POV-Ray : Newsgroups : povray.beta-test : POV-Ray v3.8.0-beta 1 - Parse error using "%s" in Win10 Server Time
12 Nov 2026 15:22:02 EST (-0500)
  POV-Ray v3.8.0-beta 1 - Parse error using "%s" in Win10 (Message 11 to 36 of 36)
<<< Previous 10 Messages Goto Initial 36 Messages
Subject: Re: POV-Ray v3.8.0-beta 1 - Parse error using "%s" in Win10
Date: 26 Jul 2021 14:46:34
Message: <60ff030a$1@news.povray.org>
Am 26.07.2021 um 10:34 schrieb jr:
> demo scene TdG mentioned simply needs a (fairly) reliable unique seed for the
> RNG, whenever it's rendered.  made a couple of quick tests with 'now', and am
> thinking of using something like the following to replace the
> 'datetime(now,"%s")', and would appreciate comment(s):
> #declare seed_ = mod((now-int(now))*1e16,1e9);
- Variable name should use uppercase as the first letter. Just saying.
- No need for `mod`, as the seeding via `#declare MyRNG = seed(seed_);`
already effectively does a `mod` operation with a modulus of 2^32 (ca. 4e9).
- Taking the time of day, rather than the running total, is a smart move
I probably wouldn't have thought of, and had me thinking thrice to
figure out whether it even has any advantage. (My preliminary
conclusion: I think it does.)
- Multiplying with 1e16 seems excessive. The value is given in days, and
has a precision of microseconds at best; 8.64e10 would be the ideal
factor in that case. Some systems may even provide timers as slow as one
tick mer millisecond, in which case there would be little point in using
  a factor larger than 8.64e6.
There might be some point in multiplying with a very large number and
then applying `mod`, so that seeds quickly diverge. But that doesn't
work when the multiplying factor is a multiple of the modulus - you'd
ideally want coprime values for that, otherwise you're not shuffling
around information, you're just ditching digits.
This should be easy to accomplish by using any odd (in the literal
sense) multiplier, while ditching your own mod and relying on the
inbuilt mod 2^32 operation. I have a hunch that numbers with a
well-balanced number of binary ones and zeros would be ideal.
The following might do nicely:
     #declare seed_ = (now-int(now))*(1e9+1);
Date: 27 Jul 2021 10:40:25
Message: <61001ad9$1@news.povray.org>
>> for the
>> and am
> 4e9).
When I want coprimes, I often plug in pi in the mix, or use two values
that differ by 1. It could be something like :
#declare Seed_ = mod(now*pi*100000000, 87654321);
Date: 27 Jul 2021 11:15:00
Message: <web.61002228e398ba995e0fed26cde94f1@news.povray.org>
hi,
:-)  I can live with camelcase like 'fooBarBaz' but..
I guess that ("ditching digits") was the idea.  take away the "constant" part,
shift the decimal point by 16 positions (I was looking at 'now' with
'str(now,0,16)', and all positions are in use/change), then "truncate".
it does (and I'll be using that).  output is more like using "%s", ie
incrementing, than with the "diverging" 'mod()'.
AM: yes, 'pi', neat, though not for this project.  thanks.
regards, jr.
Date: 28 Jul 2021 09:16:08
Message: <61015898$1@news.povray.org>
On 7/25/21 4:33 AM, jr wrote:
> hi,
> (thanks, could not post this as I have no MS Windows machine)
>> #declare seed_ = val(datetime(now,"%s"));
> just to confirm, this works on all Linux systems I have access to, incl a Debian
> VM with (oldest) POV-Ray-3.7.0.8.
Just to toss it out there, for as long as I've used datetime(now) as in:
#version 3.8;
#debug concat("v3.8 default -> ",datetime(now),"\n")
I've gotten back:
  v3.8 default -> 2021-07-28 08:11:16Z
because the default format strings has a 'Z' on the end where I suspect
' %Z' was intended. In the povr branch I changed to ' %z' as I think the
time offset more general.
  v3.8 (povr) default -> 2021-07-28 08:15:15 -0400
Bill P.
