POV-Ray : Newsgroups : povray.beta-test : Render window recovery. Server Time
18 Feb 2026 12:42:15 EST (-0500)
  Render window recovery. (Message 1 to 6 of 6)
Subject: Render window recovery.
Date: 11 Dec 2001 09:16:48
Message: <Xns917491BB6A608michaelkearnssaacons@204.213.191.226>
I've checked the buglist (Dec 10th) and this one's not in it, so I hope I'm
correct in posting here.
Using Beta 8, win32-icl. Win2k, 800Mhz P3, 256Meg RAM.
When rendering, if I minimise the render window, I can't ever get it back
without changing the .ini file. The hide/show works fine, I just can't use
the windows minimise button.
The pvengine.ini file gains the following line in the RenderWindow section:
Flags=536870912
If I remove this line, then the window is back and usable again.
HTH,
Michael Kearns.
Subject: Re: Render window recovery.
Date: 11 Dec 2001 09:29:28
Message: <ur5c1uo7t2k53f4lu5it8kgh4us0g55hco@4ax.com>
On 11 Dec 2001 09:16:48 -0500, mic### [at] saaconsultantscom (Michael
POV 3.5 b 8  (both compile versions), NT 4m PII 233 MHz, 128 MB
> Flags=536870912
Works fine for me. Perhaps it is related with some wrong windows dll. I've
copied your flags value into ini file and it sill works fine.
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)|_((x+y)*.7,z,.1)|_((x+y+2)*.7,z,.1)|_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Date: 11 Dec 2001 20:04:26
Message: <3c16ad1a@news.povray.org>
back
use
section:
> > Flags=536870912
If you could both list the settings in the Render Window Settings under the
Options menu,  perhaps others could repeat the scenario.
N Shomber
Date: 12 Dec 2001 02:30:47
Message: <ci1e1uokbt7oeoqoopaqq912hd9ua1pjv1@4ax.com>
On Tue, 11 Dec 2001 17:08:30 -0800, "N Shomber" <nsh### [at] hotmailcom> wrote:
checked:
 - get focus on creation
 - keep above main
 - preserve contents during animation
grayed:
 - hide when main minimized
 - re-display
 - close
grayed and checked:
ABX
function{_(x-2,y,1)&_((x+y)*.7,z,.1)&_((x+y+2)*.7,z,.1)&_(x/2+y*.8+1.5,z,.1)}
Date: 17 Dec 2001 09:29:22
Message: <Xns917A93E481E59michaelkearnssaacons@204.213.191.226>
"N Shomber" <nsh### [at] hotmailcom> wrote in
news:3c16ad1a@news.povray.org:
>> > back without changing the .ini file. The hide/show works fine, I
>> > just can't use the windows minimise button.
>> > section: Flags=536870912
>> I've copied your flags value into ini file and it sill works fine.
> the Options menu,  perhaps others could repeat the scenario.
Sorry about my delay in replying.
For my failing version:
As it comes out of the box ;o)
(Exactly the same settings as the previous reply from ABX).
Date: 17 Dec 2001 10:34:27
Message: <3c1e1083@news.povray.org>
I can't duplicate this (though sometimes I have to press the restore button
twice, since the system menu pops up the first time).
If someone can work out how to isolate the problem please let me know.
-- Chris
