POV-Ray : Newsgroups : povray.beta-test : Known bugs 2 Dec 2001 (beta 8) Server Time
30 Sep 2024 21:30:43 EDT (-0400)
  Known bugs 2 Dec 2001 (beta 8) (Message 1 to 9 of 9)
Subject: Known bugs 2 Dec 2001 (beta 8)
Date: 1 Dec 2001 23:16:21
Message: <aBQBPBAAmaC8Ew76@econym.demon.co.uk>
KNOWN BUGS
Blob problem (job000189)
and Blob : Toward a solution
(blob surface develops holes when "radius" is very small)
http://news.povray.org/3b99052c@news.povray.org
http://news.povray.org/3B991C90.D715B7A3@free.fr
Superellipsoid epsilon to big ? (job000190)
(strange dark patches occur on a superellipsoid when the east-west-
exponent is set very small)
http://news.povray.org/3b992a81@news.povray.org
Additional (?) blob bug
(blob component disappears when radius is 317 or greater)
http://news.povray.org/Xns9115B92CF7D8ACQ@204.213.191.226
(also reported as: Blob rendering error (job000136))
http://news.povray.org/Xns91203DC7F3CCQ@204.213.191.226
hf_gray_16 + png creates wrong output image (job000173)
(global_settings {hf_gray_16} causes "Cannot open output file")
http://news.povray.org/3BA3BAE6.4671C0BB@free.fr
Small window title bug
(Title switches back to "POV-Ray for Windows" after minimize or
restore.)
http://news.povray.org/3ba92966$1@news.povray.org
Rendering animation (MS Windows) (job000178)
(Message that indicates the frame to be render is displayed AFTER the
rendering.)
http://news.povray.org/3BAC1D0C.74A4A503@free.fr
sin(X)^sin(X) -> crash! (job000179 and job000180)
http://news.povray.org/3baf7992@news.povray.org
Spline bug (job000182)
(The spline path is all wrong when certain time values are used.)
http://news.povray.org/3bb41dc8@news.povray.org
Strange spline problem (job000181)
(Changes from render to render. Control points are sometimes missing.)
http://news.povray.org/Xns9136AC2E64F60seed7@povray.org
Highlight bug (job000137)
(highlights are sometimes visible where they should be in shadow)
http://news.povray.org/3bb4cf08@news.povray.org
Macro bug (job000146)
(POV can dereference a deallocated pointer if you return a local from a
macro.)
http://news.povray.org/3BB4ED11.8EC69CEC@hotmail.com
(also reported as: strings operations crash with both compiles
http://news.povray.org/e3piut8anmf4cli4pnfmstadgc3nleqvb2@4ax.com)
Bug with intersection stack (with crash)(job000175)
http://news.povray.org/5f13rtc0v0rso4fk7lut5e0980qa9g756b@4ax.com
Radiosity sampling, with fix method (job000177)
(radiosity sample counter is reset to the start every time, sampling
artefacts are produced)
http://news.povray.org/3BC5A13E.9C022BD6@reading.ac.uk
Slow rendering when using +ua and antialiasing method 1 (job000191)
(No details available)
http://news.povray.org/3bbf6347@news.povray.org
Delayed syntax checking (job000192)
(declare without the "#" can cause a much later line to fail to parse
Parser will ignore the first token following old-style declares without
a #.)
http://news.povray.org/AM3LOAABMO27EwFh@econym.demon.co.uk
[bug] orthographic camera bug?
