POV-Ray : Newsgroups : povray.beta-test : Radiosity feature request Server Time
23 Mar 2026 19:05:28 EDT (-0400)
  Radiosity feature request (Message 1 to 7 of 7)
Subject: Radiosity feature request
Date: 24 Apr 2002 20:36:37
Message: <Xns91FABD5277338spammindspringcom@204.213.191.226>
Would it be possible to squeeze in an object keyword that removes
that object from all radiosity calculations?  If this would take a lot of
extra code, then by all means it doesn't belong in 3.5, but if it's a
simple thing it's something I would really like to see make it in.  I have
a scene with multiple isosurfaces that do not benefit much (if at all) by
radiosity, but the rest of the scene really needs it.  The isosurfaces
really slow down the render when radiosity is used though.
Rich Allen
(Remove SPAM from my address to reply by e-mail)
Subject: Re: Radiosity feature request
Date: 25 Apr 2002 00:32:08
Message: <3CC7869F.85F80857@gmx.de>
How about tracing the scene without Isosurfaces, save the
radiosity, and then load it when tracing with Isosurfaces?
I don't know if that would be accurate enough for you
purposes, but it may be a solution.
> Rich Allen
Tim Nikias
Email: Tim### [at] gmxde
Date: 25 Apr 2002 14:19:33
Message: <3CC84A6C.B3E86462@mail.com>
That might not work.  Imagine what would happen if the isosurfaces were
mirrors!
As I remember the code, it would not be difficult at all to modify the
lighting.c code to implement this feature.  This object flag would just
modify whether the ra_gather function was called or not.  The problem
would be associated with adding a keyword and token, which is quite a
trial with the way that the parser functions as of 3.1g.
Personally, I think it is a WONDERFUL idea and should be implemented
ASAP, but that's just my $0.02.
- Ben
Date: 26 Apr 2002 03:53:37
Message: <3cc90781@news.povray.org>
> The problem
???  Adding a keyword to the parser is really trivial.  Just take a look at
the many patches available - they had no problems doing it.  Anyway, the
whole thread is off-topic in this group...
    Thorsten
Date: 27 Apr 2002 11:12:22
Message: <3CCABFAF.3FE8489F@gmx.de>
Well, I was talkin about isosurfaces not contributing to the scene, and
with no need of them being lit much by the scene either.
> mirrors!
> - Ben
Tim Nikias
Date: 3 May 2002 20:54:04
Message: <Xns9203C048F7616spammindspringcom@204.213.191.226>
"Thorsten Froehlich" <tho### [at] trfde> wrote in
news:3cc90781@news.povray.org:
> look at the many patches available - they had no problems doing it.
I've tried the trick mentioned earlier, rendering without the isos, saving
the radiosity map, then re-rendering with the isos.  The two-step process
takes longer than to just render the whole scene with radiosity, especially
since the parts of the scene that DO need to react with radiosity change
often while I'm experimenting.  <smile>  The scene looks different enough
without radiosity that I need to render with every few changes.  <sigh>
> Anyway, the whole thread is off-topic in this group...
Sorry!  I don't see a feature-request group, and this is the only
discussion group fro 3.5, so I went with it.  Where should I be posting
these kinds of messages?
Rich Allen
Date: 3 May 2002 21:23:56
Message: <3cd3382b@news.povray.org>
  povray.general, povray.newusers, povray.advanced-users or
povray.unofficial.patches, depending on the contents. Perhaps even
povray.programming if it's something really related to the povray source
code.
