POV-Ray : Newsgroups : povray.beta-test : [win] "cpu time used" not works properly Server Time
18 Feb 2026 08:55:02 EST (-0500)
  [win] "cpu time used" not works properly (Message 1 to 2 of 2)
Subject: [win] "cpu time used" not works properly
Date: 15 Jan 2002 10:51:47
Message: <llj84uk2findr74u9jpge6dlteqf19c70o@4ax.com>
POV 3.5 b 10.icl on PII 233 128 MB with NT 4 Sp 6
CPU time in stream was mentioned in changes but seems not work properly. I
started rendering of my sig with "+GAout.txt". Rendering is finished properly,
CPU time was displayed in Message Window but no CPU time in out.txt. But when I
make User Abort (with Stop button) during rendering then CPU time is outputed in
both - Message Window and stream out.txt. Any confirmation ?
ABX
disc{z,-z 5#macro O()asc(substr("-+((1*(,1,/.-,*/(,&.323/'1"e,1))*.1-4#declare
e=e-1;#end#local e=26;pigment{#local g=function(_){ceil(_)-_}function#local//X
k=function{pattern{object{sphere_sweep{linear_spline 13#while(e>0)<O(),O()//AB
>.01#end}}}}{k(g(atan2(x,y)),g(ln((y+x)^2+1e-5)),0)}}finish{ambient 1}}//POV35
Subject: Re: [win] "cpu time used" not works properly
Date: 15 Jan 2002 11:08:09
Message: <3c4453e9@news.povray.org>
> I make User Abort (with Stop button) during rendering then CPU time is
> outputed in both - Message Window and stream out.txt. Any confirmation ?
I cannot confirm it, but it should logical as the platform specific code
gets back control only after the output streams have been closed.  Premature
termination however is initiated by the platform specific code and thus it
can output the information early enough. If what you report is correct, such
code probably needs a new hook in the core code to be able to work as
expected...
    Thorsten
e-mail: tho### [at] trfde
