POV-Ray : Newsgroups : povray.beta-test : function declaration and namespace Server Time
19 Nov 2025 05:37:30 EST (-0500)
  function declaration and namespace (Message 1 to 10 of 12)
Subject: function declaration and namespace
Date: 7 Jan 2002 02:27:37
Message: <l2ji3uc2k9su99o2gct3n2thgqoq7f4pd5@4ax.com>
POV 3.5 b 9.icl on PII 233 128 MB with NT 4 Sp 6
POV 3.5 b 9.icl on PII 233 128 MB with Win95 OSR2
below script stops at header of macro with message
"Expected 'identifier or expression.', function_id found instead"
#local F=function{x}
#macro P(F) #end
ABX
Subject: Re: function declaration and namespace
Date: 7 Jan 2002 07:15:35
Message: <3c399167@news.povray.org>
> #macro P(F) #end
Works as it should.  Please refer to the documentation.
    Thorsten
e-mail: tho### [at] trfde
Date: 7 Jan 2002 07:27:35
Message: <sj4j3ucmp9do8nlr46a56cf09bu95jrh6m@4ax.com>
On Mon, 07 Jan 2002 13:15:30 +0100, "Thorsten Froehlich" <tho### [at] trfde>
> > #macro P(F) #end
6.2.8.1: "PARAM_IDENTs are a list of zero or more formal parameter identifiers
separated by commas and enclosed by parentheses".
F is formal in local namespace of macro P for me and should works just like
below script:
#macro P(C) #local F=C; #end
P(1)
Is there any other place in documentation where it is precised ?
ABX
Date: 7 Jan 2002 07:32:20
Message: <3c399554@news.povray.org>
> below script:
> P(1)
6.1.6.1 Functions and Macros
Date: 7 Jan 2002 07:35:24
Message: <4d5j3ukkckm30bsj12n0i72i04uhgmmkrt@4ax.com>
On Mon, 07 Jan 2002 13:32:17 +0100, "Thorsten Froehlich" <tho### [at] trfde>
but it is about calling macro,
I'm talking about declaring
ABX
Date: 7 Jan 2002 07:39:55
Message: <3c39971b$1@news.povray.org>
    Thorsten
Date: 7 Jan 2002 07:47:47
Message: <ps5j3u42jdj85v0jfr3jeaj8e2i2vn3qsa@4ax.com>
On Mon, 07 Jan 2002 13:39:55 +0100, "Thorsten Froehlich" <tho### [at] trfde>
wrote:
here is list of cases from 6.1.6.1.
"You can use macros in functions, but the macros will be called only once when
the function is defined, not every time the function is called."
This is not my case becouse I'm not declaring function.
"You cannot pass function variables to the macros."
This is not my case becouse I'm not calling macro and therefore no parameters
are passed.
"You can pass functions to macros, how to do this is best explained by an
example."
As above.
I'm declaring.
This is parsed ok:
#macro P(F) #end
and this not:
#macro P(F) #end
The only difference is the order of lines.
ABX
Date: 7 Jan 2002 08:18:10
Message: <3c39a012@news.povray.org>
> This is parsed ok:
> #macro P(F) #end
> and this not:
> #macro P(F) #end
Ah, now I see.  I missed that it wasn't a macro call.  I am not sure what it
is then.
    Thorsten
Date: 7 Jan 2002 08:20:29
Message: <c28j3uod9ldtp8bo2cf8fq1t5p9ugdddq1@4ax.com>
On Mon, 07 Jan 2002 14:18:08 +0100, "Thorsten Froehlich" <tho### [at] trfde>
Now I'm happy it's not my English again :-)
ABX
Date: 7 Jan 2002 09:23:57
Message: <3c39af7d@news.povray.org>
The difference is not only the order of lines, but in the last case "F" in
known as function name
in current block, so POV is correct, reporting an error..
If we put " #local F=" inside e.g. a macro block, like below, it works OK
 #macro  M(F)
 #macro P(F) #end
 6.2.2.2  #declare vs. #local
 Use of #local in the main scene file (not in an include file and not in a
macro)
  is identical to #declare.
  For clarity sake you should not use #local in a main file except in a
macro.
atb,
gleb
"W?odzimierz ABX Skiba" <abx### [at] babilonorg> wrote in message
news:ps5j3u42jdj85v0jfr3jeaj8e2i2vn3qsa@4ax.com...
> This is parsed ok:
> #macro P(F) #end
> and this not:
> #macro P(F) #end
> ABX
