POV-Ray : Newsgroups : povray.beta-test : can't create function{spline{}} Server Time
10 Apr 2026 14:20:48 EDT (-0400)
  can't create function{spline{}} (Message 1 to 10 of 10)
Subject: can't create function{spline{}}
Date: 20 May 2002 04:32:46
Message: <h1dheusbdk95qsegakbrqieki4s60gf64k@4ax.com>
POV 3.5 RC5 icl on WinNT Sp 6 PII 233 with 128 MB
Following code not works with RC5. It worked with RC4.
#macro Time_To_Length_Converter(Spline,Min,Max,Accuracy)
  #local Conversion=function{spline{
    #local Last=Spline(Min);
    #local Length=0;
    #local C=Min;
    #while (C<=Max)
      #local C=min(C,Max);
      #local Point=Spline(C);
      #local Length=Length+vlength(Point-Last);
      C , Length
      #local C=C+Accuracy;
#local S=spline{-1 x 0 y 1 z 2 0};
Time_To_Length_Converter(S,0,1,.001)
ABX
Subject: Re: can't create function{spline{}}
Date: 20 May 2002 05:14:33
Message: <3ce8be79@news.povray.org>
Yes, as mentioned in another thread you might recall that declaring has been
disallowed in functions to fix a problem you had with it.
Looking at this code doing so might go a bit too far.  I will see if there are
better solutions...
    Thorsten
e-mail: tho### [at] trfde
Date: 20 May 2002 06:39:23
Message: <h8kheucgt04venggn0gk6j1t0miqgk8ehb@4ax.com>
On Mon, 20 May 2002 11:14:30 +0200, "Thorsten Froehlich" <tho### [at] trfde>
You mean ANY declaration inside function is forbidden now ? In this case I
prefer work with that crash I reported than with such "awful" limitation :-(
> better solutions...
Please, find it... (is it feature request ?)
ABX
Date: 20 May 2002 06:54:57
Message: <falheugtkrhj9vt19rj05c7d0c249426nc@4ax.com>
>better solutions...
Probably for the same reason I can't use such construction:
  #local fn_T=function { Reorient_Trans( Axis, x) }
which is basic construction in iso_csg library. Wasting identifiers and time
for assigments is not very good solution :-(
ABX
Date: 20 May 2002 07:11:07
Message: <3ce8d9cb@news.povray.org>
been
I haven't followed this in detail, but I noticed that in the last post, it
was a problem with declaring a *function* inside a function. Of course, I
don't know how pov-ray deals with this stuff internally, but perhaps merely
saying "you can't declare a function within another function being declared"
might fix it, instead of limiting *all* types of declarations?
 - Slime
[ http://www.slimeland.com/ ]
Date: 20 May 2002 09:12:40
Message: <3ce8f648@news.povray.org>
are
>> better solutions...
No, not a feature request because it is simply an alternate bug fix.  I found
a solution that works and should even allow functions to be declared inside
functions (also I won't guarantee that will work before running more tests).
    Thorsten
Date: 10 Jun 2002 06:12:43
Message: <bnu8gukrjdsdhc9f0e22ve04854rhd73pb@4ax.com>
On Mon, 20 May 2002 15:12:37 +0200, "Thorsten Froehlich" <tho### [at] trfde>
> > > better solutions...
Bad news: code mentioned in 9m89euo7sj6mvsns96cg47daa9e11m630o@4ax.com again
crashes RC6.
ABX
Date: 10 Jun 2002 07:35:50
Message: <3d048f16@news.povray.org>
> crashes RC6.
Well, you complain either way, so live with it.  Period!
    Thorsten
Date: 10 Jun 2002 08:37:41
Message: <a579gus0s9jj6jics0ag04lke384enf3ph@4ax.com>
On Mon, 10 Jun 2002 13:35:46 +0200, "Thorsten Froehlich" <tho### [at] trfde>
> > crashes RC6.
... until 3.5.first.bug.fix.release.win32.icl I hope ;->
ABX
Date: 10 Jun 2002 09:49:36
Message: <3d04ae70@news.povray.org>
No, what you do is destroying the function prior to it getting used, so it
can never work.  Don't you the #undef of a function that is used inside
another function at the same time when that other function is being
declared.
    Thorsten
