POV-Ray : Newsgroups : povray.beta-test : bug: select within select Server Time
11 Apr 2026 20:07:24 EDT (-0400)
  bug: select within select (Message 1 to 10 of 15)
Subject: bug: select within select
Date: 1 Oct 2001 11:08:30
Message: <j60hrt43df8pu3ugq4hk6dvqqo4pod61rr@4ax.com>
POV 3.5b4 on PII233 128 MB with NT4Sp6
it looks like select inside select not work
look at the function
#local test=function{
        select(
          f_noise3d(floor(x),floor(y),0)-(1/3),
          0,
          select(
            f_noise3d(floor(y),floor(x),0)-(1/2),
            1,
            2
in my opionion it should evenly return 0, 1 and 2
but I have tested this 100.000 with differents seeds and random points
with script from the end of this post and it returned
0 - 0 times
1 - 64161 times
2 - 35839 times
anybody can confirm ?
here is script:
#local Count0=0;
#local Count1=0;
#local Count2=0;
#local MaxSeed=1000;
#local MinRand=-1000;
#local MaxRand=1000;
#local Loops=100;
#local CounterSeed=0;
#while(CounterSeed<MaxSeed)
  #local Seed=seed(CounterSeed);
  #local Counter=0;
  #while (Counter<Loops)
    #switch(test(
        Interpolate(rand(Seed),0,1,MinRand,MaxRand,0),
        0))
      #case(0)
        #local Count0=Count0+1;
        #break
      #case(1)
        #local Count1=Count1+1;
        #break
      #case(2)
        #local Count2=Count2+1;
        #break
      #else
        #error "unexpected"
    #local Counter=Counter+1;
  #local CounterSeed=CounterSeed+1;
ABX
Subject: Re: select within select
Date: 1 Oct 2001 12:29:07
Message: <3bb899d3$1@news.povray.org>
Well, for them to appear *evenly*, you would have to change the (1/2) to
(2/3). But it's a mystery to me as to why zero isn't appearing.
Just wanted to clarify that they shouldn't appear completely evenly.
- Slime
[ http://www.teja.nu/slime/ ]
[ http://www.teja.nu/slime/images/ ]
news:j60hrt43df8pu3ugq4hk6dvqqo4pod61rr@4ax.com...
>         select(
>           0,
>           select(
>             1,
>             2
> 0 - 0 times
> 1 - 64161 times
> 2 - 35839 times
> here is script:
> #local Count0=0;
> #local Count1=0;
> #local Count2=0;
> #local Loops=100;
>   #local Counter=0;
>     #switch(test(
>         0))
>       #case(0)
>         #break
>       #case(1)
>         #break
>       #case(2)
>         #break
>       #else
>         #error "unexpected"
>     #end
>   #end
> #end
> ABX
Subject: Re: bug: select within select
Date: 1 Oct 2001 12:36:12
Message: <3bb89b7c$1@news.povray.org>
>         select(
>           0,
>           select(
>             1,
>             2
> 0 - 0 times
> 1 - 64161 times
> 2 - 35839 times
Do you by any chance have a _simpler_ version of this function?  Or does it
require f_noise3d to show the problem or will any nested select show the
problem?
    Thorsten
Date: 1 Oct 2001 14:20:00
Message: <C5fbDCACOLu7EwXB@econym.demon.co.uk>
>        select(
>          0,
>          select(
>            1,
>            2
>0 - 0 times
>1 - 64161 times
>2 - 35839 times
I confirm the numbers, but I don't think it's anything to do with the
nesting of selects.
If you change to noise generator 1, the numbers come out even. It looks
to me like there's a subtlety in noise type 3 that causes
f_noise3d(integer, integer, 0) to always be greater than 1/3. I really
don't see that as being a problem because you shouldn't really expect
noise3d to be a random number generator.
[[But, does that actually mean that we don't have a decent random number
generator that we can use in a function? Rand() is not available inside
a function block.]]
