POV-Ray : Newsgroups : povray.beta-test : v3.8b2. height_field input values at 0.0 not clean. Server Time
2 Apr 2026 03:29:41 EDT (-0400)
  v3.8b2. height_field input values at 0.0 not clean. (Message 4 to 13 of 23)
<<< Previous 3 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: v3.8b2. height_field input values at 0.0 not clean.
Date: 16 Feb 2023 19:00:00
Message: <web.63eec2c21428d28b9b4924336e066e29@news.povray.org>
"Kenneth" <kdw### [at] gmailcom> wrote:
> *If* that is the case, then the select() result can have only two states or
> outcomes-- true or false (or 1 and zero). Which would then pick either argument
> B or C, but never D(??) So, I am wondering if your f-boom macro will ever
> actually be chosen by this select() set-up.
Hmm. I think I muddied my question and my logic, sorry. I kind of mixed up what
happens in a 4-argument 'select' use.
But it would seem that only two of the three B-C-D select() results could be
chosen by your function, but not all three.
Date: 16 Feb 2023 20:00:00
Message: <web.63eed0b51428d28b1f9dae3025979125@news.povray.org>
> > #include "functions.inc"
> > #declare FnChkVals = function (x) {
> >      select(((x<0.0) | (x>1.0)),
> >          0,
> >          0,
> >          f_boom(x,2,3,4,5,6)
Kenneth, I use select all the time.
This is how it works:
select (N, -1, 0, 1)
When your comparison function gets evaluated, it returns a Boolean state (in
POV-Ray it's a 0 or a 1).
So what he's doing, is checking if x is less than 0 or greater than 1.
If it is, then the Boolean result is true, which in POV-Ray is 1.
If it's not, then the result is false, or zero.
The negative option in the select statement never gets used - it's just there to
force the select function to have a zero option that's separate from the 1
option, since a 3-term select statement is divided into 2 results:  negative or
>= 0.
I hope that helps.
Date: 17 Feb 2023 04:51:17
Message: <63ef4e15$1@news.povray.org>
Bill W (BE) explained well.
However, I'm going to re-state things because what showed up where I
have ???? characters above looks different on the web than what I see in
Thunderbird(a).
There are two forms of select(). The is a four term/argument version and
a three term version. The four term allows 'actions' for negative, zero
and positive input values. The three term one allows actions for
negative and (zero or positive) values.
I used the 4 term because I think it reads a little cleaner when setting
up a boolean test in the first term which can only return a zero or one
- the negative action is never used as Bill W said.
Aside: You can use the 3 term select depending upon a boolean result in
the first term test by doing something like:
select(1-(2*((x<0.0) | (x>1.0))), 0, 1)
I think this form less clear and, FWIW, it's slower than the four term
version.
Bill P.
(a) The leading '>' character got picked up as being an indication of
text from a previous post and is displaying as a vertical bar '|' in
Thunderbird.
Date: 17 Feb 2023 05:11:09
Message: <63ef52bd$1@news.povray.org>
On 2/16/23 18:45, Kenneth wrote:
> Yes. Functions as used in height_fields never see called x,y values
> outside the [0-1] range.
Perhaps worth saying a little more than the above. Whether creating a
height_field or internal image_map from a function in POV-Ray, any
'function return' values outside the [0-1] get 'wrapped' to a ramp wave
as is the default with the majority of inbuilt patterns.
So, function return values of:
-0.1 --> 0.9
-0.5 --> 0.5
-0.9 --> 0.1.
1.1 --> 0.1
1.5 --> 0.5
1.9 --> 0.9
In other words, there is a jump or discontinuity when returning values
go negative or larger than 1. Further, there is no ability to to invoke
wave(a) modifiers as is true with the pattern mechanism.
Function based image_maps and height_fields all end up in a [0-1]
vertical/value range - even if your function itself returns values
outside that range.
Bill P.
(a) - The povr fork offers some wave modification capability via new
inbuilt functions like f_sine_wave().
Date: 17 Feb 2023 14:10:00
Message: <web.63efce3b1428d28b9b4924336e066e29@news.povray.org>
> Thunderbird(a).
No problem at my end; I see the correct syntax in the web portal.
Sorry for my longer-than-usual-delay in responding; I had to think hard about
this 'negative option being ignored' thing, and the difference between a 3-part
vs. 4-part select(). I was still thinking about it when I feel asleep last
night! William P's function construct makes better sense to me now; I finally
had the 'flashing insight'.
docs for the 4-part select:
When used with four parameters, if A < 0 it will return B. If A = 0 it will
return C. Else it will return D (A > 0).
I had to work out my own rather pedantic 'truth table' of sorts, as I see it --
hopefully corrected this time--
Given  ((x<0.0) | (x>1.0))  as the first argument 'A':
The boolean results in parentheses are only ever 0 or 1 (true or false).
if x is indeed less than 0.0 OR greater than 1.0, that produces boolean TRUE (or
1) in the parentheses. Compared against select's 'zero by definition' for A,  1
is 'greater than zero'.  So according to the rules, the outcome of select() will
be argument D-- the f_boom macro. Effectively, it doesn't matter if x exceeds
either limit; the result will be TRUE in either case.
