POV-Ray : Newsgroups : povray.beta-test : Spline: Cannot copy identifier Server Time
17 Jan 2026 21:47:11 EST (-0500)
  Spline: Cannot copy identifier (Message 1 to 7 of 7)
Subject: Spline: Cannot copy identifier
Date: 10 Oct 2001 11:01:19
Message: <Xns9136AD2824CB5seed7@povray.org>
The scene below results in:
#declare A=Spl <----ERROR
Parse Error: Cannot copy identifier
#declare Spl=spline{
   linear_spline
   0/4,< 0   , 0  , 0>
   1/4,< 0.25, 0.5, 0>
   2/4,< 0.50, 0.1, 0>
   3/4,< 0.75, 0.9, 0>
   4/4,< 1   , 0  , 0>
#declare A=Spl(0.3);
Ingo
Subject: Re: Spline: Cannot copy identifier
Date: 10 Oct 2001 15:55:37
Message: <3bc4a7b9@news.povray.org>
How about #declare A(0.3)=Spl(0.3)?
Actually I'm only replying to point out that in the HTML Help section 6.1.9
Spline Identifiers there is a "quadratc_spline" mispelling (no i).  That,
and how both catmull_rom_spline and b_spline are no longer mentioned yet
still work apparently.  Were those supposed to be removed?  Seems I remember
talk of those changes or something.
Bob H.
"ingo" <ing### [at] homenl> wrote in message
news:Xns### [at] povrayorg...
>    linear_spline
>    0/4,< 0   , 0  , 0>
>    1/4,< 0.25, 0.5, 0>
>    2/4,< 0.50, 0.1, 0>
>    3/4,< 0.75, 0.9, 0>
>    4/4,< 1   , 0  , 0>
> Ingo
> Photography: http://members.home.nl/ingoogni/
> Pov-Ray    : http://members.home.nl/seed7/
Subject: Re: Spline: spline, spline (no spline)
Date: 10 Oct 2001 16:00:17
Message: <3bc4a8d1$1@news.povray.org>
"Bob H." <omn### [at] msncom> wrote in message
news:3bc4a7b9@news.povray.org...
remember
Please forgive me  :-)  I went from thinking about sphere_sweep to spline to
fast and confused those two.  They don't share the same spline type, I knew
that before.
Bob H.
Date: 11 Oct 2001 00:05:00
Message: <3bc51a6c@news.povray.org>
ingo wrote in message ...
Try
#declare A = 0+Spl(0.3);
This tells the parser you are trying to declare a float or vector, rather
than trying to copy a spline.  I don't know why you get the particular error
message you do; my development version gives "Expected: RValue to declare".
Mark
Date: 11 Oct 2001 06:50:57
Message: <Xns913782B59E38Eseed7@povray.org>
in news:3bc51a6c@news.povray.org Mark Wagner wrote:
> Try
Ah, I tried #declare A = Spl(0.3)+<0,0,0>; as a work around that didn't
work. Yours does.
> rather than trying to copy a spline.  I don't know why you get the
> particular error message you do; my development version gives
Shouldn't copying a spline be (made) possible?
Ingo
Date: 11 Oct 2001 08:53:17
Message: <slrn9sb5hu.cg1.ron.parker@fwi.com>
>> Try
>work. Yours does.
It isn't that simple.  Like passing spline and function evaluations to macros,
it requires an extra token of lookahead, and the parser isn't made to be able
to handle that.
I do think splines and functions should have the same limitations, though, and
currently they do not.  Functions act one way and splines act the opposite way.
#macro R(L P)sphere{L __}cylinder{L P __}#end#macro P(_1)union{R(z+_ z)R(-z _-z)
R(_-z*3_+z)torus{1__ clipped_by{plane{_ 0}}}translate z+_1}#end#macro S(_)9-(_1-
_)*(_1-_)#end#macro Z(_1 _ __)union{P(_)P(-_)R(y-z-1_)translate.1*_1-y*8pigment{
rgb<S(7)S(5)S(3)>}}#if(_1)Z(_1-__,_,__)#end#end Z(10x*-2,.2)camera{rotate x*90}
Date: 12 Oct 2001 00:19:59
Message: <3bc66f6f@news.povray.org>
>> Try
>work. Yours does.
It is possible.  Use the following line:
#declare A=spline{Spl}
Mark
