POV-Ray : Newsgroups : povray.beta-test : v3.8 b2. Deprecated feature doesn't work with pseudo dictionaries Server Time
2 Apr 2026 01:49:15 EDT (-0400)
  v3.8 b2. Deprecated feature doesn't work with pseudo dictionaries (Message 2 to 11 of 11)
<<< Previous 1 Messages Goto Initial 10 Messages
Subject: Re: v3.8 b2. Deprecated feature doesn't work with pseudo dictionaries
Date: 22 Oct 2023 15:40:00
Message: <web.65357a8c7b584a00b180e2cc6cde94f1@news.povray.org>
hi,
William F Pokorny <ano### [at] anonymousorg> wrote:
> The #declare / #local, deprecated sub-feature does not function when the
> reference to the identifiers is done via the 'global' and 'local' pseudo
> dictionaries(*).
> (*) As mentioned in an earlier post to beta-test, I don't presently
> recommend any pseudo dictionary use in v3.8 beyond the #macro local.
> testing for optional parameter defaults.
for instance, if I have 'A.pov' and 'A.inc', and the latter '#include's another
file ('filed.inc', in this particular situation), I have taken to writing in
'A.inc' eg:
#ifdef (global.fild_workingDir)
would dropping the 'global' make an actual difference ?
regards, jr.
Date: 23 Oct 2023 09:43:48
Message: <65367894$1@news.povray.org>
Sure. Whether the difference matters depends on - stuff.
(Above a MUCH shorter response than I tried to send a while ago from
thunderbird. A response sitting in my sent folder, but thus far it has
not shown up elsewhere? I this doesn't work, I'll ping you via email
directly)
Bill P.
Date: 23 Oct 2023 09:59:00
Message: <65367c24$1@news.povray.org>
> directly)
> Bill P.
That showed up and I tried again to send my long response. It again is
in my sent folder, but otherwise again went poof... :-(
Suppose beyond my thinking while writing it, my ramblings don't rate
much for general value in any case.
I'm going to work on other stuff for a while. :-)
Bill P.
Date: 24 Oct 2023 00:25:44
Message: <65374748@news.povray.org>
On 24/10/2023 00:59, William F Pokorny wrote:
> That showed up and I tried again to send my long response. It again is in my sent
The spam filter ate it (and the previous). I'll try to work out what's triggering it
and either remove that factor or find a way to exempt your posts.
-- Chris
Date: 24 Oct 2023 07:03:28
Message: <6537a480$1@news.povray.org>
> triggering it and either remove that factor or find a way to exempt your
> posts.
> -- Chris
Thank you Chris.
Bill P.
Date: 25 Oct 2023 08:53:20
Message: <65390fc0$1@news.povray.org>
> posts.
> -- Chris
I had the thought maybe my glitching head had dropped a 'bad word' into
my rejected post. I carefully read what I'd sent again, but it all
looked innocuous.
Made some coffee, took a few sips, and I thought to search on my
playpen's fork name. Dang, a gazillion adult sites pop up. When I picked
that name I saw only a few unimportant collisions on searching the web.
Well _____(a). I guess, moving to another fork name is now at the top of
my to do list no matter the reason the spam filter tripped. What a pain.
Something obscure, z_4_  ?
Except, jr, wouldn't like having to use the shift key...
Bill P.
(a) - That was a bad word.
Date: 25 Oct 2023 09:30:28
Message: <810899683.719933105.733153.deletethis-newsadmin2-deletethistoo.povray.org@news.povray.org>
Don’t worry about renaming it yet, I need to run it through the spam filter
manually and find what specifically is tripping it up. Will do that today.
Date: 28 Oct 2023 07:04:18
Message: <653ceab2@news.povray.org>
Chris,
FYI. I've started the work to rename the fork. I want to get away from
from the adult site name in any case.
Once done, I'll try a post to povray.test of the original text, except
with my new fork name. If it still gets rejected, I can find the issue
myself with repeated posts to p.test. You can take this work item off
your plate - except for any eventual spam filter update, should one
still be needed.
Bill P.
Date: 29 Oct 2023 01:04:33
Message: <653de7e1$1@news.povray.org>
> Chris,
> FYI. I've started the work to rename the fork. I want to get away from from the
> Once done, I'll try a post to povray.test of the original text, except with my new
fork name. If it still gets rejected, I can find the issue myself with repeated posts
to p.test. You can take this work item off your plate - except for any eventual spam
filter update, should one still be needed.
ok. sorry didn't get to fix it, I've been clobbered with a particularly nasty variant
of the flu going around Australia right now. normally only takes me a few days to get
over a flu, approaching 10 days now.
Date: 30 Oct 2023 14:33:12
Message: <653ff6e8$1@news.povray.org>
> nasty variant of the flu going around Australia right now. normally only
> takes me a few days to get over a flu, approaching 10 days now.
I hope you're feeling better.
It was not my older fork name and I had not much luck in isolating the
cause for the spam rejection.
It seems to be some longer span 'rejection rule match'.
See the rejected posts to povray.test with the Fourteenth (and
Fifteenth) runs at the spam filter for the smallest posts I managed
still getting rejected. Both about half the size of the original.
Get well. No rush.
Bill P.