(objects sometimes disappear when the orthographic camera is used)
http://news.povray.org/3bdca5eb@news.povray.org
Bug: dispersion_samples affects photon brightness (job000193)
http://news.povray.org/MPG.1631c5fca936293298969e@news.povray.org
Jpeg and memory problem during animations (job000194)
(It seems that some memory is not properly released between frames when
a jpeg file is used)
http://news.povray.org/3be2ef0d@news.povray.org
Bug with blobs and media
(possibly related to  blob surface develops holes when "radius" is very
small)
http://news.povray.org/3be5f0b2@news.povray.org
Render Window Bug
(Render window pops up when application minimised, after which the
application doesn't open when clicked on the task bar.)
http://news.povray.org/3bde157e@news.povray.org
Another strange photon behavior (job000195)
(a: bright colored caustics. b: holes/circular black spots)
http://news.povray.org/MPG.16510f3e44067d3f9896ae@news.povray.org
panoramic projection bug? (job000196)
(When "angle" keyword within camera statement appears after "panoramic"
keyword then looks like ignored.)
http://news.povray.org/avnfut8fof5ualgf8hnrtpl1knlg8828sp@4ax.com
Alpha problems: text is not antialiased (job000187)
(black objects are not antialiased on Unix and Windows versions, alpha
is not correctly output on Mac)
http://news.povray.org/3bea5a84$1@news.povray.org
Black outline in smooth meshes
(The outline of smooth meshes exhibit black dots or areas (which go away
with double_illuminate))
http://news.povray.org/3bf6794e$1@news.povray.org
User_Abort_Command
(User_Abort_Command does not seem to work at all)
http://news.povray.org/Xns913D9F7268736seed7@povray.org
First report from bugreports
http://news.povray.org/u12outsm2kso3k5ef4lp26ogm5cvsm46ge@4ax.com
Re: trivial question on topic
(Poly Object Bug: heart has a dark line of artifacts)
http://news.povray.org/3BEBEB4C.CA854309@pacbell.net
Camera is off by half a pixel
http://news.povray.org/3bccc696@news.povray.org
Light_sources in light_groups don't cast shadows
(rendering without light buffers (-UL) puts the shadows back)
http://news.povray.org/3bfd4d63@news.povray.org
Save during render
(is very slow)
http://news.povray.org/jhaiduce@engin.umich.edu
double_illuminate only works with direct lighting
http://news.povray.org/3BF6F1FE.D21B0C6@oreka.com
no_image, merge and shadows
(setting no_image to an object in a merge causes that object to stop
casting shadows)
http://news.povray.org/vqfd0ucm5276q9j8sdh34afjliapc1kj0n@4ax.com
Isosurfaces *much* slower in beta 7?
(isosurfaces with "evaluate" are now very slow)
(was said to be fixed in next beta, but isn't fixed in beta 8)
http://news.povray.org/3bdf24b3$1@news.povray.org
rand.inc VRand_In_Sphere flaw
(VRand_In_Sphere doesn't give uniform distribution)
http://news.povray.org/3bc64790$1@news.povray.org
problem with normals/functions: crash!
(if an isosurface is the first function parsed, then things go horribly
wrong)
http://news.povray.org/MPG.16724448f4beb4ad9896c3@news.povray.org
Isosurface : 2 bugs
(int() causes crash)
http://news.povray.org/3c082dbe@news.povray.org
IsoCacti.pov
(displays 754 evaluate warnings, most with incorrect values)
http://news.povray.org/3c08c36c$1@news.povray.org
        BUGS FIXED IN BETA 8
marble + turbulence bug
(marble turbulence now looks very different)
http://news.povray.org/Xns914AC563F6C36seed7@povray.org
function re-declaration crash
(Intel compilation only: previously reported as "loop bug" for beta 5)
(also causes crackle2.pov and crackle3.pov to crash under the Intel
compile)
http://news.povray.org/3bdfcdf7@news.povray.org
Are '&' and '|' switched?