Date: 28 Jul 2021 11:40:00
Message: <web.610179f4e398ba995e0fed26cde94f1@news.povray.org>
hi,
> #version 3.8;
> I've gotten back:
is this new?  because does not work for me, see below.  also, while on 'povr', I
ran into trouble viewing font glyphs >= chr(256).  (and thanks for raising the
"constant rounding" thing)
regards, jr.
jr@swift:6:wfp$ c### [at] tpov
#version 3.8;
global_settings {assumed_gamma 1}
box {0,1}
#declare s_ = datetime(now);
#debug concat("datetime v3.8 default: '",s_,"'.\n")
jr@swift:7:wfp$ povr t.pov -gr -gs -d -f
Persistence of Vision(tm) Ray Tracer   (see --license)
Copyright 1991-2021 Persistence of Vision Raytracer Pty. Ltd.
Version 3.8.0-x.povr_1984d6ea.unofficial
  (g++ 5.5.0 @ x86_64-slackware-linux-gnu)
This is an unofficial version compiled by: <jr### [at] swiftlan>
Dynamic optimizations:
  CPU detected: Intel,SSE2,AVX,AVX2,FMA3
  Noise generator: avx2fma3-intel (hand-optimized by Intel)
==== [Parsing...] ==========================================================
datetime v3.8 default: '2021-07-28 15:31:42Z'.
==== [Rendering...] ========================================================
POV-Ray finished
Date: 28 Jul 2021 15:34:17
Message: <6101b139@news.povray.org>
On 7/28/21 11:38 AM, jr wrote:
> hi,
Relatively, I guess. Looks like I updated this with a commit on:
Date:   Fri Jun 11 06:18:44 2021 -0400
where I changed datetime() to optionally generate a time accounting for
the local daylight savings time datetime(-100000) after getting myself
tangled up due the generated datetime() string not aligning to my local
-dst adjusted - computer time. Only %z %Z appear to be dst aware with
datetime() otherwise.
So... The Z to ' %z' is an update not yet published.
True my text{} isn't POV-Ray's exactly... Is this something unique to
the povr branch? Off the top of my head, this likely normal unless using
a unicode string specifications.
Aside:
In povr, I'm leaning in a direction of eliminating the text{} object...
Or, at least, not further updating it.
Christoph has been playing with freetype and making the text{} internals
prisms as you know. I'm thinking perhaps all characters/glyphs should
just be include-able objects only where we'd use SDL macros to do all
the placements for a string -- get POV-Ray, at the core, completely out
of the text formatting game and push that sort of thing into SDL.
If you look at the text oriented macros shipped today - like
Circle_Text(), for example, they are actually doing a lot of work to
pull apart text{} strings character by character. When I do isosurface
stuff with text{} strings, I often do the same to get to single
'characters' for better performance. Effectively, pulling text{} objects
apart - or internally doing this - for most work is a painfully
backwards way to approach things in my opinion.
Bill P.
Date: 28 Jul 2021 17:53:02
Message: <6101d1be$1@news.povray.org>
Am 28.07.2021 um 15:16 schrieb William F Pokorny:
> #version 3.8;
> I've gotten back:
The `datetime` function with default values works as documented:
"The default for the STRING parameter format is %Y-%m-%d %H:%M:%SZ"
I'm not the author of that functionality, but according to my
understanding, this is entirely intentional:
Since the information provided by "now" is based on UTC, and the
`strftime` conversion specifiers are time zone agnostic(*), the printed
date and time are also with respect to UTC.
In full compliance with ISO 8601, this is indicated by appending a
literal uppercase `Z` right after the time, which is the official time
zone designator for UTC.
(*)Except for `%Z` or `%z` of course.
Speaking of which: Appending either of those instead of "Z" would
actually give a wrong time, unless you first convert `now` to local time.
Also, per ISO 8601 any time zone designator should be appended to the
time without any intervening space.
Date: 29 Jul 2021 04:40:00
Message: <web.6102686ce398ba995e0fed26cde94f1@news.povray.org>
hi,
not so sure now whether 'povr' or 'povray' cause "a problem", see attached,
'povr' on right.  did a quick check with a Tk text and that confirms the 'povr'
output.
also, Tdg, while testing my macro (thanks, Thomas), found fonts where 'chr(32)'
display as exclamation marks; with both POV-Ray alpha and yr 'povr'.  have not
yet checked to find out why (have to install one or two of the fonts first).
regards, jr.
