POV-Ray : Newsgroups : povray.beta-test : Stream <type>_file=false ini options not working. Server Time
10 Nov 2026 23:04:15 EST (-0500)
  Stream <type>_file=false ini options not working. (Message 1 to 4 of 4)
Subject: Stream <type>_file=false ini options not working.
Date: 1 Mar 2024 09:58:07
Message: <65e1ecff$1@news.povray.org>
It looks like these options have not functioned correctly since at least
v3.7.
I have not yet fixed them the yuqk fork - the fix priority is low.
The options in particular are:
all_file=false
debug_file=false
fatal_file=false
render_file=false
statistic_file=false
Bill P.
Subject: Re: Stream <type>_file=false ini options not working.
Date: 1 Mar 2024 13:32:24
Message: <65e21f38$1@news.povray.org>
> v3.7.
> all_file=false
> debug_file=false
> fatal_file=false
> render_file=false
I think this is more a documentation error remaining than a missing
feature. All this would do is turn OFF output to a file, which already
will only be written if it is specified in the first place ... what does
work is setting this to an empty string.
However, if you wanted to implement "false" it, it should be in
frontend/renderfrontend.cpp method RenderFrontendBase::CreateScene
Find the line
if(ProcessOptions::IsTrue(UCS2toSysString(shd.streamnames[gStreamNumber[i]]).c_str())
== true)
and add a case for IsFalse that sets the
shd.streamnames[gStreamNumber[i]] to an empty string.
Thorsten
Date: 2 Mar 2024 09:39:50
Message: <65e33a36$1@news.povray.org>
> Find the line
== true)
Thank you, Thorsten, for digging.
Unfortunately, your suggestion to try the empty string highlights a
secondary bug. All of the variations below direct the stream to a
defaulted filename of debug.out in my testing (ini forms too).
yuqk debug.pov debug_file=on
yuqk debug.pov debug_file=true
yuqk debug.pov debug_file=yes
yuqk debug.pov debug_file=1
yuqk debug.pov debug_file=""
yuqk debug.pov debug_file=''
The secondary problem is ProcessOptions::IsTrue (and
uProcessOptions::IsFalse) use ProcessOptions::Matches which needs the
following code at the very top
    if ( ((v2[0] == 0) || (v1[0] == 0)) &&
        !((v2[0] == 0) && (v1[0] == 0)))
        return false;
to not, falsely, test 'true' on empty string options. With that
secondary fix in place, the following code is testing out OK for me.
(Ugly code formatting to avoid uglier formatting on posting of code...)
Replace:
     shd.streamnames[gStreamNumber[i]] =
         obj.GetUCS2String(gStreamTypeUtilData[i]);
     if (ProcessOptions::IsTrue(
         ) == true)
         SysToUCS2String(gStreamDefaultFile[i]);
With:
         UCS2toSysString(
         ).c_str()) == true)
     else if (ProcessOptions::IsFalse(
         UCS2toSysString(
         ).c_str()) == true)
         // Do nothing if the string indicates false (or empty).
     else
Bill P.
Date: 2 Mar 2024 11:34:49
Message: <65e35529@news.povray.org>
 >         return false;
Interesting. Then I am not sure this ever worked as documented before in
the first place: The matches-code is a straight port from 3.1 and
according to the header there dates back to April 1994. So you probably
found a 30 year old bug here ...
Thorsten
