POV-Ray : Newsgroups : povray.beta-test : `datetime(now)` issue - suggestions for a solution Server Time
25 Oct 2025 05:19:55 EDT (-0400)
  `datetime(now)` issue - suggestions for a solution (Message 11 to 16 of 16)
Subject: Re: `datetime(now)` issue - suggestions for a solution
Date: 11 Aug 2021 08:57:06
Message: <6113c922$1@news.povray.org>
On 8/8/21 6:54 PM, clipka wrote:
> We have established that the `datetime(now)` combo is both currently
> broken (on some systems), and has some shortcomings in its design (on
> all systems, both broken and otherwise).
> I think the key issues in finding any satisfactory solution are the
> following:
Suppose I'd lean toward (C.2) with (A.1) for what you've proposed.
FWIW.
In June I worked some on datetime() to support an internal always local
clock now, but as importantly to make work the %z and %Z formatting
options whether the fractional days were coming from now or being
generated on the fly. The last bit, I failed initially to recall on
mentioning the trailing 'Z' with a non utc time result.
Beyond the initial changes, I had plans for a new f_clock() internal
function. Admittedly, my aim was in part to insulate povr from whatever
'now' was doing, but there were additional reasons. Due your post, I've
worked up an initial version of f_clock() much earlier than planned to
test how crazy my plans were and to help clarify my thoughts.
In your preamble, you didn't mention 'now' being used as an SDL timing
mechanism. It's something people do today and it carries risk with
respect to any particular timing result. The reasons is we are using the
system_clock for 'now' which can be updated at any time moving forward
or backward - synchronization with time servers, etc.
We don't warn against timing use of 'now' in the documentation as far as
I know. Perhaps we should?
In povr's f_clock() the up front returned time comes from steady_clock
instead - which on my Ubuntu 20.04 machine appears to be a monotonic
clock since the last reboot/boot.
Suppose the following povr SDL:
#declare Fn_TimePt00 = function (sec_in_day) { now*sec_in_day }
#declare TimePt00 = f_clock(0,0,0);
#debug concat("f_clock(0,0,0) ",str(f_clock(0,0,0),9,9),"\n")
#for (I,0,3000000,1)
     #declare Dummy = 1.0;
#declare Fn_TimePt01 = function (sec_in_day) { now*sec_in_day }
#declare TimePt01 = f_clock(0,0,0);
#debug "\n"
#declare SecInDay = (24*60*60);
#debug concat("Fn_TimePt00 ",str(Fn_TimePt00(SecInDay),9,9),"\n")
#debug concat("Fn_TimePt01 ",str(Fn_TimePt01(SecInDay),9,9),"\n")
#debug concat("Fn_TimePt01 - Fn_TimePt00 ",
     str(Fn_TimePt01(SecInDay)-Fn_TimePt00(SecInDay),9,9),"\n")
#debug "\n"
#debug concat("TimePt00 ",str(TimePt00,9,9),"\n")
#debug concat("TimePt01 ",str(TimePt01,9,9),"\n")
#debug concat("TimePt01 - TimePt00 ",
     str(TimePt01-TimePt00,9,9),"\n")
#debug "\n"
#error "Parsing test. Stop early."
The povr branch generates:
f_clock(0,0,0) 234835.462146713
Parsing 17764K tokens
f_clock(0,0,0) 234838.496408219
Fn_TimePt00 681978977.077232242
Fn_TimePt01 681978980.111495137
Fn_TimePt01 - Fn_TimePt00 3.034262896
TimePt00 234835.462139445
TimePt01 234838.496401535
TimePt01 - TimePt00 3.034262090
Of note for POV-Ray v3.8 and onward is that the Fn_TimePt00, Fn_TimePt00
method for capturing time points should work in v3.8 beta 1, but it
doesn't because when 'now' was added, the support for it was not added
to parser_strings.cpp alongside pi, tau, etc. This a stand alone 'now'
issue.
The other current return types from f_clock() are:
1 - Whole seconds to system wall clock since Y2K.
2 - Fractional days to system wall clock since Y2K (The povr 'now').
3 - Difference between machine epoch and y2k epoch in seconds.
4 - Convert local seconds since machine epoch to utc.
The second argument is whether to account for dst, or not, for types 1,2,3.
The third and last argument is the local seconds argument for return
type utc. The method for this turned out uglier than hoped, though it
appears to work.
