Subject: Re: Can POV make use of 48 bpp color images as detailed height fields?
Date: 12 Oct 2001 18:47:48
Message: <3bc77314@news.povray.org>
In article <3bc7683b@news.povray.org> , Warp <war### [at] tag povray org> wrote:
> I must confess that I don't understand the logic behind the current
> behaviour. Wouldn't it be more logical to just convert the color to b/w and
> take that as height?
I think there are good arguments for and against both ways.
I think the "normal" way to create a hfield is to take some image and
process it with either a special program or photo editor to get the desired
look. In both cases one would expect the export of a grayscale image. No
human can reliably comprehend how a rgb-image will look like when it is
converted to grayscale without seeing the result. So this task is best done
in a program. POV-Ray allows you to even work with programs that don't
support grayscale images in an easy way by using just one component of a
color image without having to consider a possibly complicated color to
grayscale conversion.
Then there is the less frequent and less useful (I guess) use of a color
photo or something similar as a hfield. In this case the optimal solution
would be to do a good grayscale conversion of the color information.
I don't use hfields (or POV-Ray) a lot, and I actually don't have a problem
with either way. If there are more requests to make it convert to grayscale
for 16-bit per color component images, I would be happy to do so...
Thorsten
e-mail: tho### [at] trf de
in news:3bc75cdc$1@news.povray.org Thorsten Froehlich wrote:
> No, with the exception of JPEG all non-indexed color image formats
> will be used as red-green hfields
I'll add this to the docs.
Ingo
Pov-Ray : http://members.home.nl/seed7/
Date: 13 Oct 2001 04:22:20
Message: <3bc7f9bc@news.povray.org>
Thorsten Froehlich <tho### [at] trf de> wrote:
: I don't use hfields (or POV-Ray) a lot, and I actually don't have a problem
: with either way. If there are more requests to make it convert to grayscale
: for 16-bit per color component images, I would be happy to do so...
I don't think that the current behaviour is that problematic. I think that
the biggest problem is that this behaviour is not clearly documented. I have
read the heightfield documentation countless times during these years, and I
never realized this behaviour.
Of course I can't speak for anyone else, but it seems to me that the user
(well, in this case me) gets the impression that this kind of b/w conversion
must be done when creating the heightfield... I don't know where did I get
that impression, but that's what I thought. I think that the documentation
lacks a clear and unambiguous description of the exact algorithm used for
the pixel to height conversion with true color images (what happens with
indexed images is a lot better documented).
Perhaps a more visible note about this conversion could be added with some
examples of useful usages of this feature.
On the other hand, I wouldn't mind that the b/w conversion would be used
to create the heightfield from the image. Note that this way you get *more*
than 256 heights, which makes the heightfield more accurate even with 24-bit
images.
7382340,3358,3900569407,970,4254934330},0)}// - Warp -
Date: 13 Oct 2001 06:34:53
Message: <3BC818CD.D24B90D3@free.fr>
Well, I have. But I also read the Fractint documentation,
who also used "16 out of 24 bits" formats, so I easily
understood what POV was doing.
I am not sure that if you convert 24-bit to greyscale
you will get 16-bit precision : I would say 8-bit, but I'm
not at all into this field, so I'm not sure at all.
Something inbetween perhaps.
Indexed color : the number of the color in the index
is used to determine the height. 8-bit and 16-bit indexes
are accepted and used by POV. 16-bit indexes are mostly/only?
supported by PNG file format.
True color : the red and green components are combined to
form a 16-bit value. This dates back from days where no
file format supported 16-bit palettes or 16-bit B&W.
Fractint introduced this hack, and it has been kept. Of
course, it is almost impossible to draw them by hand (or
you do a B&W picture, but only get 8-bit precision), you
should use a special program for that. afaik, hflab can
output such format.
> images.
I'm a bit confused about the issue of B&W conversion. Are you
sure you will have more than 8-bit precision in that case?
Adrien Beau adr### [at] free fr http://adrien.beau.free.fr/
Date: 13 Oct 2001 06:56:55
Message: <3bc81df7@news.povray.org>
Adrien Beau <adr### [at] free fr> wrote:
: I am not sure that if you convert 24-bit to greyscale
: you will get 16-bit precision : I would say 8-bit, but I'm
: not at all into this field, so I'm not sure at all.
When you convert an image to b/w (and save it to a true-color 24-bit
format) you get exactly 256 different shades of gray. POV-Ray can only
create 256 heights from them.
Using red+green as a 16-bit value for the height is a good idea, but not
very practical. No image editing programs support that, so you just can't
create them. AFAIK there are only two widespread programs which support
this: POV-Ray and fracting. This isn't enough because neither is an image
editing program.
Nowadays this red+green idea is also obsolete because we can use a 16-bit
b/w PNG to achieve the same thing, and this is a lot more supported (besides
being a lot more logical).
: I'm a bit confused about the issue of B&W conversion. Are you
: sure you will have more than 8-bit precision in that case?
Yes. You get approximately 3 times more accuracy.
There's a big difference between converting an image first to b/w and
then feeding the result to POV-Ray and feeding the original color image
and letting POV-Ray do the b/w conversion. The difference is that when
you do the b/w conversion yourself and save to an image format, you are
actually *clamping* the fraction values from the result, thus destroying
accuracy.
Suppose that a simple average is used to make the b/w-conversion. This
table shows what I mean:
Original B/W value What actually gets
rgb values (which pov could use) written to an image file
0,0,0 0 0
1,0,0 1/3 0
1,1,0 2/3 1
1,1,1 1 1
2,1,1 4/3 1
2,2,1 5/3 2
2,2,2 2 2
etc.
(Note that the order of the example rgb values above doesn't matter.)
If we let POV-Ray do the b/w-conversion, then it can use 3 times more
accuracy than if we save to b/w-converted image to a file and give that
to POV-Ray.
Date: 13 Oct 2001 08:33:42
Message: <3BC834A5.CF2BA150@gmx.de>
> editing program.
I would not say it's obsolete, apart from the reason that it's quite
simple to program TGA output, it's also possible to edit those formats
with a paint program which does not apply for 16 bit png. You can resize
it (without interpolation of course) cut out a subsection of the image,
mirror it, etc.
Christoph Hormann <chr### [at] gmx de>
Date: 13 Oct 2001 09:03:56
Message: <3bc83bbc@news.povray.org>
Christoph Hormann <chr### [at] gmx de> wrote:
: I would not say it's obsolete, apart from the reason that it's quite
: simple to program TGA output, it's also possible to edit those formats
: with a paint program which does not apply for 16 bit png. You can resize
: it (without interpolation of course) cut out a subsection of the image,
: mirror it, etc.
But forget about making any real changes to the image, like smoothing,
sharpening, etc... :)
Date: 13 Oct 2001 09:11:03
Message: <3BC83D92.EE811D94@free.fr>
> editing program.
IIRC, hf-lab and the like can do that. Not that I'm a
supporter of 16-bit coded as red+green. We all agree
that PNG is now a better choice.
I thank you for the explanation.
Date: 17 Oct 2001 23:58:29
Message: <3bce5365@news.povray.org>
-Hail
If you study how the F().gray works for the isosurface you will see that
that is a far better way to make heightfields.
Date: 18 Oct 2001 04:11:03
Message: <3BCE8EA4.612F80CC@gmx.de>
Far better than what?
The red/green channel tga has - as mentioned - historical reasons. Your
suggestion would allow higher vertical resolution than 16 bit, but this is
hardly necessary and would be difficult from the programming perspective
(the program generating such a HF would certainly use 32 bit values for
internal calculations)
