POV-Ray : Newsgroups : povray.beta-test : v3.8 b2. Exposure with number_of_waves parse vs render. Server Time
12 Nov 2026 19:18:45 EST (-0500)
  v3.8 b2. Exposure with number_of_waves parse vs render. (Message 1 to 1 of 1)
Subject: v3.8 b2. Exposure with number_of_waves parse vs render.
Date: 17 Mar 2023 11:41:02
Message: <64148a0e$1@news.povray.org>
I recently resumed a look at the ripples and waves patterns - which
exist for both normal and pattern value map blocks.
If you never use other than the default of 10 waves, you can stop reading.
Be aware, the internal initialization of vectors and frequency /
amplitude values happens when each worker thread is initialized. So, the
parse thread gets initialized, before, it has a chance to parse any
'global_settings { number_of_waves <n> }' settings or change-settings
during parsing.
In other words we always get 10 waves in the parsing thread and we'll
only get the last number_of_waves setting in the post-parse threads for
photons / radiosity / render.
So what, you shout!
You might be right. This state of thing might come to nothing - except
when you do something in the parse phase like place objects on a surface
perturbed by the ripples and/or waves pattern. Later, when the render of
that surface happens, it isn't the same surface as what existed during
parsing.
Bill P.
Aside: The other unfortunate bit I'm taking a swing at fixing is that we
always get the same vectors and values. It's as if we are working with a
long fixed list and only get to pick the first <n> sets(a). Changing the
number could change all <n> values, but it doesn't today. What we really
want are truly independent patterns where we can specify more of what we
want for each of the uses. We'll see.
(a) - The reason for a fixed list might be how 'waves' is implemented.
There isn't a hard clamp on the upper range of values, but rather a
heuristic function. Admittedly, one which might well be as good as an
optimal one for any reasonable number of waves(b) given the known fixed
stream of values!
(b) - There is no check on the upper value today while parsing, which
itself, might result in crashes, bangs and booms - or cursing while a
render takes forever and 12 years. :-) (Effective limit is MAX_INT)
