POV-Ray : Newsgroups : povray.beta-test : strange concatenation rules Server Time
7 Mar 2026 12:45:22 EST (-0500)
  strange concatenation rules (Message 1 to 8 of 8)
Subject: strange concatenation rules
Date: 24 Sep 2001 05:21:17
Message: <h9utqt0r7aer5md5md2ge3kpu39131k51e@4ax.com>
POV3.5b4 on NT4 PII233 128MB
Please parse below and look at the output where it stops and what is
the output. I didn't found anything within 6.1.7.1 and 6.1.7.3 what
could explain this
  #declare String=concat("1","2","3")
  #warning String
  #declare String=concat("1" "2" "3")
  #warning String
  #declare String=concat("1" "2","3")
  #warning String
  #declare String=concat("1""2""3")
  #warning String
  #declare String=concat("1" "2")
  #warning String
to compare result here is my output
  File: C:\tests\test.pov  Line: 4
  Warning: 123
  File: C:\tests\test.pov  Line: 7
  Warning: 13
  File: C:\tests\test.pov  Line: 10
  Warning: 13
  File: C:\tests\test.pov  Line: 13
  Warning: 13
  File: C:\tests\test.pov  Line: 15
  #declare String=concat("1" "2") <----ERROR
  Parse Error: Expected 'string expression', ) found instead
ABX
Subject: Re: strange concatenation rules
Date: 24 Sep 2001 09:39:21
Message: <3baf3789@news.povray.org>
news:h9utqt0r7aer5md5md2ge3kpu39131k51e@4ax.com...
> could explain this
I don't see a problem, you just need to use comma separation.  concat() is
obviously ignoring the quotes when without commas which turns the "2" into
nothing seen.  So that error of the last example is seeing just a 1 with
nothing to concatenate onto it.
Looking at the Scene Help I don't see an example without commas.
Bob H.
Date: 24 Sep 2001 10:06:30
Message: <rvduqtkorh4jdp1a548pf7ruqaqg4t4mtm@4ax.com>
On Mon, 24 Sep 2001 08:39:18 -0500, "Bob H." <omn### [at] msncom>
wrote:
> "W?odzimierz ABX Skiba" <abx### [at] babilonorg> wrote in message
> > could explain this
but I see the problem
I found this playing with Parse_String macro
I just generated macro with it this way for example
Parse_String(concat(
  "#macro Name(Params)",
    :   // here are lines with content of macro
  "#end"
and sometimes I forgot to add comma after lines of string
and it was parsed ok during concatenation but during Parse_String it
behave  unexpected
I found that it lost some lines
I don't think there must be possibility to not use comma
I just think there should be at least warning that comma required
> concat() is
I don't say about last line but about all without first !!!
Question is: why it wasn't reported during parse ? Second string
(without comma) is always invisible. Third is visible.
Perhaps I missed something but have you seen example without commas
for sphere{x 1} or triangle{x y z} ?
ABX
Date: 24 Sep 2001 13:11:01
Message: <3baf6925@news.povray.org>
news:rvduqtkorh4jdp1a548pf7ruqaqg4t4mtm@4ax.com...
>   "#end"
> behave  unexpected
Yes, I agree.
> > concat() is
into
I knew that :-) I only pointed out the last example because it kind of
explained the others.
But those are not strings.  You're dealing with quotes, and a pair of double
quotes must be confusing the parser since it can't decide where the end will
be unless it's the last one seen around a group of characters.
If you wanted a string like """"" you'd do "\"\"\"\"\""
I certainly see your point about the warning being needed for paired quotes.
Seems to me this was a topic I remember from long ago.  If you had a empty
string, for whatever reason, then how would POV know to warn or not?  Except
to warn about any and all such instances...
Hmm, well, maybe like have POV see the first quote and check for closing
quote for only paired off ones.  That way it would move on to the next pair.
Bob H.
Date: 24 Sep 2001 14:36:34
Message: <slrn9quv9k.p48.ron.parker@fwi.com>
>could explain this
This was a bug in the parser.  It'll be fixed in a future beta.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbf 1}hollow interior{media{emission 3-T}}}#end
Z(-x-x.2x)camera{location z*-10rotate x*90normal{bumps.02scale.05}}
Date: 24 Sep 2001 14:42:08
Message: <slrn9quvk2.p48.ron.parker@fwi.com>
>> could explain this
Commas are supposed to be optional just about everywhere, including here.
Also, it works if you type 'concat("1")' which doesn't make sense if you
go by the reasoning you've proposed.
What was happening was much more complicated, but essentially POV was throwing
away every second token inside the parentheses, but with some additional
caveats that made it unable to parse the example with two parameters.  This
will be fixed in an upcoming beta. (and, more importantly, it is NOT a
documentation bug, so no need to say anything about commas being required.)
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
Date: 24 Sep 2001 15:15:52
Message: <3baf8668@news.povray.org>
"Ron Parker" <ron### [at] povrayorg> wrote in message
news:slr### [at] fwicom...
is
into
Thanks for the dose of wisdom.  I figured concat had to glue at least two
strings together, had never questioned whether it did or not.  Likewise
about commas, I'm a comma user.
Bob H.
throwing
This
required.)
Date: 25 Sep 2001 03:27:58
Message: <iac0rtg5p18cg45vcnjbt7viv25orth5rp@4ax.com>
On 24 Sep 2001 14:42:08 -0400, ron### [at] povrayorg (Ron Parker)
but first sentence causes documentation or parser bug
becouse there is sentence "Must have at least 2 parameters but may
have more" about concat within 6.1.7.3
ABX
