POV-Ray : Newsgroups : povray.beta-test : Difference in wrapped vs raw wood in normal{} Server Time
24 Jun 2026 03:49:10 EDT (-0400)
  Difference in wrapped vs raw wood in normal{} (Message 1 to 6 of 6)
Subject: Difference in wrapped vs raw wood in normal{}
Date: 27 Nov 2024 08:00:55
Message: <67471807@news.povray.org>
In writing this post to the v4.0 forum:
http://news.povray.org/povray.pov4.discussion.general/thread/%3C67471126%241%40news.povray.org%3E/
I discovered weird differences in results between using the wood pattern
directly within a normal and wrapping it in pigment_pattern{} or
function{pattern{}}.
In other words, the following:
normal {
   wood
   rotate*90
Results in behavior different than either:
#declare Fn = function {
   pattern {
     wood
     rotate x*90
normal { Fn(x,y,z) }
     or
normal {
   pigment_pattern {
     wood
     color_map {
       [0 rgb 0]
       [1 rgb 1]
     rotate x*90
In the attached image the left column is using one of the wood {}
wrapped forms. The middle column uses 'wood' directly in the normal{}.
The right column showing a 4x multiple of differences which should not
exist. No AA used. The image results are from v3.8 beta 2, but this
issue exists in the yuqk fork too.
The top row is just the wood base normal. The bottom row showing the
wood based normal used in a slope map{}.
Real life keeping me busy over the next few days, but I plan to dig into
this when I get some time. My guess at the moment is it is some
numerical difference near values of 0 and/or 1, but we'll see.
Bill P.
Download 'wrappedvsrawwoodinnormal.jpg' (145 KB)
Preview of image 'wrappedvsrawwoodinnormal.jpg'
Subject: Re: Difference in wrapped vs raw wood in normal{}
Date: 27 Nov 2024 14:28:41
Message: <674772e9$1@news.povray.org>
What is going on popped into my head 10 minutes ago. The following does
produce the same result as normal{ wood rotatex*90 } :
         pattern {  // This {} enables value modifiers
             wood
           //rotate x*90
     normal {
         Fn(x,y,z)
         rotate x*90  // Moved the rotation here
Where I had coded this:
             wood
             rotate x*90
     normal {
         Fn(x,y,z)
In the top the rotate happens in normal{} context. With the bottom
encoding it happens in the pre-compiled function{ pattern{} } context.
The normal{} value sampling - in being only a pyramid  of 4 samples - is
asymmetric. It sees the wood pattern's value not-rotated in one case and
rotated in the other and we get different perturbed normal results.
Bill P.
Date: 29 Nov 2024 06:25:00
Message: <web.6749a39149345a6016086ed06830a892@news.povray.org>
>              wood
>            //rotate x*90
>      normal {
>          Fn(x,y,z)
>              wood
>              rotate x*90
>      normal {
>          Fn(x,y,z)
> Bill P.
So... Is there still no chance to create tangent space normal maps macros since
most recent fixes?
Date: 29 Nov 2024 21:13:57
Message: <674a74e5$1@news.povray.org>
> most recent fixes?
Probably not... :-)
I don't know is my actual answer. I have doubts I've changed mapping
capability enough in yuqk to do much new over what POV-Ray can do.
When I have a little more time I'll have to search the web and the
newsgroups for exactly what you mean by "tangent space normal maps macro".
Bill P.
Date: 30 Nov 2024 05:55:00
Message: <web.674aee8249345a609ab1ad886830a892@news.povray.org>
> > most recent fixes?
> Probably not... :-)
> Bill P.
This is the first result and does seem relevant:
https://learnopengl.com/Advanced-Lighting/Normal-Mapping
Crossfingers! Anyway, thanks a lot for ALL the work you are doing, very much
appreciated, please keep having fun !
Date: 30 Nov 2024 06:22:38
Message: <674af57e$1@news.povray.org>
Thank you for the reference!
Bill P.