I don't consider the form of f_clock final - in povr, as often as not,
just trying outs ideas. A type to directly return seconds since machine
epoch might be nice. Maybe other stuff. We'll see.
Putting more of the whole plan/implementation on the table because I see
secondary 'concerns' such as POV-Ray's Y2K epoch not lining up with any
unix like system I've ever used - all have been at Jan 1, 1970. This
makes understanding the values POV-Ray is generating and using harder to
work with.
Unix commands like date have some nice options:
date --date='TZ="America/Los_Angeles" 09:00 next Mon' +"%s"
but we cannot use the results directly in POV-Ray. Hmm, maybe an
explicit unix time to y2k seconds type for f_clock...
I'll end with my view our 'now' is trying to be both a timer and a
time/date input and I'm not sure these are completely compatible. Most
of the time/date stuff which works for dst uses only seconds resolution
as far as I know(1).
Aside:
Supposing datetime fixed to support %z %Z, and 'now' returning always a
no dst utc or local time you can fairly easily adjust the fractional day
value to account for dst of say an hour with:
#declare DSToffset = (1/24);
#debug concat("now + (1/24) ",
datetime(now+DSToffset,"%Y-%m-%d %H:%M:%S %z"),"\n")
datetime(now+DSToffset,"%Y-%m-%d %H:%M:%S %Z"),"\n")
FWIW.
Bill P.
(1) - The C++/Boost (plus time.h etc) date/time options go on forever. I
don't begin to understand them all and it looks like c++20 is aiming to
revamp/extend a lot of it. Coding wise. I tried to stick mostly with c.
Date: 11 Aug 2021 14:07:32
Message: <611411e4$1@news.povray.org>
Am 11.08.2021 um 14:57 schrieb William F Pokorny:
I don't think there's much sense to warn of using `now` in this capacity
in particular.
If people want a rough idea of how long the individual pieces of their
scene take to parse, for example to decide what portions of their scene
to try and optimize, `now` is probably good enough. It's not like system
clocks are typically corrected umpteen times a day, or changed by huge
values.
Also, given that `now` has days as its unit of measure, and the docs
make no promises about its precision other than that it is "seconds or
better", I think that's enough of a warning to not use it for
microseconds precision measurements if anything serious depends on it.
If people want precise performance metrics, anything based on a real
time clock - even `std::chrono::steady_clock` - is a poor choice of tool
anyway. In general, I would guess that the task/thread scheduling jitter
introduces far more noise into the measurements than the occasional
system clock adjustment. CPU time would be a far better candidate for
such things.
Also note that for the purpose of performance metrics, we already
provide measurements of the total parsing time, both real time and CPU time.
If you think we should provide more tools for performance measurements,
I would argue that some `#split_time` directive to print out the current
parser stats would make more sense than some basic building block that
users would have to build additional SDL code around, that in turn would
potentially skew the results, to actually put to use.
But I don't see any dire need for such a feature.
That's what `steady_clock` is for. If it wasn't monotonic, it would
violate the C++ specs.
But being monotonic and steady, it is obviously no good as a building
block for getting the time of day as a string (and conversion to an
absolute date may also be a pain).
> issue.
Then that sounds like a bug to me, or at least an issue.
> work with.
This was a deliberate choice, based on various considerations:
* The value was to be exposed to the user, allowing them to assign it to
other variables, as well as perform arithmetics on it (such as adding a
day or an hour before converting to a date/time string, or computing the
number of minutes the parsing took and inserting that value as text in
the image; or computing a value from scratch to be later represented as
a date/time string).
This inevitably meant that the format would have to be based on a
floating-point representation.
This in turn meant that the maximum possible absolute precision would
not be constant, but vary depending on the distance from whatever "zero
point" we would choose. So it would be advantageous to choose a "zero
point" close to the time we live in.
* The value should have a precision of seconds in the worst case, but
higher precision if possible.
* With POV-Ray being a platform-agnostic project at heart, I did not
want to give preference for any existing platform-specific time
representation format - neither POSIX' native seconds-since-1970
timestamp format, nor Windows' native 100ns-intervals-since-1601 format.
The only format I would have considered would have been a format defined
as part of the C/C++ standard. Had I followed that route, I would have
ended up using 1900 as the basis, as that's the only epoch year that had
been explicitly specified by the official C/C++ standard at the time
(see the `std::tm` structure). The POSIX epoch hasn't made it into the
official C/C++ standard until C++20, and even then only for non-C
features for now.
Also remember that back then (2013 or earlier), POSIX time wasn't nearly
as ubiquitous as it is today.