Download 'tabu_cmp.png' (832 KB)
Preview of image 'tabu_cmp.png'
Date: 29 Jul 2021 06:29:32
Message: <6102830c@news.povray.org>
Am 29.07.2021 um 10:35 schrieb jr:
> output.
povr is based on those rolled-back alpha versions, right? Then color me
unsurprised.
Did I ever, maybe in passing, mention that POV-Ray v3.7's behavior
(which we strive to emulate in v3.8) regarding non-ASCII characters and
fonts is seriously borked?
It is theoretically possible for fonts to provide a non-empty glyph for
the ASCII "space" character. I guess this could go unnoticed in most
programs, as they would typically use operating systems calls to render
text, which in turn could conveivably give special treatment to ASCII
"space" by simply inserting a gap according to the character's width.
I think POV-Ray does not currently do that, and instead treats "space"
like any other character, i.e. it may or may not have a visible glyph.
But I think we're digressing a bit from the original thread...
Date: 29 Jul 2021 07:45:12
Message: <610294c8$1@news.povray.org>
>> #version 3.8;
>> I've gotten back:
>> suspect ' %Z' was intended. In the povr branch I changed to ' %z' as I
>> think the time offset more general.
Supposing the SDL:
    #debug concat("",datetime(now),"\n")
    #debug concat("",datetime(-100000),"\n") // (*)
And the 'date' command on my Ubuntu 20.04 computer returning:
     Thu 29 Jul 2021 07:15:12 AM EDT
The v3.8 branch returns:
     2021-07-29 06:15:12Z  <-- Not current Zulu time... (**)
     1726-03-18 00:00:00Z
The povr branch returns:
     2021-07-29 06:15:13 -0400 <-- Not my current dst time. Offset wrong.
     2021-07-29 07:15:13 -0400 <-- This is correct.
Bill P.
(*) The -100000 days is somewhat arbitrary. Just needs to be earlier
than the unix epoch time to trigger the dst aware mode.
(**) Using %Z would add EDT instead of EST (locally), which is also
correct. Though any given reader must know what the local %Z dst is no
matter where povray/datetime(now) was run or where they live
compared to the person who did run it.
Date: 29 Jul 2021 08:54:35
Message: <6102a50b$1@news.povray.org>
Am 29.07.2021 um 13:45 schrieb William F Pokorny:
> Supposing the SDL:
> Bill P.
Oh hooray.
So, after some digging, it turns out that on Linux machines,
`boost::posix_time::microsec_clock::universal_time()` does specifically
*NOT* do what it was designed to do (at least with the boost version
we're bundling for Windows builds).
I have no idea what you're saying there. What do you need to trigger,
and why?
Date: 29 Jul 2021 17:43:55
Message: <6103211b$1@news.povray.org>
Can someone test whether the fix in this pull request actually solves
the time zone issue?
https://github.com/POV-Ray/povray/pull/433
It should cause `datetime(now)` to print UTC (as opposed to local) time,
while still incrementing significantly faster than once per second.
What I'm doing there is query another timer to get a second opinion.
While that timer is of lower precision (seconds instead of
microseconds), it should reliably give proper UTC. So by using that as a
reference, we can adjust the high-precision timer accordingly by a
multiple of 15 minutes, to give us high-precision UTC.
Date: 30 Jul 2021 10:00:59
Message: <6104061b$1@news.povray.org>
First, what the -1e5 argument to datetime() does in the povr branch is
flip to code inside Parser::Parse_Datetime which uses std::time(nullptr)
over the argument - POV-Ray's 'now' is not relevant.
In my testing your fix gives me the utc time as a hard coded result -
and it's the only datetime string I can get with 'now'.
2021-07-30 12:48:35Z
What about local datetime strings with %z or %Z? The secondary issue I'd
forgotten I hit back in June with the boost code is that:
std::tm t =
boost::posix_time::to_tm(boost::posix_time::from_time_t(timestamp));
doesn't set up the %Z and %z capability. Using both in the string format
option gives me: "2021-07-30 12:48:35".