(when used in a function operating on numbers they have the opposite
effect)
http://news.povray.org/Xns9128A184570B3seed7@povray.org
function(a){a<=0} returns the wrong value when a=0
http://news.povray.org/Xns9128A519E6F15seed7@povray.org
When outputting to PNG, the wrong gamma correction value is written
http://news.povray.org/3be12811@news.povray.org
agate pattern broken
(different results with intel and msvc compile)
http://news.povray.org/3BE46299.421893B7@gmx.de
Bug with declaration with no dimensions
http://news.povray.org/scpitt851apfq5r6qtsoi1vpupt77g829s@4ax.com
Status line bug
(status line keeps saying "Parsing..." instead of telling me what the
error was)
http://news.povray.org/3bde062f@news.povray.org
WinPov crash with too many max_gradient warnings
(previously reported as: "[Bug] Output of too many evaluations cause
strange behavior", but it didn't actually crash beta 4 or  beta 5)
http://news.povray.org/3BE026F0.B59858FA@gmx.de
Using charset sys crashes povray
http://news.povray.org/3bfb4d8c@news.povray.org
Marble + Turbulence + Isosurface ( bug ? )
(turbulent marble looks very different when the rays pass through or
close to an isosurface)
http://news.povray.org/3c065976@news.povray.org
Mike Williams
Gentleman of Leisure
Subject: Re: Known bugs 2 Dec 2001 (beta 8)
Date: 2 Dec 2001 07:56:30
Message: <3c0a24fe@news.povray.org>
In article <aBQ### [at] econymdemoncouk> , Mike Williams
It is fixed.  The other problems with isosurfaces may obscure the fix in
scenes which exhibit the other problem as well.
> wrong)
> Isosurface : 2 bugs
> IsoCacti.pov
All the same problem.
    Thorsten
e-mail: tho### [at] trfde
Date: 2 Dec 2001 08:30:33
Message: <3c0a2cf9@news.povray.org>
Mike Williams <mik### [at] nospamplease> wrote:
: Isosurfaces *much* slower in beta 7?
: (isosurfaces with "evaluate" are now very slow)
: (was said to be fixed in next beta, but isn't fixed in beta 8)
  What do you mean "isn't fixed in beta 8".
  AFAIK the original problem is not there. There are other problems introduced,
but that one certainly not.
Date: 3 Dec 2001 13:03:23
Message: <Aw3XzMAc$rC8EwKy@econym.demon.co.uk>
I did some timings, and on my machine isosurfaces with "evaluate" still
run very nearly as slowly as they did in beta 7, and *much* more slowly
than the same isosurfaces without "evaluate".
Mike Williams
Date: 3 Dec 2001 15:09:44
Message: <3c0bdc08@news.povray.org>
In article <Aw3XzMAc$rC8EwKy@econym.demon.co.uk> , Mike Williams
Well, did I say they would be as fast or did i say the fix might be obscured
to the user because of the other problems?  The problem *is* fixed, no
matter how long you argue it isn't because I have the source code and know
what I changed...
    Thorsten
Date: 3 Dec 2001 15:24:27
Message: <3c0bdf7b@news.povray.org>
obscured
If multiple bugs are contributing to the problem, can you really say the
problem is fixed untill all the bugs contributing to it are?
Date: 3 Dec 2001 16:07:16
Message: <3c0be984@news.povray.org>
In article <3c0bdf7b@news.povray.org> , "Anders K." <and### [at] f2scom> wrote:
Yes.  Unless you know the source code you can't understand why the first bug
was there and thus can't understand how it was fixed.  I am not going to
discuss every line that is fixed somewhere in the source code (which you
don't have) to justify my statement.  You either take it as is or you don't.
Discussing won't change my statement or the fact that this particular bug
was fixed.
    Thorsten
Date: 21 Dec 2001 03:59:07
Message: <+2c4COAYBtI8Ew85@econym.demon.co.uk>
>> wrong)
>> Isosurface : 2 bugs
>> IsoCacti.pov
>    Thorsten
Odd, then, that only one of it was fixed in Beta 9.
Mike Williams
Date: 21 Dec 2001 05:32:28
Message: <3c230fbc$1@news.povray.org>
In article <+2c4### [at] econymdemoncouk> , Mike Williams
The crash problems are fixed, I am very sure about this!
    Thorsten