* I did want a format that would be easy for users to understand, and
* I specificially did want a format that would be easily convertible to
POSIX time.
While the latter would seem to clearly speak in favor of POSIX time
itself, in conjunction with the previous point it actually speaks
AGAINST it; here's why:
POSIX time is often cited as being the number of seconds that have
elapsed since 1970-01-01 00:00 UTC.
That is NOT the case.
As a matter of fact, POSIX time is currently about 30 seconds short of
that value.
Instead, POSIX time is the number of _days_ that have elapsed since that
point in time, plus the number of seconds that have elapsed since 00:00
UTC of the current (UTC) day.
(Modulo one or two other minor quirks.)
The difference being that this method does not include leap seconds.
By specifying the format of `now` to give a number of days, rather than
seconds, we're avoiding this subtle difference between what peopole
_think_ POSIX time is, and what it _actually_ is.
(As a minor snag, on days with leap seconds we're actually off by up to
1 second in the value reported, but those days are rare.)
Now with using days instead of seconds for the `now` format, some math
would be required to convert to or from POSIX time anyway; so
introducing a constant offset in addition to the seconds-per-day factor
was anything but a big deal.
Year 2000 made for a far nicer epoch than 1970, or 1961, or even 1900.
And it was closer to "home", meaning we'd have more headroom in terms of
precision for longer time in the future.
(Year 2000 also had the benefit that UTC was already defined in its
current form then. In 1970 it wasn't, so the POSIX time value 0 is
somewhat ambiguous. Not that it matters, as current dates are still
well-defined.)
* Speaking of conversion, If it would turn out that users wanted to
convert to or from POSIX time frequently, enough so that it would
warrant support from our side, the format choisen would have made it
trivial to provide an official include file to define a function or
macro to convert between the two formats. And other then-competing
formats besides.
What's wrong with a simple conversion function?
Why put all the burden on the building block that has the primary job of
getting the current date and time in _some_ format?
That's a difficult enough job as it is. Leave conversion stuff to
separate dedicated functions. It's also a difficult enough job.
There is _no_ reason whatsoever to mix them. Just as there is _no_
reason whatsoever to cram `now` and `datetime` in a single monolithic
function, as the original design would have had it.
> Aside:
Yeah, no.
I'm already working on a solution that is far simpler for the user.
Yeah, it makes for fun reading. Especially the parts where you go,
"yeah, you got THIS functionality here, and THAT functionality there,
but all of this doesn't give me THAT THING I REALLY WANT, which should
be far more trivial to implement than THIS and THAT?! And probably just
as common a use case."
Case in point:
There are two functions to convert `std::time_t` to a `std::tm`
structure: One giving you the UTC representation, the other giving you
the local time representation.
There is also a function to convert a `std::tm` in local time
representation to `time_t`.
But where is the **** function that will allow me to populate a
`std::tm` with a UTC representation and convert *THAT* to `time_t`? That
would have to be even easier to implement!
So how else do I get a `time_t` representation of 2000-01-01 00:00 UTC?!
And no, just casting 30 years' worth of seconds to `time_t` is NOT the
proper way to do it folks, because `time_t` is NOT guaranteed to use
POSIX representation. Not even in C++20.
I've now decided that the cleanest way of doing it (in pure C++11
without boost anyway) may be to convert 2000-01-01 00:00 local time to
`time_t`, convert that into UTC, convert that back again to `time_t`
pretending it to be local time, compute the difference to the first
`time_t` obtained, and subtract the result from that first `time_t`.
Behold - 2000-01-01 00:00 UTC as `time_t`. Easy as pi. Or half a tau.
Anyway, irrational. Transcendental even.
Date: 12 Aug 2021 07:59:53
Message: <61150d39@news.povray.org>
> issue.
I think you mean `parser_functions.cpp`?
There's a point to be made in keeping it that way: If we allow `now` in
a function, what value should it evaluate to? The point of time when the
function is parsed and compiled, or the one when it is invoked?
Since the answer to both alternatives is probably "yes" (depending on
the use case), allowing it at all in functions _will_ cause confusion.
For e.g. `pi` and `tau`, by contrast, the answer is easy: "Who cares,
it's the same either way."
Also, if you design a function to return current date and time encoded
in a different time format (say, POSIX timestamp), it's easy to just add
another parameter, and pass `now` when invoking that function. (*)
And while a function that evaluates to a different value upon each
invocation during render _may_ sound like a fun idea, I'm quite sure its
applicability is pretty much limited to being a novelty.