One can set up those fields by calling strftime() with an argument of:
std::localtime(&t), here getting EDT/-0400, but the date and time string
is still strictly UTC - so it's not particularly useful except maybe to
work backward to the actual time zone date and time in a uncommon /
awkward way and to do that you'd need to know the data/time was UTC no
matter the EDT or -0400 in the returned string.
I guess I see a place for a hard coded 'now' UTC/Z result - and as
accurate an internal time/timer as we can get (is your fix at odds with
timer use?). I don't see it as what most people will want with
datetime(). This why I coded up a more traditional std::time(nullptr) as
an optional mode of datetime()(a).
Aside 1: A reminder that in newer(to be v4.0) code, you moved 'now' off
boost completely. This is in fact is the code povr uses - meaning any
unix/linux 'bug' is in that code too.
Aside 2: The Parse_Datetime() code has too that use of:
setlocale(LC_TIME,"");
the full implications of which made me a little nervous along with the
etting being afterward persistent. So after the strftime() call I added:
setlocale(LC_TIME,"C");
to return the setting to the C++ start up default. In a scan of the code
I didn't pick up any other adjustments to the default locale.
Bill P.
(a) Lying some. Unsure what might happen with the boost variant over the
pure c++11 one for now, but the latter didn't account for daylight
savings adjustments which also makes datetime(), %z and %Z less than
precisely useful.
Date: 30 Jul 2021 14:29:34
Message: <6104450e$1@news.povray.org>
Am 30.07.2021 um 16:00 schrieb William F Pokorny:
> std::tm t =
That would require making `now` a more complicated beast than just a
numeric value, as we can't transport timezone information in that format.
I'm not going there. Not in v3.8, at any rate. Nor am I going the povr
route of hacking something into `datetime` to make it look up the
current time on its own when it gets passed some magic value. Retrieving
the current time is precisely the job of `now`.
As it currently stands, we have no sane way (in v3.8) of achieving all
the following ideal goals:
- Have separate mechanisms to get the current point in time (`now`), and
print a point in time (`datetime`).
- Have a simple "phrase" (combo of the above) to automatically print the
given point in time as UTC, without extra effort, and in a way that it
won't be mistaken for local time.
given point in time as local time, without extra effort, and in a way
that it won't be mistaken for UTC.
I think the following arguments lead to the sanest solution:
- If we have `datetime` default to a string that explicitly prints any
time zone information (as we currently do), then for the default to be
not blatantly wrong, we limit ourselves to one "flavor" of point-in-time
information: Either local ("%z" suffix), or UTC ("Z" suffix). If on the
other hand we omit the time zone entirely from the default, the output
will, for both flavors, be at least not entirely wrong.
This speaks heavily in favor of not including any time zone suffix at
all by default, i.e. dropping the "Z" we're currently appending.
- When users see a date or time, they will usually expect it to indicate
local time. To achieve that, the parameter passed to `datetime()` would
have to be of local time flavor.
This speaks heavily in favor of making `now` return local time, as
opposed to UTC.
I think it can be argued that local time is of far more relevance to
most users than UTC.
Should someone come up with any use case that needs access to the
current time in UTC, then possible workarounds would be:
- for the user to hard-code time zone offset into their scene file;
- for the user to design the scene such that time zone offset can be
passed via `Declare=` INI file setting;
- for us to provide some `timezone` pre-defined variable that evaluates
to the time zone offset in days, ready to be subtracted from `now` to
give UTC, or a `utc()` function that converts from local time to UTC. (I
would lean towards the latter, as the former variable would not be in
the common format of hours, which might give rise to confusion.)
> timer use?).
I'm not sure what you mean by "at odds with timer use".
What I can say is that the fix does not compromise timer precision, if
that's what you mean.
Actually, no - in this case `now` returning local time is not a
Unix/Linux bug (or, more to the point, not a "boost on Unix/Linux bug"),
but rather proper intrinsic behavior of the new implementation I chose.
I realize only now that I accidently implemented the wrong behavior
(judging by the documentation, and intent so far).
It's not the worst of accidents though. I'd like to consider it a Bob
Ross moment.
