1i12dpi64gepufahnam6rd5q@4ax.com>
On Wed, 13 Mar 2002 20:31:21 -0600, "Robert Chaffe"
> added as well.
I have verified this with script and it seems correct as Thorsten said.
#include "functions.inc"
#macro f()
  V #if(params) (a,a,a) #end
#macro F(V,params)
  #local Fx        = function(a){ f() .x        };
  #local Fy        = function(a){ f() .y        };
  #local Fz        = function(a){ f() .z        };
  #local Ft        = function(a){ f() .t        };
  #local Fu        = function(a){ f() .u        };
  #local Fv        = function(a){ f() .v        };
  #local Fred      = function(a){ f() .red      };
  #local Fgreen    = function(a){ f() .green    };
  #local Fblue     = function(a){ f() .blue     };
  #local Ffilter   = function(a){ f() .filter   };
  #local Ftransmit = function(a){ f() .transmit };
  #local Fhf       = function(a){ f() .hf       };
F(1,no)                             // float     - all returns parse error
F(x,no)                             // vector    - all returns parse error
F(red 1,no)                         // color     - all returns parse error
F(function{f_agate(x,y,z)},yes)     // fn_float  - all returns parse error
F(function{transform{scale 1}},yes) // fn_vector - all work fine
F(function{pigment{agate}},yes)     // fn_color  - all work fine
ABX
disc{z,-z 5#macro O()asc(substr("-+((1*(,1,/.-,*/(,&.323/'1"e,1))*.1-4#declare
e=e-1;#end#local e=26;pigment{#local g=function(_){ceil(_)-_}function#local//X
k=function{pattern{object{sphere_sweep{linear_spline 13#while(e>0)<O(),O()//AB
>.01#end}}}}{k(g(atan2(x,y)),g(ln((y+x)^2+1e-5)),0)}}finish{ambient 1}}//POV35