(*Speaking of extra parameters: Passing the number of seconds in a day
as a _parameter_...??!)
Date: 12 Aug 2021 08:16:27
Message: <6115111b$1@news.povray.org>
> such things.
> time.
First, thanks for the detailed response.
I remain of the opinion POV-Ray would be better positioned with two
'now's with a 'now_for_datetime' and a 'now_for_timing'.
A now_for_datetime can be sloppy to the order most concerns we've
pointed out are OK. It could always use the local machine's epoch and
local setting - aligning with other local tools in the machine/OS
environment. Something easier for users to use date time wise.
As to timing things inside the parser. My initial reaction was similar
to yours. The idea rattled around a while inside the cavity behind my
eyes, and, I started to think that certain sorts of timing
characterizations are likely simpler/better-done within the parser.
The parser, in being single threaded, is at some advantage timing wise
for using only a one thread.
Something which gets asked every now and again, is whether POV-Ray could
provide some idea as to the relative expense of certain features over
others.
Instead of timing some block of user SDL code, imagine instead a parser
only job which first characterizes the cost of an empty loop and - to
the degree it can - other "wrapper" costs. We then start inserting
things to characterize in that loop/wrapper. Single patterns in turn as
called via functions. Functions themselves one at a time. Or trace()
operations against base shapes/surfaces one at a time. Or particular
parser functions one a time. Or whatever else. In many respects the
parser can more easy isolate particular functionality than can be
accomplished via other methods.
Imagine a large, long running, parser characterization job for all the
'things' for which we want to track relative performance. The
information from which we, perhaps, stick in a big table via jr's new
macro and publish. Regular timing results useful to users and developers.
This the sort of parser timing application which I believe requires a
more stable and dedicated 'now_for_timing'. But, yep, it's just another
idea at this point - except for now having povr's timer specific
f_clock() feature in hand.
Bill P.
Date: 12 Aug 2021 08:25:54
Message: <61151352$1@news.povray.org>
>> Fn_TimePt00 method for capturing time points should work in v3.8 beta
>> 1, but it doesn't because when 'now' was added, the support for it was
>> not added to parser_strings.cpp alongside pi, tau, etc. This a stand
>> alone 'now' issue.
I did, sorry.
As for what you say below... We're not going to agree. Plus, I need to
run to other stuff for the day.
The token 'now' is what it is when the parse sees it. It's no different
than 'pi' in that regard. Why create inconsistent behavior for users?
Date: 12 Aug 2021 13:38:17
Message: <61155c89@news.povray.org>
Am 12.08.2021 um 14:16 schrieb William F Pokorny:
Um - nope.
Juging from my experience with trying to get the `datetime` and `now`
stuff sorted out, a `now` based on local time will only be a source of
utter confusion.
What would that value even represent?
The only sensible formulation is a "time units since D-Day H-Hour".
Such a D-Day H-Hour would have well-defined DST semantics, either
explicitly by definition or implicitly by user expectation. If D-Day was
2000-01-01, H-Hour was 00:00, and the value was advertised as local
time, then users would expect H-Hour to imply local non-DST in the
northern hemisphere, local DST in the southern hemisphre, or non-DST if
their time zone does not observe DST at all.
So if some user were to compute a point in time of, say, 2000-07-01
00:00 local time - would that be D-Day H-Hour plus exactly 182*24 hours,
or 1 hour more or less due to DST?
That won't fly. Not in the "easier for the user" sort of way, at any rate.
And certainly not in the "easier for the programmer" sort of way either,
that much I can guarantee already.
And that will be utterly useless if the functionality to actually
implement the timing measurements takes considerable time compared to
what we actually want to measure.
For such an endeavor, things need to have the lightest footprint in
parser itself that we can possibly create. Ideally, it would just be a
single (and possibly even very short) token. What that statement would
trigger can be a bit more complex, because it will be compiled, rather
than having to be parsed.
Possibly a job for a dedicated build, that adds a single-character token
just for the purpose, and which isn't functional in release builds. "@"
isn't used anywhere, for example.
This could trigger one or more performance metrics to be logged whenever
"@" is encountered, and the result dumped once parsing (or rendering)
has completed. Maybe a fixed number of characters to follow (say, 4), to
be logged along with it. The resulting dump could then be correlated
with the scene later.
If you want precise results, that would be the road to give you the most
reliable data.
