POV-Ray : Newsgroups : povray.beta-test : spline in, out array bug Server Time
24 Oct 2025 16:51:40 EDT (-0400)
  spline in, out array bug (Message 1 to 5 of 5)
Subject: spline in, out array bug
Date: 15 Jul 2021 05:54:59
Message: <XnsAD687938A665Aseed7@news.povray.org>
In the scene below is spline is defined and then put into an array. When
it is pulled out of the array it always is a linear spline, instead of
the original 'curvy' spline. This used not to be the case as one of the
meshmaker macro's depends on doing this since 3.5.
I cannot trace back where this behaviour originated as I only have 3.8
alpha's and beta's here and all show this behaviour. (running win10)
#version 3.8;
global_settings {assumed_gamma 1.0}
camera {location <0,3.5,-12> look_at <0,1.5,0> angle 40}
light_source {<500,500,-500> rgb <0.8,0.9,1>}
#declare A1=spline {
   cubic_spline
   -0.5, < 1,-1, 0>
    0.0, < 1, 0, 0>
    0.5, < 2, 1, 0>
    1.0, < 1, 2, 0>
    1.5, < 1, 3, 0>
#declare An=array[1]{
   spline{A1},
#declare M=500;
union {
  #declare Spl=spline{An[0]};
  #for(I,0,50)
   sphere {Spl(I/50), 0.04 no_shadow pigment {rgb 1}}
https://ingoogni.nl
Subject: Re: spline in, out array bug
Date: 15 Jul 2021 07:29:03
Message: <60f01bff$1@news.povray.org>
> #version 3.8;
>     cubic_spline
>     -0.5, < 1,-1, 0>
>      0.0, < 1, 0, 0>
>      0.5, < 2, 1, 0>
>      1.0, < 1, 2, 0>
>      1.5, < 1, 3, 0>
>     spline{A1},
> #declare M=500;
> union {
>    #for(I,0,50)
>    #end
Looks like a problem with spline{} block parsing when passing a spline
id. The current Parse_Spline() code expects the spline type token to
exist otherwise it assumes the intent was a linear spline.
A fix is to add some dynamic_cast 'type checking' to:
GenericSpline *Parser::Parse_Spline()
in parser_expressions.cpp so it looks something like:
     if (!New)
         if (Old)
             if (dynamic_cast<LinearSpline *>(Old)!=nullptr)
                 New = new LinearSpline(*Old);
             else if (dynamic_cast<QuadraticSpline *>(Old)!=nullptr)
                 New = new QuadraticSpline(*Old);
             else if (dynamic_cast<CatmullRomSpline *>(Old)!=nullptr)
                 New = new CatmullRomSpline(*Old);
             else if (dynamic_cast<NaturalSpline *>(Old)!=nullptr)
                 New = new NaturalSpline(*Old);
             else
                 throw POV_EXCEPTION_STRING("Internal Error. Pointer to
existing spline not of a known type.");
//          New = new LinearSpline(*Old); // <-- what is done currently.
         else
             New = new LinearSpline();
Bill P.
Date: 15 Jul 2021 16:56:27
Message: <60f0a0fb$1@news.povray.org>
Am 15.07.2021 um 13:29 schrieb William F Pokorny:
Fortunately, there's a more elegant solution: The `GenericSpline` class
has a virtual member function, `Clone()`, that is implemented by each
subclass to return a newly constructed copy of whatever the actual type
of the object is.
So the code in question can remain as simple as:
     if (!New)
         if (Old)
             New = Old->Clone();
         else
Will you do the honors, or shall I?
Date: 16 Jul 2021 05:42:05
Message: <60f1546d$1@news.povray.org>
> of the object is.
>      if (!New)
>          if (Old)
>              New = Old->Clone();
>          else
Please go ahead.
I'll be updating my own pile of code to your cleaner fix - thank you.
Bill P.
Date: 16 Jul 2021 07:42:15
Message: <XnsAD698B66DB735seed7@news.povray.org>
Thanks.
https://ingoogni.nl