You and me both, bro.
Without any additional safety net, that would actually be
counter-productive: `setlocale` is not thread-safe; so if we ever run
multiple parser threads in parallel, and they come across the same piece
of code nearly at the same time, your "cleanup" could throw the other
thread off the rails.
The good news is that the above call only sets the time-specific
portions of the locale, which we don't mess with anywhere else. So
ideally we should call `setlocale(LC_TIME,"")` somewhere on program
startup, and never look back.
> precisely useful.
The v4.0 variant doesn't respect daylight savings zone? Yikes!
That'll be another problem to solve then.
Date: 30 Jul 2021 17:38:49
Message: <61047169@news.povray.org>
> opposed to UTC.
> [snip]
The 3.8 documentation say 'now' should return GMT, and on my GNU/Linux
box, it (pre-beta) does return UTC or GMT.  Are you proposing a change
in behavior?
Date: 30 Jul 2021 19:13:23
Message: <61048793$1@news.povray.org>
Am 30.07.2021 um 23:38 schrieb Cousin Ricky:
> in behavior?
I think I do, yes.
The current behavior appears to be quite inconsistent across platforms
and systems and whatnot.
Date: 31 Jul 2021 04:18:55
Message: <6105076f$1@news.povray.org>
>> in behavior?
> I think I do, yes.
Cousin Ricky is onto something; Me screwing up with respect to v3.8 beta
1 results. :-(
I maintain "many" versions of POV-Ray which I run with wrapper scripts
that are careful to strip any $HOME directory or environment variable
customizations - so I'm always testing the native code and set up.
When I grabbed and compiled:
https://github.com/POV-Ray/povray/releases/tag/v3.8.0-beta.1
I created a 'p380b1' wrapper script, but I screwed up and pointed it to
the v3.8 compile directories for the commit from off of which I'm basing
my povr stuff. All my testing of v3.8 beta 1 over the last couple weeks
has been against something closer to the current master branch.
#@%^$^%$&!!! The version is clearly there in the text output, which I
ignore 99.99% of the time...
What this means is the 'now' command I was running as v3.8 beta 1 was
the newer(1) c++11 version. It's that one not returning the utc/gmt/zulu
time making the default 'Z' format suffix wrong.
(1) - Though I've been running primarily that one for years - so I was
seeing what I expected to see as datetime(now) output.
I think, Christoph, an option - if you want to minimize v3.8 release
change - would be to let things go as they are. This would mean a hard
UTC datetime() result without working %z and %Z format options (others?).
I agree with your thinking the behavior of 'now' should updated, but
this could be delayed to v4.0.
Bill P.
Date: 31 Jul 2021 10:03:13
Message: <61055821@news.povray.org>
On 7/28/21 3:16 PM, William F Pokorny wrote:
> #version 3.8;
> I've gotten back:
> ' %Z' was intended.
Z is for Zulu Time Zone, often used in aviation and the
military as another name for UTC +0.
tTh
|                      sphinx of black quartz, judge my vow.        |
Date: 31 Jul 2021 11:10:15
Message: <610567d7$1@news.povray.org>
>> in behavior?
> I think I do, yes.
In my case, #debug concat("v3.8 default -> ",datetime(now),"\n")
returns the current local time with an extraneous «Z» appended at the end.
Running the Windows version under Windows 10.
The default formatting string do end with «%SZ». I think that it should
end with «%S%Z».
Date: 11 Aug 2021 07:13:43
Message: <6113b0e7$1@news.povray.org>
> #version 3.8;
Can you put some estimate on "as long as I've used datetime(now)"?
Further back than 2019?
If so, can you remember whether you already got local time out of the
function back then, or whether it could originally have been UTC after all?
Date: 11 Aug 2021 09:09:21
Message: <6113cc01$1@news.povray.org>
>> #version 3.8;
Guessing 2018 or there about - certainly your new c++11 code over the
boost stuff - but I don't remember the exact timing. We could look at
the commit messages I guess.
Yes, as I said in answer to Cousin_Ricky, I tripped myself up on using
the v3.8 branch point for povr as v3.8 beta 1 due a screw up in my
wrapper script. The latter (now)- with the original boost code does
return utc - but the %z %Z options in datetime don't work. Sticking with
v3.8 beta <n> as is - at least as far as my Ubuntu machine goes - is an
OK option I think.
