POV-Ray : Newsgroups : povray.beta-test : RC6 (Intel compile) - Runs too fast! Server Time
14 May 2025 19:49:33 EDT (-0400)
  RC6 (Intel compile) - Runs too fast! (Message 1 to 6 of 6)
Subject: RC6 (Intel compile) - Runs too fast!
Date: 11 Jun 2002 02:30:39
Message: <aJAFPfa0MTSIo+fyEjg7XkjPrbOt@4ax.com>
I hope you don't mind this mostly OT post, but I thought you might
like some good news and comments for a change.
POV reports that the "Render" -> "Run Benchmark" menu option takes
about one hour to execute on a 2GHz Pentium 4 machine. Well, you might
want to revise that warning dialog, just before you release the final
version of POV-Ray. I just ran the official benchmark from that menu,
and it rendered in only 46 minutes, 26 seconds.
The system I used has 256Megs of PC133 SDRAM (not DDR), runs WIN98se
(with virtual memory disabled), and is powered by an  Athlon XP 1600+,
which has an actual clock speed of 1.4 GHz, and is usually rated to
compare favorably with a 1.6 GHz Pentium 4, not the 2GHz Pentium 4
that POV-Ray cites as a reference.
In other words, my "slower" machine just rendered your scene much
faster than your warning dialog led me to believe it would. It seems
that someone has done a good job of tweaking POV's speed, and I really
want to thank them for it. However, I still think you might want to
update that dialog box that warns about a 1 hour render, just before
POV becomes finalized. I'm hoping that by then, my render time drops
to a mere 1/2 hour.   :)
Thanks very much, and keep up the good work!
Glen
Subject: Re: RC6 (Intel compile) - Runs too fast!
Date: 11 Jun 2002 09:02:05
Message: <3D05F4E2.9030405@free.fr>
Well, it renders in 4 hours 14 minutes 41 seconds on
P-2 400MHz under W98 (with some other applications, normal priorities).
Maybe it was sized down too much (seems it's missing 1/5) ?
Anyway, remember also that Athlon are better than P4 at FPU.
Date: 11 Jun 2002 21:29:34
Message: <3d06a3fe@news.povray.org>
> Anyway, remember also that Athlon are bettern tahn P4 at FPU.
Holy cow! What am I supposed to buy for my new computer? Athlon, Intel?
Heeeeelp!
Apache
POV-Ray Cloth experiments: http://geitenkaas.dns2go.com/experiments/
Email: apa### [at] yahoocom
ICQ: 146690431
Date: 12 Jun 2002 05:17:54
Message: <3d0711c2@news.povray.org>
In article <3d06a3fe@news.povray.org> , "Apache"
> Heeeeelp!
Did it occur to you that the two hour message may just be outdated...?
    Thorsten
Date: 12 Jun 2002 09:55:40
Message: <3d0752dc@news.povray.org>
> Heeeeelp!
  Certainly don't buy a P4. You will be paying a lot more for a lot less
computing power.
Subject: Benchmark (was: RC6 (Intel compile) - Runs too fast!)
Date: 12 Jun 2002 15:51:58
Message: <3d07a65e@news.povray.org>
I got nearly the same with Athlon TBird 1.4GHz (46:57)
I looked up the help for benchmark (Windows specific: 1.10.7.1.5), and it
says, that the author of Povray for Windows (That would be Chris Cason) ran
the benchmark with the final release of 3.5:
"(note that this was with POV-Ray for Windows v3.5 final release)"
is there a "not" missing?
The average PPS of the mentioned P4 2000: 54.04 PPS leads exactly to one hour
: (512*384)/54.04=3638sec, 3600 would be an hour.
The problem is, that povray isn't running the benchmark with 512*384, but
with 384*384 instead, this can be seen in the message-window:
<quote from message-stream>
Running standard POV-Ray benchmark version 1.01
Persistence of Vision(tm) Ray Tracer Version 3.5.beta.RC6 win32 (.icl)
  This is a time-limited beta test version.  No re-distribution
   of any sort is permitted.
Output Options
  Image resolution 384 by 384 (rows 1 to 384, columns 1 to 384).
</quote from message-stream>
(Taking this into account, those Athlons would take 1 hour and 2.5 minutes.
-> not too fast anymore)
There's one thing to add:
This benchmark generates a warning:
Warning: The maximum gradient found was 2.626, but max_gradient of the
isosurface was set to 2.400. The isosurface may contain holes!
Adjust max_gradient to get a proper rendering of the isosurface.
Maybe this is right, I don't know (perhaps the benchmark is tweaked to look
good and be "fast"; at least not unnecessarily slow...)
cukk
