POV-Ray : Newsgroups : povray.beta-test : Known Bugs Dec 10 Server Time
2 Nov 2025 04:59:03 EST (-0500)
  Known Bugs Dec 10 (Message 1 to 5 of 5)
Subject: Known Bugs Dec 10
Date: 9 Dec 2001 20:03:07
Message: <ZrphVDA7lAF8EwA+@econym.demon.co.uk>
KNOWN BUGS
Blob problem (job000189)
and Blob : Toward a solution
(blob surface develops holes when "radius" is very small)
http://news.povray.org/3b99052c@news.povray.org
http://news.povray.org/3B991C90.D715B7A3@free.fr
Superellipsoid epsilon to big ? (job000190)
(strange dark patches occur on a superellipsoid when the east-west-
exponent is set very small)
http://news.povray.org/3b992a81@news.povray.org
Additional (?) blob bug
(blob component disappears when radius is 317 or greater)
http://news.povray.org/Xns9115B92CF7D8ACQ@204.213.191.226
(also reported as: Blob rendering error (job000136))
http://news.povray.org/Xns91203DC7F3CCQ@204.213.191.226
hf_gray_16 + png creates wrong output image (job000173)
(global_settings {hf_gray_16} causes "Cannot open output file")
http://news.povray.org/3BA3BAE6.4671C0BB@free.fr
Small window title bug
(Title switches back to "POV-Ray for Windows" after minimize or
restore.)
http://news.povray.org/3ba92966$1@news.povray.org
sin(X)^sin(X) -> crash! (job000179 and job000180)
http://news.povray.org/3baf7992@news.povray.org
Spline bug (job000182)
(The spline path is all wrong when certain time values are used.)
http://news.povray.org/3bb41dc8@news.povray.org
Strange spline problem (job000181)
(Changes from render to render. Control points are sometimes missing.)
http://news.povray.org/Xns9136AC2E64F60seed7@povray.org
Highlight bug (job000137)
(highlights are sometimes visible where they should be in shadow)
http://news.povray.org/3bb4cf08@news.povray.org
Macro bug (job000146)
(POV can dereference a deallocated pointer if you return a local from a
macro.)
http://news.povray.org/3BB4ED11.8EC69CEC@hotmail.com
(also reported as: strings operations crash with both compiles)
http://news.povray.org/e3piut8anmf4cli4pnfmstadgc3nleqvb2@4ax.com)
Radiosity sampling, with fix method (job000177)
(radiosity sample counter is reset to the start every time, sampling
artefacts are produced)
http://news.povray.org/3BC5A13E.9C022BD6@reading.ac.uk
Slow rendering when using +ua and antialiasing method 1 (job000191)
(No details available)
http://news.povray.org/3bbf6347@news.povray.org
Delayed syntax checking (job000192)
(declare without the "#" can cause a much later line to fail to parse
Parser will ignore the first token following old-style declares without
a #.)
http://news.povray.org/AM3LOAABMO27EwFh@econym.demon.co.uk
[bug] orthographic camera bug?
(objects sometimes disappear when the orthographic camera is used)
http://news.povray.org/3bdca5eb@news.povray.org
Bug: dispersion_samples affects photon brightness (job000193)
http://news.povray.org/MPG.1631c5fca936293298969e@news.povray.org
Jpeg and memory problem during animations (job000194)
(It seems that some memory is not properly released between frames when
a jpeg file is used)
http://news.povray.org/3be2ef0d@news.povray.org
Bug with blobs and media
(possibly related to  blob surface develops holes when "radius" is very
small)
http://news.povray.org/3be5f0b2@news.povray.org
Render Window Bug
(Render window pops up when application minimised, after which the
application doesn't open when clicked on the task bar.)
http://news.povray.org/3bde157e@news.povray.org
Povray main window disappears during rendering
(Possibly the same as the above)
http://news.povray.org/3c1350f4@news.povray.org
Another strange photon behavior (job000195)
(a: bright colored caustics. b: holes/circular black spots)
http://news.povray.org/MPG.16510f3e44067d3f9896ae@news.povray.org
panoramic projection bug? (job000196)
(When "angle" keyword within camera statement appears after "panoramic"
keyword then looks like ignored.)
http://news.povray.org/avnfut8fof5ualgf8hnrtpl1knlg8828sp@4ax.com
Black outline in smooth meshes
(The outline of smooth meshes exhibit black dots or areas (which go away
with double_illuminate))
http://news.povray.org/3bf6794e$1@news.povray.org
User_Abort_Command
(User_Abort_Command does not seem to work at all)
http://news.povray.org/Xns913D9F7268736seed7@povray.org
First report from bugreports
http://news.povray.org/u12outsm2kso3k5ef4lp26ogm5cvsm46ge@4ax.com
Re: trivial question on topic
(Poly Object Bug: heart has a dark line of artifacts)
http://news.povray.org/3BEBEB4C.CA854309@pacbell.net
Camera is off by half a pixel
http://news.povray.org/3bccc696@news.povray.org
Light_sources in light_groups don't cast shadows
(rendering without light buffers (-UL) puts the shadows back)
http://news.povray.org/3bfd4d63@news.povray.org
Save during render
(is very slow)
http://news.povray.org/jhaiduce@engin.umich.edu
double_illuminate only works with direct lighting
http://news.povray.org/3BF6F1FE.D21B0C6@oreka.com
no_image, merge and shadows
(setting no_image to an object in a merge causes that object to stop
casting shadows)
http://news.povray.org/vqfd0ucm5276q9j8sdh34afjliapc1kj0n@4ax.com
Isosurfaces *much* slower in beta 7?
