> As the mosaic preview is a _preview_ feature it doesn't really make sense
> when used with radiosity.
I disagree.
1: I may need radiosity in a preview, e.g. when I want to test wether
radiosity suffices to shed enough light on some part of a scene.
2: I may not mind the 33% overhead, e.g. when I render somebody
else's scene and I want to know quickly what it is and only
eventually obtain the final image.
3: The doc (5.2.2.2.4) reads:
Future versions of POV-Ray will include some system
of temporary files or buffers which will eliminatethese
inefficiencies and limitations.
As soon as that is established, mosaic preview will be as quick as
line-by-line preview, but more informative. At that time everybody
will mix radiosity and mosaic, so why disallow now?
Mark Weyer
On 2 Jul 2002 18:03:57 -0400, Warp <war### [at] tag povray org> wrote:
> > Note, however, that if you use +SP and +EP command line options, they'll
> > override the pretrace settings.
> > I don't know if this is intentional or something left by mistake.
> Am I becoming crazy or what?
Would You like to describe what are you consider crazy in your original post ?
Doesn't +SP and +EP override the pretrace settings ? Wasn't this intentional
or something left by mistake ? :-)
The only thing I consider inconsistent is that something called 'preview'
influences something called 'pretrace' without any well written note or parse
warning. They are two separated technics but somehow they share settings and
it confused a few people - why to not warn users about it. There are more
obvious notes builded in package like "You can press F1 within editor to get
syntax help" tip.
ABX
Warp wrote:
> Uh... I don't know if I'm suffering from some lapsus or what, but I can't
> remember writing this. I remember *reading* this previously, but not
> writing it myself.
Maybe just because you wrote it a long time ago?
Felix Wiemann
No. I doubt my sanity because I am so sure that I did not post that
article, but was posted by someone else. I don't remember writing that.
I remember reading it, but not writing it myself.
I wonder if a news server can mix two articles together. Perhaps I'm just
being paranoid.
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
> being paranoid.
There were three threads so perhaps you are ... less paranoid ;-)
http://news.povray.org/povray.beta-test/25214/
http://news.povray.org/povray.advanced-users/25209/
http://news.povray.org/povray.beta-test/21982/
ABX
My signature is missing a line in that post.
Conspiracy?
> Conspiracy?
In this post, too. But via NNTP there's the right signature, just at the
web access the line is missing. Very strange...
Felix Wiemann
X-Authenticated-User: warp
It must be posted by you.
> just
> being paranoid.
Probably... ;)
Felix Wiemann
It was, after all, five months ago...
Alan
ako### [at] povray org
a k o n g <at> p o v r a y <dot> o r g
Subject: Re: [doc] mosaic preview and radiosity
Date: 4 Jul 2002 10:28:56
Message: <3d245ba8@news.povray.org>
"Felix Wiemann" <Fel### [at] gmx net> schreef in bericht
news:3d23411a@news.povray.org...
> > Conspiracy?
Yes, I noticed that before. It must be caused by the opening square bracket at
the 1st position of the 2nd line. (just a guess)
Jan Maarten
#local S=spline{cubic_spline-2<-1,2,8>0z*8 1<2,1,4>2<0,2,8>3<-2,-2,8>4<-3,-2,
8>5<-2,-1,4>6<-2,-.5,8>7<0,-1,4>8<-.5,-2,8>9<0,-1,8>10<.5,-1,4>11<.5,-2,8>12<
1,-1,8>13<1,-1,4>14<1.5,-2,8>15<2,1,0>20<-19,1,99>22<-180,-9,999>}#local c=0;
#while(c<20)sphere{S(c).1pigment{rgb(S(c)+(x+y)*3.5)}}#local c=c+.02;#end//JM
