POV-Ray : Newsgroups : povray.beta-test : int() and val() don't work in functions Server Time
14 Oct 2025 03:31:39 EDT (-0400)
  int() and val() don't work in functions (Message 1 to 10 of 10)
Subject: int() and val() don't work in functions
Date: 17 Sep 2001 13:16:26
Message: <OsdImCAWCep7Ew$O@econym.demon.co.uk>
"floor()" can be used in simple assignments and in functions
#declare A=floor(B);                    //OK
#declare F=function{floor(x)}           //OK
But int() and val() can be used in simple assignments, but can't be used
inside a function
#declare A=int(B);                      // OK
#declare F=function{int(x)}             // Parse Error
#declare A=val("1.4");                  // OK
#declare F=function{x+val("1.4")}       // Parse Error
The docs, page 6.1.6, say int() and val() are permissible in a function.
Actually, we could live quite happily without val() in functions because
it's not going to change its value during the function evaluation, so we
can simply write
        #declare V=val(My_string);
        #declare function{x+V}
in which case remove "val()" from the list on page 6.1.6.
POV 3.5b2, AMD K6-2 500, 128Mb
Mike Williams
Gentleman of Leisure
Subject: Re: int() and val() don't work in functions
Date: 17 Sep 2001 13:39:57
Message: <3ba6356d@news.povray.org>
In article <OsdImCAWCep7Ew$O@econym.demon.co.uk> , Mike Williams
This is a documentation error.  Sorry for that, it will be corrected.
    Thorsten
e-mail: tho### [at] trfde
Date: 17 Sep 2001 14:54:36
Message: <WmeuUCAZakp7EwcT@econym.demon.co.uk>
So what do we do if we really want "int()"?
Mike Williams
Date: 17 Sep 2001 15:37:21
Message: <3ba650f1@news.povray.org>
In article <Wme### [at] econymdemoncouk> , Mike Williams
Actually, could you list the differences between "int" and "floor"?
    Thorsten
Date: 17 Sep 2001 15:56:48
Message: <slrn9qclc2.l3s.ron.parker@fwi.com>
I think the difference is the behavior for negative numbers:
int(-1.5) is -1, but floor(-1.5) is -2.
#local R=rgb 99;#local P=R-R;#local F=pigment{gradient x}box{0,1pigment{gradient
y pigment_map{[.5F pigment_map{[.3R][.3F color_map{[.15red 99][.15P]}rotate z*45
translate x]}]#local H=pigment{gradient y color_map{[.5P][.5R]}scale 1/3}[.5F
pigment_map{[.3R][.3H][.7H][.7R]}]}}}camera{location.5-3*z}//only my opinions
Date: 17 Sep 2001 16:29:15
Message: <3ba65d1b@news.povray.org>
According to their definitions... shouldn't they be the same thing?...
"Thorsten Froehlich" <tho### [at] trfde> ha scritto nel messaggio
news:3ba650f1@news.povray.org...
>     Thorsten
Date: 17 Sep 2001 16:36:07
Message: <3ba65eb7@news.povray.org>
In article <slr### [at] fwicom> , ron### [at] povrayorg (Ron
Hmm, do we really need the "int" behavior?  Anyway, I will add it to
functions.
    Thorsten
Date: 17 Sep 2001 17:21:33
Message: <3ba6695d@news.povray.org>
Yes, they *should* be the same thing... The difference right now is that
floor always rounds down, but int always rounds towards zero (this is
usually called trunc). This also has a rather unfortunate effect on mod,
where, for example, -23 mod 10 is currently -3 when it should be 8.
Date: 16 Oct 2001 22:03:55
Message: <W8YOyLAqYOz7Ewt8@econym.demon.co.uk>
>functions.
>    Thorsten
Just a reminder.
The inconsistency between the documentation (6.1.6) and the program
regarding the legality of "int()" withing a user defined function was
noticed back in beta 2. Things are still the same in beta 6, and it
doesn't appear to be on the "known bugs" list.
Mike Williams
Date: 17 Oct 2001 04:33:02
Message: <3BCD41A8.8EB9CA5C@hotmail.com>
> functions.
Yes.
Tor Olav
