POV-Ray : Newsgroups : povray.beta-test : [doc] language directives quick ref Server Time
10 Apr 2026 21:45:49 EDT (-0400)
  [doc] language directives quick ref (Message 1 to 4 of 4)
Subject: [doc] language directives quick ref
Date: 13 Mar 2002 05:30:33
Message: <6k7u8u05us4bligo3ug6bgu6eqsvnpv643@4ax.com>
POV 3.5 b 12 for Win
(note: some suggestions are connected also with conventional part of SDL
refenrence - it is just simpler to dig on quick reference)
10.1.4.2  Identifier Declaration
  I can't find function() case in possible RVALUE
10.1.4.3  File Input/Output
  Considering discussion about array entries and final "something can be
  declared but not assigned" I suggest to change:
  DATA_IDENTIFIER:
    UNDECLARED_IDENTIFIER | (...)
  to
  DATA_IDENTIFIER:
    UNDECLARED_IDENTIFIER | UNASSIGNED_IDENTIFIER | (...)
  I suggest to add to File Input/Output quick ref section about EOF detecting.
10.1.4.8  Macro
  Describes MACRO_DEFINITION as
    #macro MACRO_IDENTIFIER ( ... ) SCENE #end
  where SCENE is:
    LANGUAGE_DIRECTIVE|CAMERA|LIGHT|OBJECT|ATMOSPHERIC_EFFECT|GLOBAL_SETTINGS
  So how it can return texture or function with macro ? I think good
  replacement could be:
    #macro MACRO_IDENTIFIER ( ... ) SCENE | RVALUE #end
  or as in conventional syntax frame:
    #macro MACRO_IDENTIFIER ( ... ) TOKENS #end
Additional feature request (but probably not a simple task): could it be
possible to replace all identifiers with links to aproprioate quick ref part ?
ABX
Subject: Re: [doc] language directives quick ref
Date: 13 Mar 2002 22:19:22
Message: <3c9016ba@news.povray.org>
The RVALUE item is part of the ARRAY_INITIALIZER and ARRAY_ELEMENT_ASSIGNMENT items.
In testing possible assignments of
RVALUEs to array elements, I could not get a user-defined function item to work.  So I
left it out of the RVALUE list.  Was
this a bug that has been corrected?  If so, I'll simply add USER_FUNCTION to the list
and also correct the Macro's ACTUAL_PARAM
item.  Let me know.
The assignment to a user-defined function is also covered in section 10.1.3.4 with the
USER_FUNCTION_DECLARATION item.
>   DATA_IDENTIFIER:
>   to
>   DATA_IDENTIFIER:
I am not sure what you mean here.  Outside of arrays, I don't think there is such a
thing as an unassigned identifier.  And
even for the arrays, it would be an unassigned element, would it not?  I cannot use
#read to read a value directly into an
array element.  Please correct me with an example!
This appears to be something that might go against my statement, "It does not provide
definitions for the numerous keywords nor
explain their usage!"  Perhaps a better item would be a "Jump to SDL" link that sends
us to section 6.2.3 ?
> 10.1.4.8  Macro
>   where SCENE is:
I am avoiding TOKENS because that includes punctuation.  Can we have a macro that
returns just a plus sign or a parenthesis?
I have replaced SCENE with MACRO_ITEM... and added the following definition:
MACRO_ITEM:
    SCENE  |  RVALUE
Now that I look at this though, is it possible to have more than one RVALUE?  If not,
we'll have to come up with something
else.
Well, of course, I cannot speak for the distributed documentation.  For the web page I
decided to not link anything that could
be found in the table of contents at the top of the page.  While creating this
reference, I agonized for a time over the
possibility of including an ITEM_DECLARATION with each "ITEM" that could be declared
(OBJECT_IDENTIFER, COLOR_MAP_IDENTIFIER,
etc.).  The original documentation does this.  Instead I assumed that the reader could
find Identifier Declaration in the
contents for any identifier and figure it out.
Robert Chaffe
http://www.donovansweb.com/~chaffe/
Date: 14 Mar 2002 06:18:58
Message: <19019u4knn4969utlkse2bjera0svfemjg@4ax.com>
On Wed, 13 Mar 2002 21:20:19 -0600, "Robert Chaffe"
try: #local A=array[1]{function{x+y+z}}
works fine for me with beta 12
>  So I left it out of the RVALUE list.  Was
probably
Try this twice - first time as is, second time with uncommented line with
array redeclaration:
  #local A=array[2]{1,2};
  #fopen File "test.txt" write
  #write(File,A[1])
  #fclose File
  //#local A=array[2];#local A[0]=1;
  #fopen File "test.txt" read
  #read(File,A[1])
  #fclose File
At first run script reads into declared (becouse symbol A[1] is known and has
memory reference) and assigned (with value 2) entry. At second run (with
uncommented line) script reads into declared but not assigned entry. Now try
this the same way:
  #local A=array[1]{1};
  #write(File,A[0])
  #fclose File
  // #local A=array[1];
  #read(File,A[0])
  #fclose File
In second run (with uncommented line) it returns parse error becouse A[0] is
not declared. It is not declared becouse it wasn't specified with first
assigment which could define type of entries in array.
> "It does not provide definitions for the numerous keywords nor explain their usage!"
Since there are parts of possible file operations: open, read, write, close I
just found EOF detecting as another possible IO-operation. It could be
explanation of usage if it would be used in #ifdef section. But using it in
File Input/Output section is more like using #declare assigment explanation in
User Defined Functions section.
> > 10.1.4.8  Macro
Of course:
  #macro Plus() + #end
  #macro Open_Parenthesis() ( #end
  #macro Close_Parenthesis() ) #end
  #local C=
    Open_Parenthesis()
       2 * Open_Parenthesis() version Plus() pi Close_Parenthesis() Plus() 1
    Close_Parenthesis() ^ pi;
  #warning str(C,0,-1)
afaik not
ABX
Date: 14 Mar 2002 21:13:50
Message: <3c9158de@news.povray.org>
I added USER_FUNCTION to the RVALUE list.  I removed USER_FUNCTION from the
ACTUAL_PARAM item for a macro (section 10.1.4.8)
since it would now be redundant.
>  [snip]
> this the same way:
>  [snip]
I added ARRAY_REFERENCE to the DATA_IDENTIFIER list.  I also added an item note: "May
read a value into an array reference if
the array element's type has already been established."
usage!"
I added an item note:  "Use defined(FILE_HANDLE_IDENTIFIER) to detect end-of-file
after a read."
> > > 10.1.4.8  Macro
parenthesis?
> Of course:
>  [snip]
I replaced MACRO_ITEM with TOKENS and removed the MACRO_ITEM definition.
Robert Chaffe