Adding:
        global_settings{
          noise_generator 1
to your scene gives the results:
0 - 35946 times
1 - 32982 times
2 - 31072 times
Which indicates that the nested selects are working perfectly, and
noise_generator 1 does happen to partition (floor(x),floor(y),0) into
three roughly equal thirds.
If you do the same thing, with the default noise generator, but without
the "floor()"s, then the results are:-
        select(
          f_noise3d(x,y,0)-(1/3),
          0,
          select(
            f_noise3d(y,x,0)-(1/2),
            1,
            2
0 - 13007 times
1 - 45476 times
2 - 41517 times
By the way, since you seem to like using "Interpolate()", I guess that
you have some idea of what it's supposed to do and what the parameters
mean. Would it be possible for you to enlighten the rest of us? The docs
have a bit of a hole there.
Mike Williams
Gentleman of Leisure
Date: 1 Oct 2001 14:29:58
Message: <3bb8b626$1@news.povray.org>
In article <C5f### [at] econymdemoncouk> , Mike Williams
> nesting of selects.
Thank you for finding this!  So it is not a bug, but simply the wrong
noise_generator.  There has a lot been written about the old/default noise
generator's problems, and I guess this is one good example of them.
> a function block.]]
True, there is none because for such functions it would not be possible to
find the surface (it would be changing every time one calculates the value
at the same spot).
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 1 Oct 2001 20:26:41
Message: <CSbrJDAROQu7EwlA@econym.demon.co.uk>
>> nesting of selects.
It's the NEW noise generator that is exhibiting the strange behaviour at
integer coordinates. The old noise generator that behaves sensibly in
this respect.
2.6.1: The default generator, type 3, is a completely new Perlin noise
function. You can also choose noise_generator 1, which behaves like the
noise in POV-Ray 3.1 and earlier.
Mike Williams
Date: 22 Oct 2001 05:46:57
Message: <0mq7tt888pac9hsj5r5b4l4jatn5ooahi5@4ax.com>
On Mon, 1 Oct 2001 12:28:02 -0400, "Slime" <noo### [at] hotmailcom>
> (2/3).
I think you are wrong.
ABX
Date: 22 Oct 2001 05:54:18
Message: <s9p7ttk0cqadgpvrkjquu9r2c5tai77u6g@4ax.com>
On Mon, 1 Oct 2001 19:18:42 +0100, Mike Williams <mik### [at] nospamplease>
wrote:
> > 0 - 0 times
> > 1 - 64161 times
> > 2 - 35839 times
> nesting of selects.
Thanks for finding and pointing this.
I think there should be note withing documentation about
characteristic of noise generators.
> I really
I don't expect. They are just good to make "random but constant"
mosaics in textures/pigments. :-)
> 0 - 13007 times
> 1 - 45476 times
> 2 - 41517 times
they are similiar to noise_generator 2 with floor() for args
sorry. it's macro from standard "math.inc"
ABX
Date: 22 Oct 2001 08:37:06
Message: <Xns914294B46DB06seed7@povray.org>
What kind of characteristics do you mean and what are they.
I posted two images in p.b-t.b with histograms, is this sufficient?
Ingo
Date: 22 Oct 2001 10:05:20
Message: <fs98ttg2cuuk2484bbl2su4vmgljvjoqkl@4ax.com>
On 22 Oct 2001 08:37:06 -0400, ingo <ing### [at] homenl> wrote:
> in news:s9p7ttk0cqadgpvrkjquu9r2c5tai77u6g@4ax.com W?odzimierz ABX
I'm talking about few words about results for some special args. As
this thread shows one sentence can be: "for integer args generator 3
returns only values above 1/3." Without sources I can't give more
examples - I found only this by experience. Perhaps something like
this occure for some generators:
noise(x,0,0)=noise(0,x,0)=noise(0,0,x). Or : noise(x,y,0)=noise(y,x,0)
I though about characteristic as description. Such images have sense
only in small range. And are usfull when such range is repeated over
and over. But perhaps your images could be usefull for others.
ABX
