POV-Ray : Newsgroups : povray.beta-test : bug: select within select Server Time
13 Mar 2026 03:03:16 EDT (-0400)
  bug: select within select (Message 11 to 15 of 15)
Subject: Re: select within select
Date: 22 Oct 2001 12:14:26
Message: <3bd445e2$1@news.povray.org>
Unfortunately, Outlook Express seems to delete old messages and I can't
figure out how to make it *stop* doing that, so I don't really remember the
original post that this applied to. However, if I remember correctly, I
think it was a matter of splitting it up into thirds, and what was being
done was someone was testing if a number between zero and one was less than
1/3, and then if it was less than 1/2. I figured it should be 1/3 and then
2/3, to split it up evenly. But I don't really remember or care enough to
argue the point anymore. =)
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
news:0mq7tt888pac9hsj5r5b4l4jatn5ooahi5@4ax.com...
> On Mon, 1 Oct 2001 12:28:02 -0400, "Slime" <noo### [at] hotmailcom>
> wrote:
> > Well, for them to appear *evenly*, you would have to change the (1/2) to
> > (2/3).
> I think you are wrong.
> ABX
Subject: Re: bug: select within select
Date: 22 Oct 2001 13:55:37
Message: <tnrwELA$jF17EwKG@econym.demon.co.uk>
>On Mon, 1 Oct 2001 19:18:42 +0100, Mike Williams <mik### [at] nospamplease>
>wrote:
>> By the way, since you seem to like using "Interpolate()", I guess
>> that you have some idea of what it's supposed to do and what the
>> parameters mean. Would it be possible for you to enlighten the rest
>> of us? The docs have a bit of a hole there.
>sorry. it's macro from standard "math.inc"
I knew that, but the documentation says
"Interpolate(GC, GS, GE, TS, TE, Method). Interpolation macro...can
someone explain this one?"
The comments in math.inc aren't helpful either, but you seemed to be
using it as if you had some idea what the parameters were for. The rest
of us are rather in the dark.
Mike Williams
Gentleman of Leisure
Date: 23 Oct 2001 01:47:44
Message: <3bd50480@news.povray.org>
"Slime" <noo### [at] hotmailcom> wrote in message
news:3bd445e2$1@news.povray.org...
the
Have a look in povray.announce.frequently-asked-questions. The most recent
post there is about Outlook express settings.
Gail
* gsh### [at] monotixcoza                *   Step into the abyss,           *
* http://www.rucus.ru.ac.za/~gail/   *   and let go.          Babylon 5 *
* Just think of me as the storm before the calm     Magic: The Gathering*
Date: 23 Oct 2001 06:54:41
Message: <jhhatt859rt4tadigbrfptpgt0u0g2sv4r@4ax.com>
On Mon, 22 Oct 2001 18:35:59 +0100, Mike Williams <mik### [at] nospamplease>
Well, I missed note from doc and get it only with content of include
file. It looks very simple to me and I can explain a little. This
macro gets value (first arg) from range <global_start,global_end>.
Than it makes calculations to put it into another range
<target_start,target_end>. The way how it calculate depends on last
argument called Method. For Method=0 characteristic of calculation
looks like part of sinusoid. For Method=1 it simple linear
calculation. For Method>0 it goes with exponent.
Sample of use: Looking for smooth movement from one point to another
for animations you need only one line.
Result=Interpolate(clock,initial_clock,final_clock,StartPoint,EndPoint,0)
I suppose it is designed as macro (I think slower) becouse function
forbids use it with vectors and colors for target range.
To show characteristic of interpolations I made sample file I'll post
after moment to p.b-t.binaries. Feel free to use its output within doc
or as sample file or merge it with math.pov from incdemo.
ABX
Date: 24 Oct 2001 09:18:41
Message: <j3fdtt89eelodnvdrul19qgeoii6n13fbg@4ax.com>
On Mon, 22 Oct 2001 12:12:43 -0400, "Slime" <noo### [at] hotmailcom>
http://news.povray.org/povray.beta-test/18823/
But I can't stay when you are wrong. My english is not enough to
explain but take this script for proof. It takes _two_ random values
just like original script. I don't know how to set up "follow-up" in
my newsreader but change group if you want talk about this problem.
#include "stdinc.inc"
#local test=function(A,B){select(A-(1/3),0,select(B-(1/2),1,2))}
#local Count=array[3]{0,0,0};
#local Seed=0;
#local Counter=0;
#while(Counter<10000)
  #local Result=test(rand(Seed),rand(Seed));
  #local Count[Result]=Count[Result]+1;
  #local Counter=Counter+1;
#warning Str(Count[0])
#warning Str(Count[1])
#warning Str(Count[2])
ABX
