POV-Ray : Newsgroups : povray.beta-test : strange recursion error Server Time
17 Jan 2026 01:04:37 EST (-0500)
  strange recursion error (Message 1 to 10 of 11)
Subject: strange recursion error
Date: 15 Mar 2002 11:47:09
Message: <at849uk68rnqhu92mhbkng6ho01tl23178@4ax.com>
POV 3.5 b 13 icl on WinNT Sp 6 PII 233 with 128 MB
Below script:
  #local g=function(_){ceil(_)-_};
  plane{-z,-5 pigment{function{ g(atan2(x,y))}} finish{ambient 1}}
returns:
  Rendering Error: Stack full. Possible infinite recursive function call.
but when I inline function and write script this way:
  plane{-z,-5 pigment{function{ ceil(atan2(x,y))-atan2(x,y) }} finish{ambient 1}}
then it is rendered fine. Any confirmation ?
As extended testing example use my signature :-)
Btw: Am I only active beta-tester or just lucky one ?
ABX
disc{z,-z 5#macro O()asc(substr("-+((1*(,1,/.-,*/(,&.323/'1"e,1))*.1-4#declare
e=e-1;#end#local e=26;pigment{#local g=function(_){ceil(_)-_}function#local//X
k=function{pattern{object{sphere_sweep{linear_spline 13#while(e>0)<O(),O()//AB
>.01#end}}}}{k(g(atan2(x,y)),g(ln((y+x)^2+1e-5)),0)}}finish{ambient 1}}//POV35
Subject: Re: strange recursion error
Date: 15 Mar 2002 18:25:00
Message: <3c9282cc@news.povray.org>
"W?odzimierz ABX Skiba" <abx### [at] babilonorg> wrote in message
news:at849uk68rnqhu92mhbkng6ho01tl23178@4ax.com...
> returns:
finish{ambient 1}}
Confirm (PIII-1000 512 Mb Win2000)
Your signature fails with the same message.
Gleb
Date: 15 Mar 2002 20:27:33
Message: <3c929f85@news.povray.org>
Maybe you are just one of the few who try these weird function/macro things
I have no clue about :)
-Jide
Date: 17 Mar 2002 07:16:05
Message: <3C9487E7.17F54BFC@hotmail.com>
No, you're not alone out in the
dark. I too torture functions.
Right now I am experiencing
severe crash problems when my
macros builds _VERY_ large
functions: I have to reboot my
PC after each crash  =(
So maybe you'll consider me
"lucky" as well.
Tor Olav
Date: 18 Mar 2002 03:16:26
Message: <r08b9uoiojmu0hnnpoosv1no234c6dbmjt@4ax.com>
On Sun, 17 Mar 2002 13:11:19 +0100, Tor Olav Kristensen
Sounds very promising for functions advocate :-)
Did you reported this problem ? If your time is limited or something I can
help you with bug investigation if you can share your source.
> "lucky" as well.
We are really lucky with those functions in 3.5 :-)
ABX
Date: 18 Mar 2002 19:41:57
Message: <3C96883A.CDCF453D@hotmail.com>
No, because I'm not sure if I have
read reports about similar problems
earlier. I'll have to check that.
Thank you.
I'll soon post a zip file to povray.
beta-test.binaries, containing two
test files so that you can check if
it crashes POV on your PC.
I wish that I knew the limitations
for the sizes of functions.
> > "lucky" as well.
They are wonderful new tools, but if
we don't treat them with great care
they often break.
Tor Olav
Date: 19 Mar 2002 05:03:49
Message: <iq2e9u0cmjlnohgv8m4c9vit2ppcb8hm72@4ax.com>
On Tue, 19 Mar 2002 01:37:14 +0100, Tor Olav Kristensen
Yes, It makes illegal operation. But fast look into your zip gives me the
answer - there are 4022 selects not even talking about different tokens.
Thorsten explained me some day that number of tokens is limited but handling
of length checking was breaken. I though it is fixed now but look like your
source contain another exception. Check
http://news.povray.org/3c63f967%241%40news.povray.org
Check: http://news.povray.org/3c83a056%40news.povray.org
ABX
Date: 19 Mar 2002 13:43:11
Message: <3c9786bf@news.povray.org>
Confirmed. This bug is breaking most of my newest scenes.
Here's where I met it:
#macro Interpolate (p1,p2,TT)
#local p1x=p1.x;
#local p1y=p1.y;
#local p1z=p1.z;
#local p2x=p2.x;
#local p2y=p2.y;
#local p2z=p2.z;
#local fx = function (T){p1x + T*(p2x-p1x)}
#local fy = function (T){p1y + T*(p2y-p1y)}
#local fz = function (T){p1z + T*(p2z-p1z)}
#local vec = <fx(TT),fy(TT),fz(TT)>;
vec
#local my_vector =
Interpolate (<0,0,0>,<1,1,1>,0.5) ;
Jonathan.
Date: 19 Mar 2002 20:57:58
Message: <MPG.1701fd006c322296989680@news.povray.org>
In article <3c9786bf@news.povray.org>, jrg### [at] hotmailcom says...
It seems that the bug shows up when the function has fewer than the
default 3 parameters.  Try your code like this instead:
> #local p1x=p1.x;
> #local p1y=p1.y;
> #local p1z=p1.z;
> #local p2x=p2.x;
> #local p2y=p2.y;
> #local p2z=p2.z;
> #local fx = function (T,a,b){p1x + T*(p2x-p1x)}
> #local fy = function (T,a,b){p1y + T*(p2y-p1y)}
> #local fz = function (T,a,b){p1z + T*(p2z-p1z)}
> #local vec = <fx(TT,0,0),fy(TT,0,0),fz(TT,0,0)>;
> vec
> #end
> #local my_vector =
This workaround fixes the original reporter's signature, and also fixes
at least f_sqr in math.inc.  Now it is up to the developers to make a
real fix for the bug.
Geoff Reedy                                                gre### [at] umredu
Date: 20 Mar 2002 14:30:32
Message: <3C98E235.CABB23B0@hotmail.com>
Thank you for the info.
I'll look further into this later this week.
Tor Olav