Other changes to now/datetime could wait for v4.0. But, I'm not sure
what others see for v3.8.
Complete aside... I have a vague recollection of a compile time
environment variable for some compiler which let users select whether
std::time() - the 'c' time - would return utc or local time. But, maybe
it was a fever dream... :-)
Bill P.
Date: 11 Aug 2021 11:10:46
Message: <6113e876@news.povray.org>
Am 11.08.2021 um 15:09 schrieb William F Pokorny:
> OK option I think.
Can you elaborate on the "%z %Z don't work"?
Note that placing `%z` or `%Z` in the string passed to `strftime()`
doesn't magically alter how that function interprets the data it
receives. It just inserts the identifier for whatever timezone the
system has been configured to use, period. It is the responsibility of
the software developer (which in this particular case and current state
of affairs eventually means the scene author) to make sure that the data
passed to `strftime()` is local time when using `%z` or `%Z` (or no
timezone identifier at all, for that matter) and UTC when appending a
literal `Z` to indicate UTC.
There is one additional caveat in that an additional data field needs to
be set up properly in order for `%z` or `%Z` to print the proper
timezone information when DST would be in effect at the point in time
specified. If that is not done, the timezone printed will not properly
adapt to DST.
Since the code was designed for UTC, the DST field was never really
considered, and may be set up completely wrong.
If the "don't work" symptoms you observed can't be explained by either
of the above caveats, then I'd like to learn more about it.
Maybe what you remember was actually a preprocessor macro in some
software package, to let it know what was implemented in the library?
The boost source code hints that an obscure IDE for embedded system
development called Metrowerks CodeWarrior would use local time, rather
than utc, throughout the date/time-related portions of its C library.
Date: 11 Aug 2021 16:37:58
Message: <61143526$1@news.povray.org>
Some. The failures are varied depending upon the format string.
SDL:
   #debug concat("%z ---> <",datetime(now,"%z"),">\n")
   #debug concat("%Z ---> <",datetime(now,"%Z"),">\n")
   // For the lines above
   // 3.7.0.8  - Invalid formatting code in format string, or
   //            resulting string too long.
   // v3.8 b 1 - Invalid formatting code in format string, or
   // ~master  - Invalid formatting code in format string, or
   // povr     - %z ---> <-0400>
   //            %Z ---> <EDT>
   #debug concat("%z ---> <",datetime(now,"%c %z"),">\n")
   #debug concat("%Z ---> <",datetime(now,"%c %Z"),">\n")
   // 3.7.0.8  - %z ---> <Wed 11 Aug 2021 07:58:53 PM  >
   //            %Z ---> <Wed 11 Aug 2021 07:58:53 PM  > (**)
   // v3.8 b 1 - %z ---> <Wed 11 Aug 2021 07:58:53 PM  >
   // ~master  - %z ---> <Wed 11 Aug 2021 03:05:50 PM  > (***)
   //            %Z ---> <Wed 11 Aug 2021 03:05:50 PM  > (***)
   // povr (*) - %z ---> <Wed 11 Aug 2021 03:05:50 PM EDT -0400>
   //            %Z ---> <Wed 11 Aug 2021 03:05:50 PM EDT EDT>
// (*) The time isn't accounting for dst though %z,%Z correct.
// (**) The %c should include a %Z string of its own and does not.
// (***) Above issue and time not the actual utc time.
#error "Parse test. Stop early."
As I believe I mentioned somewhere else, I'm not sure what all doesn't
work with respect to formatting given the boost code being used doesn't
  set up all the fields needed to use the complete set of strftime()
formatting.
Bill P.
Date: 11 Aug 2021 17:55:43
Message: <6114475f@news.povray.org>
Am 11.08.2021 um 22:37 schrieb William F Pokorny:
>    //            %Z ---> <EDT>
Hah!
This one took me a while, and I was on the verge of asserting that
`strftime` must be broken on your machine. Because whatever `strftime`
does, it should NOT be reporting an error when confronted with these
parameters.