If x is exactly 0.0  *or inside the given range*, the boolean operation in
parentheses produces FALSE (or 0). But, for select's argument A
comparison, 'zero equals zero' -- and argument C is chosen, which is 0.0 in
William P's code and 0.3 in mine.
So far, argument B is never chosen; C and D take care of every possible outcome
of    ((x<0.0) | (x>1.0))
HOWEVER, I see now that a simpler 3-part select() would not work when using
argument A as written-- because of the 3-part rules: Argument B is only chosen
when argument A is *less than* 0, which never occurs with  ((x<0.0) | (x>1.0))
Date: 17 Feb 2023 14:45:00
Message: <web.63efd8c11428d28b9b4924336e066e29@news.povray.org>
The boolean results in parentheses are only ever 0 or 1 (false or true).
Oops.  ;-)
Date: 17 Feb 2023 20:50:00
Message: <web.63f02e8f1428d28bc076587389db30a9@news.povray.org>
I agree..
How about just this:
select(
    -((x < 0.0) | (1.0 < x)),
    0,
    1
- or this:
select(
    -((0.0 <= x) & (x <= 1.0)),
    1,
    0
Tor Olav
http://subcube.com
https://github.com/t-o-k
Date: 18 Feb 2023 05:40:25
Message: <63f0ab19$1@news.povray.org>
> select(
>      0,
>      1
> - or this:
> select(
>      1,
>      0
Very likely OK in practice, and cleaner in form than my three term select.
What spooks me some is that -0 and +0 are real things in the IEEE
floating point standard and as supported by C++. If a C++ coder has
thought to test for -0 < 0, they can.
Bill P.
Date: 18 Feb 2023 08:35:00
Message: <web.63f0d3a51428d28b1f9dae3025979125@news.povray.org>
Which raises the question about how the IEEE 754 gets implemented in POV-Ray's
source code, and if a user can test for -0 through SDL.
I actually just watched:
https://www.youtube.com/watch?v=p8u_k2LIZyo
yesterday (it was in the sidebar when watching yesbird's animation), and they
went over some interesting points, and was also wondering if we could implement
something like this in POV-Ray SDL, and source, and if you'd find it useful or
are already using it in povr.
- BW
Date: 18 Feb 2023 12:49:43
Message: <63f10fb7$1@news.povray.org>
So tempted to answer I don't know(a)... ;-)
For the floating point standard we mostly get what the C++ compilers
give us depending upon options used while compiling. Excepting where in
the POV-Ray source there might be hard coded behavior which is not
strictly compliant or in days gone by was intended to handle things is
some more compliant manner(b).
As for testing for -0 via SDL, I cannot think of any direct method...
On my development compiles using g++ 11.3 and the -ffast_math flag, I
can code:
#declare negZero = -0.0;
#declare posZero = +0.0;
#declare hmmZero = 0.0/-1.0;
#debug concat("-0.0 shows up as : ",str(-0.0,0,-1)," \n")
#debug concat("+0.0 shows up as : ",str(+0.0,0,-1)," \n")
#debug concat("Var negZero shows up as : ",str(negZero,0,-1)," \n")
#debug concat("Var posZero shows up as : ",str(posZero,0,-1)," \n")
#debug concat("Var hmmZero shows up as : ",str(hmmZero,0,-1)," \n")
#error "\nStopping at end of parsing\n"
and see as a result:
-0.0 shows up as : -0.000000
+0.0 shows up as : 0.000000
Var negZero shows up as : -0.000000
Var posZero shows up as : 0.000000
Var hmmZero shows up as : -0.000000
So maybe build up strings and do a string compare?
Aside: The C++ value comparison operators mirrored in SDL will - by
default - ignore the sign of zero.
> Fast Inverse Square Root — A Quake III Algorithm
Cool old stuff!
As for fast, clever algorithms... I've tried some tricks in povr and
looked over quite a few, though not the particular one in the video.
Most come with somewhat noisy behavior compared to standards compliant
code. The noise is difficult to swallow given the end benefit(c) -
floor() and ceil() fast equivalents, for example.
Bill P.
(a) I don't know it all - about anything. Where I do know a little,
there's almost never a simple, complete answer.
(b) The radiosity code to this day has some complicated configurations
related to the floating point math, for example. Unsure what all of this
used or needed these days.
(c) The povr fork, while coding up new functions, did implement single
and floating point flavors / options for many functions. Anywhere the
single floating point code was significantly faster on my i3 hardware -
at the expense of accuracy. Often single float accuracy in functions is
OK depending on - stuff.
Measuring and tuning for performance is REALLY difficult these days
given the hardware realities. For core functionality, the tuning job is
best left to the compiler folks as a near hard rule.
