POV-Ray : Newsgroups : povray.beta-test : #persistent Server Time
16 Nov 2025 12:07:22 EST (-0500)
  #persistent (Message 1 to 9 of 9)
Subject: #persistent
Date: 27 Dec 2018 16:54:45
Message: <XnsA9C5E91459B83seed7@news.povray.org>
Will #persistent make it from Ueberpov to 3.8? Extremely usefull feature.
ingo
Subject: Re: #persistent
Date: 27 Dec 2018 17:45:01
Message: <web.5c2555ab874d1a8ed0c6faf90@news.povray.org>
> ingo
second
Date: 28 Dec 2018 04:46:23
Message: <5c25f0ef$1@news.povray.org>
Am 27.12.2018 um 22:54 schrieb ingo:
Not yet - the implementation in UberPOV is too hackish, with persistent
variables not only carrying over between frames of an animation, but
also between independent renders in the same session (on Windows).
Date: 28 Dec 2018 05:10:31
Message: <XnsA9C671AF6AC86seed7@news.povray.org>
in news:5c25f0ef$1@news.povray.org clipka wrote:
> [...] with
> persistent variables not only carrying over between frames of an
> animation, but also between independent renders in the same session
> (on Windows).
Ouch. That's not what we want.
Thanks Clipka,
ingo
Date: 28 Dec 2018 07:05:01
Message: <web.5c261071874d1a8ed0c6faf90@news.povray.org>
> Not yet -
shucks
ok for linux tho (which is where i use it)?  if not so much, just restart povray
between projects?
Date: 28 Dec 2018 19:15:35
Message: <5c26bca7$1@news.povray.org>
Am 28.12.2018 um 13:00 schrieb green:
> between projects?
No, the proper route is to clean up POV-Ray's internal architecture even
more, and then implement it in a fashion that works regardless of the
platform.
Date: 29 Dec 2018 09:40:00
Message: <web.5c27863e874d1a8e765e06870@news.povray.org>
> > between projects?
> platform.
Yes, for "long-term proper".
For short-term accessibility, perhaps a #reset_defaults to begin a scene with,
that be deprecated / ignored one the long-term permanent proper fix is in.
Date: 29 Dec 2018 11:37:49
Message: <XnsA9C7B3599C83seed7@news.povray.org>
in news:web.5c27863e874d1a8e765e06870@news.povray.org Bald Eagle wrote:
> For short-term
Meh. With #write a lot can be done already, below's the resulting file
of ~170 lines of macro. I'd opt for doing #persistent right. That doesnt
take a way that it is an important feature that I've missed often and
for me would be high on the list.
#declare Self=dictionary{
  ["LogLevel"]:0,
  ["Default"]:dictionary{
    ["Tolerance"]:0.010,
    ["MaxIter"]:100
  ["ProcessType"]:dictionary{
    ["BaseEnd"]:0,
    ["BaseSubbase"]:1,
    ["SubbaseSubbase"]:2,
    ["SubbaseEnd"]:3,
    ["ClosedLoop"]:4
  ["Index"]:array{"Base1"},
  ["Proc"]:array[1]{"Base1"},
  ["Base1"]:dictionary{
    ["Type"]:"BaseEnd",
    ["Joint"]:array[7]{<0,0,0> ,<0,0.25,0> ,<0,0.5,0> ,<0,0.75,0> ,
<0.111803,0.973607,0> ,<-0.277081,1.28788,0> ,<-0.0783398,1.74669,0> },
    ["_Lengths"]:array[6]{0.25,0.25,0.25,0.25,0.5,0.5},
    ["_Length"]:2.000000,
    ["_O"]:<0,0,0> ,
    ["_N"]:7,
    ["_M"]:6,
    ["Effector"]:6,
    ["Target"]:<-0.0786086,1.74607,0> ,
    ["Constraints"]:dictionary{
      ["3"]:dictionary{
        ["Objn"]:"C",
        ["Objs"]:C,
        ["Axis"]:<0,1,0> ,
        ["TTs"]:<0,1,0> ,
Date: 29 Dec 2018 21:20:00
Message: <web.5c28296b874d1a8ed0c6faf90@news.povray.org>
> > For short-term
i can't say i can connect the code with the topic.
  #write might be more useful in this context if it wrote to a ram disk.
i believe my question to lipka was off-target.  linux generally spawns povray
for each batch of frames, so persistent objects should be lost after a job.  it
is hard to see how name conflicts would arise without contrived examples.
  for windows it is different.  i've already bumped my nose hard against it.  i
use a construct such as this to work around it;
#declare klock=clock; // or whatever time you are interested in
#if( klock=0)         // or whatever time you are interested in
    #ifdef( thatthing)
        #undef thatthing
#ifndef(thatthing)
    #persistent thatthing=
i think this type of thing should be sufficient.
i have not exercised due diligence in determining how much time uberpov saves
for long-parsing frames, but the small amount of experimentation i have done
suggests ten or twenty percent.  which is an enormous amount when making frames
for days or weeks or months.  so i will keep on using uberpov for animations
unless 3.8 has something i /have/ to have.
