POV-Ray : Newsgroups : povray.beta-test : none keyword Server Time
15 Jan 2026 02:44:12 EST (-0500)
  none keyword (Message 1 to 5 of 5)
Subject: none keyword
Date: 5 Jan 2019 04:53:49
Message: <XnsA9CE6ED9DE6D1seed7@news.povray.org>
A feature request,
#declare Arr = array[10]{};
#declare Arr[3]= 5;
this results in a partially 'filled' array that can't be written to a
file and then #included.
Something like #declare Arr = array[10]{,,,5,,,,..} won't work.
True, false & co. are values, so I can't put those as fillers in an array
with values as they will be seen as legit values. They can't be used in
an array with strings or objects (unless the array is of mixed type).
In an array with strings one could use an empty string "", in an array
with values an odd one, -9999.99, same with vectors.
You can't use an empty object{} anywhere.
Could a 'none' keyword be introduced as a general placeholder for
emptyness?
object{none}
#declare Arr = array[10]{none,none,none,5,...}
#if(... none)
#while(... none)
#ifndef(Arr[I])#write(File,none)#end
#macro DoThing(A, optional B, optional C)
DoThing("Great thing", none, true)
ingo
Subject: Re: none keyword
Date: 5 Jan 2019 06:47:41
Message: <5c30995d$1@news.povray.org>
Am 05.01.2019 um 10:53 schrieb ingo:
> emptyness?
> object{none}
> #if(... none)
> #while(... none)
Should be possible, though I'd probably favour `undef` for that purpose:
It avoids introducing another keyword, and also makes it perfectly clear
what happens to that array entry.
Date: 5 Jan 2019 07:27:02
Message: <XnsA9CE88D406FA3seed7@news.povray.org>
Yep, that's even more explicit.
ingo
Date: 3 Mar 2019 19:03:56
Message: <5c7c6b6c$1@news.povray.org>
Some other options are "null" or "nil".
Mike
On 1/5/2019 4:53 AM, ingo wrote:
> A feature request,
> #declare Arr[3]= 5;
> emptyness?
> object{none}
> #if(... none)
> #while(... none)
> ingo
Date: 7 Mar 2019 10:29:55
Message: <5c8138f3@news.povray.org>
Am 04.03.2019 um 01:03 schrieb Mike Horvath:
"null" is misleading because it can be misinterpreted as "zero". As a
matter of fact, that's exactly what `NULL` is in C, where everyone and
their uncle borrowed the name from; it just happens to be used a lot in
pointers, because in C pointers and integer values are highly
interchangeable.
"nil" is stupid because it is a technical acronym that's not applicable
in many contexts: "Not In List".
"void" also comes to mind.
"mu" from Zen philosophy might also do nicely, if it wasn't prone to be
mistaken for a greek letter of same name.
