POV-Ray : Newsgroups : povray.beta-test : long function with crash Server Time
31 Mar 2026 04:42:05 EDT (-0400)
  long function with crash (Message 1 to 10 of 11)
Subject: long function with crash
Date: 7 Feb 2002 12:40:31
Message: <8pe56usuudisacgrocav0l0ovqvetsno83@4ax.com>
POV 3.5 b 10 icl on WinNT Sp 6 PII 233 with 128 MB
I have created macro which creates veery long function. It is available at
http://news.povray.org/vce56usomp3amfshtgqmhnffmrtekri5a2%404ax.com
With 1000 instead of 100 at macro call povray crashes.
Any confirmation ?
ABX
Subject: Re: long function with crash
Date: 7 Feb 2002 16:10:07
Message: <Xns91AEE1CB8AC02seed7@povray.org>
> available at
> Any confirmation ?
I can confirm that the scene crashes when Count is bigger that 441.
Ingo
Date: 8 Feb 2002 05:57:06
Message: <5bb76ucbrgq3c34spn7lfs2mks7k87g7gq@4ax.com>
At begining of macro I have added function:
#local N=function{2*f_noise_generator(x,y,z,2)-1};
Then I have changed body of loop to:
      P(
        x+X*N(x+C,y,z),
        y+Y*N(x,y+C,z),
        z+Z*N(x,y,z+C)
With such changes this scene crashes when Count is bigger than 598.
Looks like crash is connected with number of tokens in expression.
ABX
Date: 8 Feb 2002 07:18:45
Message: <3c63c225$1@news.povray.org>
"ingo" <ing### [at] homenl> wrote in message
news:Xns### [at] povrayorg...
> > available at
> > Any confirmation ?
Confirm  >441 (PIII 1000 512 MB with Win 2000)
Gleb
Date: 8 Feb 2002 11:14:31
Message: <3c63f967$1@news.povray.org>
news:5bb76ucbrgq3c34spn7lfs2mks7k87g7gq@4ax.com...
>       P(
>         x+X*N(x+C,y,z),
>         y+Y*N(x,y+C,z),
>         z+Z*N(x,y,z+C)
Functions still have a size limit (the size of the function VM code is
limited to 2^16 instructions).  The function compiler does test if the
functions runs over this limit, but for some reason this test seems to fail.
At least this explains the problem (I have not looked into it yet)...
It should be noted that when this problem is fixed (maybe beta 12), POV-Ray
will issue an error message and refuse to continue parsing.  For this reason
I would suggest you add some kind of automatic splitting into several
functions, i.e. doing some kind of recursion when the count is more than say
500.  As you can have up to 2^16 functions per scene, this should be
sufficient for a count of about 2 million (or about 500000 on a 32 bit
system). Unfortunately, then you have reached the absolute size limit. BTW,
you need to do this on a 64 bit system - the functions will consume about 16
GB of memory! ;-)
    Thorsten
Date: 1 Mar 2002 10:08:53
Message: <gp5v7u4bfvadeckgreqfkvuvdbecudb6fe@4ax.com>
On Fri, 8 Feb 2002 17:16:17 +0100, "Thorsten Froehlich" <tho### [at] trfde>
> GB of memory! ;-)
I have only PII 233 with 128 MB of RAM and even with this "cheap" box I have
reached another limit:
Parse Error: More than 65535 constants in all functions are not supported.
and I think it should be mentioned in documentation and warn anybody before
long coding process. Note different limit is mentioned in 6.1.6.2 : "There is
a limit of 65535 function blocks per scene".
ABX
Date: 2 Mar 2002 22:19:59
Message: <3c81965f@news.povray.org>
What the hell are you doing???
Indeed, it should be.  I actually thought it was...
    Thorsten
e-mail: tho### [at] trfde
Date: 4 Mar 2002 03:00:47
Message: <86a68ugm13ugus6h9df0u3skeh3h6evn03@4ax.com>
On Sun, 03 Mar 2002 04:19:57 +0100, "Thorsten Froehlich" <tho### [at] trfde>
Nothing important, just universal ... something. I will show results some day
in p.b.i. Actually I passed this limitation changing loop into smart
recursion.
Great.
ABX
Date: 4 Mar 2002 09:46:15
Message: <Xns91C7A0C459B9seed7@povray.org>
Limits:
* The minimum number of parameters per function is 1.
* The maximum number of allowed parameters per function is 20.
* The maximum number of function blocks per scene is 65535.
* The maximum number of operators per function is about 10000.
  Individual limits will be different depending on the types
  of operators used in the function.
* The maximum number of constants in all functions 65535.
If this is right, I'll put it in the docs (6.1.6.2)
Ingo
Date: 4 Mar 2002 11:27:02
Message: <3c83a056@news.povray.org>
In article <Xns### [at] povrayorg> , ingo <ing### [at] homenl>  wrote:
> Limits:
Yes, this is still correct except the number of parameters - it is the same
number as the maximum parameters for macros, which was increased a few month
ago (to 40 or more I think)
    Thorsten
