POV-Ray : Newsgroups : povray.beta-test : A v3.8 / v4.0 / yuqk vector tuple assignment issue. Server Time
20 Mar 2026 07:49:04 EDT (-0400)
  A v3.8 / v4.0 / yuqk vector tuple assignment issue. (Message 1 to 5 of 5)
Subject: A v3.8 / v4.0 / yuqk vector tuple assignment issue.
Date: 4 Nov 2023 03:04:25
Message: <6545ecf9$1@news.povray.org>
There is a bug specific tuple (batch) ID assignments from vectors.
The detail for which is again being eaten by the spam filter.
Bill P.
Subject: Re: A v3.8 / v4.0 / yuqk vector tuple assignment issue.
Date: 4 Nov 2023 03:07:59
Message: <6545edcf$1@news.povray.org>
> Bill P.
Attempting to attach original post as text file.
Download 'tuplevectorassignmentbug.txt' (2 KB)
Date: 6 Nov 2023 10:04:59
Message: <6549009b$1@news.povray.org>
Attempting again to post about issue again with Chris's spam filter fix
in place.
  I've been working through more tuple (batch) ID assignment test cases.
In the documentation I've been able to turn up for the original tuple
capability, there was this bit related to assigning components of
vectors to individual identifiers:
In addition, a similar syntax extension has been added for easier
assignment of vector components to individual variables:
     #declare < ID1, ID2, ... > = VECTOR_EXPR;
This statement is fully equivalent to:
     #local TEMP = VECTOR_EXPR;
     #declare ID1 = TEMP.x;
     #declare IDY = TEMP.y;
except that the new syntax does not actually define a local variable
named TEMP.  The terminating semicolon is mandatory.
All seems to work except the mandatory semicolon bit is not enforced by
the parser!
This means the following code runs without complaint, but incorrectly.
     #declare <A0,A1,A2> = <3,2,1>; // This works.
     #declare <A0,A1,A2> = <1,2,3>  // This only appears to work
                                    // Meaning no parse error
     #debug concat("A0 = ",str(A0,3,1),"\n")
     #debug concat("A1 = ",str(A1,3,1),"\n")
     #debug concat("A2 = ",str(A2,3,1),"\n")
     #error "Stopping at parse test end\n"
The exposure made worse because in other applications, the tuple ID
assignments treat the trailing semicolon as optional.
Bill P.
Date: 6 Nov 2023 11:29:25
Message: <65491465$1@news.povray.org>
> the parser!
>                                     // Meaning no
parse error
An update. It was apparent once I dug through the code that clipka
intended for the vector form to work like other tuple assignments in not
needing a trailing semicolon, but allowing one.
The vector tuple form is broken in all parsers since mid 2015 in not
working as intended or failing for lack of semicolons.
Try as I might over the past few days, I've not been able to make it
work as intended without breaking the general ability to declare things
nearly anywhere.
A capability which looks to be the primary reason we sometimes need
semicolons. We need to somehow mark the end of all the '#' language
directives where we allow them in the middle of a other parsing.
It's also very much related to how grabbing a single token can sometimes
cause the parser to eat up a bunch of scene code and do nothing with it.
This last is exactly what is happening in the sample code up top. It is
what was happening with this recent bug find too:
https://news.povray.org/povray.beta-test/thread/%3C6533cdad%241%40news.povray.org%3E/
I've take a run or two at forcing the semicolon in this one tuple /
batch assignment type, but so far I'm failing there too. That said, I
think this the more likely outcome at the moment.
Bill P.
Date: 11 Nov 2023 17:30:10
Message: <65500072$1@news.povray.org>
I believe this fixed in the yuqk fork - in that lack of a semicolon is
now flagged as an error. Only took a week... :-(
Bill P.
Details for those interested.
Added an optional parameter in hereViaRValue defaulted false to:
Parse_Unknown_Vector()
called from Parser::Parse_RValue() and set true. Plus to
Parse_Express(expr, &terms, true)
called from Parser::Parse_Declare() and set true.
Plus to a set of expression related functions and calls in
parser_expressions.cpp so the proper indication of the 'right value
parsing' state exists in the function called Parser::Parse_Num_Factor()
where the vector dot access parsing happens near the bottom.
It appears when the dot access methods were coded, the right side
parsing state was never extended down into Parse_Num_Factor(). Further,
necessary checking for semicolons was never created. Such checking needs
to know whether the parser was in a right hand value parsing state.
This despite code being used where the dot access bit sometimes,
necessarily, is triggering the execution of directives coded right in
the middle of other work parsing work(a).
(a) - The triggering by way of a side effect of somewhere down the call
chains grabbing directive tokens while the parser is in a state which
allows the mid stream directives.
What all this means.
In the yuqk fork, the vector form of tuple / batch / list ID assignments
should work. Further, due the additional checking down in the dot access
methods for semicolons, it should be much less likely other non-tuple
form vector type assignments can cause unwanted side effects due the
lack of a semicolon. It would have been complicated SDL code which fell
into the trap previously. If users previously tripped it, and got
confusing results, my bet is they probably simplified their code - and
things began to work.
I offer no equivalent v3.8 parser fixes beyond what can be found in my
code or the description herein. Partly, this because I leaned on some
newer yuqk / v4.0 parser functionality for the fix but, the update is
complicated and I'm not going to try and replicate it in another version
of parser code.
Disclaimer. There are simply too many paths into Parse_Num_Factor() for
me to be 100% sure all situations which could be a problem are fixed. My
test cases are clean... It's better than it was.
