POV-Ray : Newsgroups : povray.beta-test : Scattering media, lightgroups and shadowless lights Server Time
30 Sep 2024 13:21:21 EDT (-0400)
  Scattering media, lightgroups and shadowless lights (Message 1 to 10 of 12)
Subject: Scattering media, lightgroups and shadowless lights
Date: 4 Mar 2002 01:19:56
Message: <Xns91C7D8DD4C59csbhccse@204.213.191.226>
While finding new and better ways to make media explosions, I ran into a
serious in that scattering media objects cannot be illuminated by
shadowless lights or by lights used in a light_group.  While I know that
shadowless lights do some funny things, I tend to think that getting
ignored by media is a bit much, and that the light_group problem is a
blatant bug.
Example scene:
  When rendered as is, the media is grey.  When rendered with light group
  and/or with shadowless enabled, the media will be black (unlit).
camera {location z*3 look_at 0} plane {z,-5 pigment {checker rgb 1 rgb .3}
finish {ambient 1 diffuse 0}}
//light_group {
sphere {0,1 hollow pigment {rgbf 1} interior {
    media {
        scattering {1, 8}
        density {spherical color_map {[0 rgb 0][1 rgb 1]}}
light_source {<1e6,0,1e6> 1 /*shadowless*/}
//} // end brace for light_group
Subject: Re: Scattering media, lightgroups and shadowless lights
Date: 4 Mar 2002 03:03:12
Message: <3c832a40$1@news.povray.org>
In article <Xns### [at] 204213191226> , che### [at] sympaticoca
> blatant bug.
Could you check if this is or isn't the same as
Newsgroups: povray.beta-test
Subject: Light_groups and Media
Date: Sun, 10 Feb 2002 11:31:11 +0200
Message-ID: <3c663dd3$1@news.povray.org>
Xref: news.povray.org povray.beta-test:4552
    Thorsten
e-mail: tho### [at] trfde
Date: 4 Mar 2002 06:36:43
Message: <3c835c4b@news.povray.org>
Isn't the illumination of scattering media technically a shadow test?
Thus a shadowless light...
Date: 4 Mar 2002 13:15:24
Message: <3c83b9bc@news.povray.org>
I don't think it's a good idea to have a flag which implies other flags. Why should
the shadowless flag imply media_interaction off? I think each flag should be specific
(that's why I'd personally love a no_radiosity and a no_specular flag).
Or, at least, this behaviour should be documented.
Jonathan.
"Warp" <war### [at] tagpovrayorg> ha scritto nel messaggio
news:3c835c4b@news.povray.org...
Date: 4 Mar 2002 14:30:05
Message: <bii78ugisrrqq0labhk54k2b2pl52cacmg@4ax.com>
Shadowless implies not casting shadows in scattering media. It should
not imply media_interraction off. If it does, it sounds like a bug.
Peter Popov ICQ : 15002700
Date: 4 Mar 2002 15:37:51
Message: <Xns91C79F01A86C9CQ@204.213.191.226>
"Thorsten Froehlich" <tho### [at] trfde> wrote in
news:3c832a40$1@news.povray.org:
>> a serious in that scattering media objects cannot be illuminated by
>> that shadowless lights do some funny things, I tend to think that
>> getting ignored by media is a bit much, and that the light_group
>> problem is a blatant bug.
The issue with media and light groups appears to be the same as
<3c663dd3$1@news.povray.org>.  While looking at the other report, I also
noticed that global_lights defaults to 'on' and can't be switched off for
media objects in a light_group.
The problem with shadowless is separate.
Date: 4 Mar 2002 15:56:08
Message: <Xns91C7A21B43754CQ@204.213.191.226>
Peter Popov <pet### [at] vipbg> wrote in
news:bii78ugisrrqq0labhk54k2b2pl52cacmg@4ax.com:
>>flags. Why should the shadowless flag imply media_interaction off? I
>>think each flag should be specific (that's why I'd personally love a
As far as the Megapov lighting code is concerned, shadowless doesn't set
media_interaction=off per say but has pretty much the same effect due to
the way media illumination is calculated.
At first glance, most of the fix is to modify test_shadow() in lighting.c
such that shadow tests are performed with shadowless lights (remove
(Light->Projected_Through_Object != NULL) from the shadow test conditional)
and then to adapt block_point_light() et el so that when handling
shadowless lights, filter_shadow_ray() is only called when the shadowed
object contains a media.  Unless I've overlooked something major, both of
these tasks should be relatively straight forward.
Date: 5 Mar 2002 01:36:29
Message: <khp88us6ttlb5fvqe1atehojkdhkrt8jae@4ax.com>
On 4 Mar 2002 15:56:08 -0500, che### [at] sympaticoca (Coridon Henshaw)
So basically what you're suggesting that objects will not cast shadows
from shadowless lights anywhere except in scattering media? Doesn't it
look a bit inconsistent?
Date: 5 Mar 2002 02:08:25
Message: <3c846ee9@news.povray.org>
Sorry for putting words in someone's mouth, but I believe he's suggesting
that shadowless lights don't illuminate scattering media at all.
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
Date: 5 Mar 2002 02:15:17
Message: <ptr88u8njs059enopcgplcu4lnp1e90rmg@4ax.com>
On Tue, 5 Mar 2002 02:05:41 -0500, "Slime" <noo### [at] hotmailcom>
Which would also be inconsistent.
