3.5.beta.8.icl.win32, WinXP, P3, 800MHz, 512 MB SDRAM
Okay, since beta 8 has *unofficially* hit the streets.... :-|
As my subject line says image_maps can crash the beta 8, and if not crashing
completely can cause a Render Error.
Apparently Jide's post about Landscape.pov is related to that, "Problem in
Evaluate_TPat" is one of the possible errors. "Warp type (number here) not
yet implemented is another".
You have been warned :-)
Following is minimum needed to show what happens:
// begin iso + image_map function crash test
#declare F_im=function {
pigment {image_map {
png "testiso.png" // any? TGA, PNG, BMP
}rotate 90*x}
isosurface {
function {y-F_im(x,y,z).gray*.5}
contained_by {box {0,1}}
// evaluate 1,10,0.1 // less likely to cause problem?
// max_gradient // more likely?
texture {pigment {rgb 1}}
translate <-.5,0,-.5> scale <1250,40,1250> rotate 180*y translate -40*y
// end iso crash test
Strange thing is that POV-generated hf_gray_16 tga or png files used as
input seem less likely to crash the program. Others made from PSP for
example can cause the program to exit.
Also, bmp (sys) image_maps might be more tolerant (less "crash prone" too
but I'm uncertain of that.
This appears to be an instance of "if an isosurface is the first
function parsed, then things go horribly wrong".
A workround is to add "#declare foo=function{0}" at the top of the
scene.
Mike Williams
Gentleman of Leisure
But that scene does not use an image_map in the isosurface function so the
bug is even more mysterious.
Christoph Hormann <chr### [at] gmxde>