(isosurfaces with "evaluate" are now very slow)
http://news.povray.org/3bdf24b3$1@news.povray.org
rand.inc VRand_In_Sphere flaw
(VRand_In_Sphere doesn't give uniform distribution)
http://news.povray.org/3bc64790$1@news.povray.org
problem with normals/functions: crash!
(if an isosurface is the first function parsed, then things go horribly
wrong)
http://news.povray.org/MPG.16724448f4beb4ad9896c3@news.povray.org
Isosurface : 2 bugs
(int() causes crash)
http://news.povray.org/3c082dbe@news.povray.org
IsoCacti.pov
(displays 754 evaluate warnings, most with incorrect values)
http://news.povray.org/3c08c36c$1@news.povray.org
Re: triangle texture interpolation
(the second texture is on the first point and the third texture is used
on the second and third points)
http://news.povray.org/3C0A8288.DDA0905B@free.fr
Blob component textures transformed twize
http://news.povray.org/3bf70645@news.povray.org
2 Win GUI bugs + nitpick
(Double-clicking a file in explorer that file isn't opened in the
instance that is already running)
http://news.povray.org/3C073446.3020104@NOzSiPpA.Mto
(also reported as: Problems starting Beta8 from Command Line)
http://news.povray.org/3c0abb67@news.povray.org
Keep Single Instance (always does, no matter setting)
http://news.povray.org/3c0b0881$1@news.povray.org
        BUGS FIXED IN NEXT BETA
image_pattern
(image_pattern produces brightness in range 76-255 instead of 0-255)
http://news.povray.org/3c09ff34@news.povray.org
o_shapes.pov (\scenes\portfolio) Beta 7 and 8
(Circle_Text and Supertorus examples have become incorrect)
http://news.povray.org/3C0A386B.7D3751C@compuserve.com
Bug with intersection stack (with crash)(job000175)
http://news.povray.org/5f13rtc0v0rso4fk7lut5e0980qa9g756b@4ax.com
Alpha problems: text is not antialiased (job000187)
(black objects are not antialiased on Unix and Windows versions, alpha
is not correctly output on Mac)
http://news.povray.org/3bea5a84$1@news.povray.org
        IT'S-NOT-A-BUG FIXED IN NEXT BETA
Focal blur aperture has no effect with camera types other than the
persective one
http://news.povray.org/3bceb66d@news.povray.org
Mike Williams
Gentleman of Leisure
Subject: Re: Known Bugs Dec 10
Date: 10 Dec 2001 23:13:00
Message: <slrna1b1s3.2ku.ron.parker@fwi.com>
Fixed in the next beta (I actually already reported this in another
group, but here's to completeness.)
Also, job000188 has been fixed in the next beta, but I didn't see
that one in your list, so it never existed. :)
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbf 1}hollow interior{media{emission 3-T}}}#end
Z(-x-x.2x)camera{location z*-10rotate x*90normal{bumps.02scale.05}}
Date: 11 Dec 2001 02:13:06
Message: <jxMPDCAvfaF8EwnF@econym.demon.co.uk>
None of the bugs reported on this newsgroup seem to have ever been
identified as job000188. Sometimes job numbers get implemented without
ever being associated with a reported bug.
Mike Williams
Date: 11 Dec 2001 09:25:29
Message: <3c161759@news.povray.org>
Mike Williams <mik### [at] nospamplease> wrote:
: None of the bugs reported on this newsgroup seem to have ever been
: identified as job000188. Sometimes job numbers get implemented without
: ever being associated with a reported bug.
  I think it had something to do with the combination of PPM output and
hf_gray_16 giving a bad result.
Date: 12 Dec 2001 10:17:46
Message: <slrna1et8r.8bl.ron.parker@fwi.com>
Right.  I think it wasn't actually reported on this newsgroup, since I
found it while discussing PPM-ish things in some other group and just
added it to the bug-tracking system myself.  I wasn't trying to make a
jab or a point or anything, I was just having a little fun.
#local R=<7084844682857967,0787982,826975826580>;#macro L(P)concat(#while(P)chr(
mod(P,100)),#local P=P/100;#end"")#end background{rgb 1}text{ttf L(R.x)L(R.y)0,0
translate<-.8,0,-1>}text{ttf L(R.x)L(R.z)0,0translate<-1.6,-.75,-1>}sphere{z/9e3
4/26/2001finish{reflection 1}}//ron.parker@povray.org My opinions, nobody else's
