POV-Ray : Newsgroups : povray.beta-test : Minor spline problem Server Time
24 Mar 2026 02:00:02 EDT (-0400)
  Minor spline problem (Message 1 to 4 of 4)
Subject: Minor spline problem
Date: 10 Feb 2002 23:19:55
Message: <Xns91B1ED54D3E8csbhccse@204.213.191.226>
The second #local statement in the code below will not parse in Windows
beta 11 even though the doucmentation says that splines will work "wherever
you would normally put a vector."  This behavior seems to be a holdover
from Megapov.  Assuming Pov can't be fixed, a note in the documentation
that the Megapov spline workaround (i.e. 1*spline(etc)) must be used might
be a good idea.
#local mTrack = spline {linear_spline 0, <0,0,0> 1, <12,0,12>}
#local P0 = mTrack(C);
Subject: Re: Minor spline problem
Date: 11 Feb 2002 04:37:10
Message: <3c6790c6@news.povray.org>
In article <Xns### [at] 204213191226> , che### [at] sympaticoca
> be a good idea.
Works correctly and has been explained before.
    Thorsten
e-mail: tho### [at] trfde
Date: 11 Feb 2002 14:33:10
Message: <Xns91B2940A2CC14CQ@204.213.191.226>
"Thorsten Froehlich" <tho### [at] trfde> wrote in
news:3c6790c6@news.povray.org:
>> Assuming Pov can't be fixed, a note in the documentation that the
>> Megapov spline workaround (i.e. 1*spline(etc)) must be used might be a
>> good idea.
> Works correctly
Then, as I said, the behavior needs to be documented as the existing
documentation provides a misleading example and makes no mention of this
obviously correct behavior.
Date: 11 Feb 2002 14:45:34
Message: <3c681f5e@news.povray.org>
>>> good idea.
>> Works correctly
BTW, a sufficient change to the scene is to place the expression into
parenthesis.
    Thorsten
