POV-Ray : Newsgroups : povray.beta-test : problem with value of local parameter/variable Server Time
14 Dec 2025 18:49:14 EST (-0500)
  problem with value of local parameter/variable (Message 1 to 2 of 2)
Subject: problem with value of local parameter/variable
Date: 15 Feb 2002 10:41:45
Message: <ja9q6us8gv2phn0dgr4t7jnqjtovvkpv0c@4ax.com>
POV 3.5 b 11 icl on WinNT Sp 6 PII 233 with 128 MB
Below example use macro kerning() from
http://news.povray.org/sa6q6u8ic6tt2ntql1kt4mm2fiebtf1pih%404ax.com.
The problem is:
1. start below script - it outputs <0,0,0> vector in message window
2. change Position at and of vletter macro to (Position) <- added parentheses
    it outputs <3.5,0,0>
3. undo parantheses and remove first or second line of kerning macro
    again <3.5,0,0> in output
3. undo removed line in above change and change warning to:
    #warning Str(vletter("crystal.ttf","POV",0,3).x)
4. remove included "strings" and change warning to:
    #warning str(vletter("crystal.ttf","POV",0,3).x,0,-1)
Could it be somehow releted to direct returning locals?
I though it was fixed in some beta. Any confirmation ?
//START
#macro kerning(Font,String,Thickness,Offset,Position)
  #local HelpText=text{ttf Font String Thickness 0};
  #local Text=HelpText;
  #local Text=<version,0,0>;
  Text
#macro vletter(Font,String,Offset,Position)
  #if(Position=1)
    #local Position=(0*x);
  #else
    #local Position=kerning(Font,String,0,Offset,Position);
  Position
#include "strings.inc"
#warning VStr(vletter("crystal.ttf","POV",0,3))
//END
ABX
Subject: Re: problem with value of local parameter/variable
Date: 15 Feb 2002 10:50:22
Message: <1fbq6ugkejd73282bniq5vtnpf0cgin2j0@4ax.com>
Now I see in Known bugs list. It is probably the same as job000146. Anyway
take it as testing example.
ABX
