POV-Ray : Newsgroups : povray.beta-test : User_Abort_Command Server Time
19 Dec 2025 09:40:40 EST (-0500)
  User_Abort_Command (Message 1 to 5 of 5)
Subject: User_Abort_Command
Date: 17 Oct 2001 09:40:28
Message: <Xns913D9F7268736seed7@povray.org>
User_Abort_Command does not seem to work at all, neither in 3.1g.
other "Shell-outs" work fine. Tested it with bounce.pov & ini from
/scenes/animations/boing/
 The bounce.ini in the current distribution and 3.1g is broken (thanks,
Tom Stone), below is a fixed version (I'll also send it to Rune).
 Updated bounce.ini
; Persistence Of Vision raytracer version 3.5 sample file.
User_Abort_Command=command /C del bounce.txt
Antialias=Off
Antialias_Threshold=0.1
Antialias_Depth=2
Input_File_Name=bounce.pov
Initial_Frame=1
Final_Frame=500
Initial_Clock=0
Final_Clock=1
Cyclic_Animation=on
Pause_when_Done=off
Ingo
Subject: Re: User_Abort_Command
Date: 17 Oct 2001 22:32:44
Message: <tom.stone-1810010457010001@d212-151-231-57.swipnet.se>
I'm not an expert in how INI files should look, but it seems like
something similar is wrong with "life.ini" in the scenes/animations/life
folder
Tom Stone
Domarebacken 42, 14557 Norsborg, Sweden
Phone: Int+46 8 5318 4318, Tel: 08-5318 4318
http://home5.swipnet.se/~w-52256/index.htm
Date: 18 Oct 2001 01:52:11
Message: <Xns913E500F410AEseed7@povray.org>
in news:tom### [at] d212-151-231-57swipnetse Tom Stone
fixed
Ingo
Date: 24 Oct 2001 07:23:00
Message: <Xns91448824C9992seed7@povray.org>
Nobody confirmed. Does this mean, that I'm the only one having the
problem, or nobody tried?
Ingo
Date: 24 Oct 2001 11:12:17
Message: <3BD6DA4C.59C32EF0@gmx.de>
Can confirm it. (Both 3.1 and 3.5)