The kicker is: It doesn't.
What happens it that - for _some_ reason - `strftime` can't properly
determine the time zone (e.g. because it doesn't know whether DST is in
effect or not).
In that case, it is contractually obliged to replace `%z` or `%Z` with
an empty string.
Which, in this very special case, leads to a completely empty result string.
Which means that `strftime` return a value of 0, because that's what it
does if it doesn't encounter a fatal error: It returns the number of
characters placed in the result string.
Zero.
Which also happens to be the value it is contractually obliged to return
if it runs out of space to write the result string to.
So POV-Ray panics, imagining there to be a serious problem when there is
none.
Should it though?
The C (and by extension C++) standard mandates that `strftime` replace
`%c` with "the locale’s appropriate date and time representation".
That's it, no other specification for it. Whether that is to include any
time zone information is, I would argue, up to "the locale". For the `C`
locale, for instance, the standard specifically mandates that a timezone
specifier is NOT included in the "%c" replacement text.
Also, even if the locale does happen to include a `%Z`, it makes sense
that it also gets replaced by an empty string, just like an explicit `%Z`.
Not at all surprised there.
Should match your local non-DST time.
> formatting.
 From all of my understanding, only the timezone identifier (either
explicitly, or implicitly such as via `%c`) should suffer.
Okay, I guess the takeway lesson here is that as implemented up to (and
including) v3.8.0-beta-1, your system doesn't seem to have enough
information to decide what timezone is applicable, presumably because
the info whether DST is in effect for the date isn't explicitly set, and
your runtime library's `strftime` function does not make any attempt to
figure it our for itself.
Which begs the question, what exactly does povr do differently?
Date: 12 Aug 2021 07:01:22
Message: <6114ff82$1@news.povray.org>
On 8/11/21 5:55 PM, clipka wrote:
> Should it though?
Understanding what you are saying below, my answer is still, yes,
because it is what my locale does if the information is available. In
other words POV-Ray's %c result should match what my 'date' command
returns.
Aside: IIRC, there's a huge text file with all sorts of locale
information in it that gets used to create code for compilers and the
like. I've never tried to find it. I do sort of wonder what it looks like.
Hmmm, just had a thought about that line of code in parser_strings.cpp:
I didn't play with that at all. Wondering at the moment what happens if
we move that call ahead of:
std::tm t =
Could it be we are not getting some fields because at that call we are
effectively running: setlocale(LC_TIME,"C") ?
>> doesn't   set up all the fields needed to use the complete set of
>> strftime() formatting.
The povr code looks like:
         std::time_t tt;
         if (FractionalDays <= -1e5)  // (****)
             tt = std::time(nullptr);
         else
             tt = std::mktime(&t);
         setlocale(LC_TIME,""); // Get the local preferred format
         vlen = strftime(val, PARSE_NOW_VAL_LENGTH, FormatStr,
std::localtime(&tt));
Suppose, if you were to use something like it, you might make use too of
std::gmtime() - depending on settings.
(****) - Yep, my old brain failed too to remember my own trigger for
generating the time_t information immediately. At one point I was
thinking of using any value prior to epoch, but apparently I didn't.
Bill P.
Date: 12 Aug 2021 07:27:59
Message: <611505bf$1@news.povray.org>
Am 12.08.2021 um 13:01 schrieb William F Pokorny:
> std::tm t =
If that were the case, then
     #declare ThrowAway = datetime(now);
     #debug concat(datetime(now),"\n")
should change the behavior, since the first invocation of `datetime`
should switch the time locale to the system default, and we're never
switching it back, so the next invocation of `datetime` should start
with the system default time locale already selected.
But I'd be surprised if that would work. By definition, `std::time_t` is
positively supposed to represent universal time in some way or form, so
converting that to `std::tm` should still result in "yeah, here's your
date information, but as for DST, well, that's not really applicable
here at all because UTC."
I thknk what should really happen is that we should perform the
conversion from `std::time_t` to `std::tm` via `std::gmtime()` when
converting for UTC, and via `std::localtime()` when converting for local
time. I'm quite confident that the latter should set the DST flag as
appropriate. And it will also definitely take care of adjusting for time
zone, so we can use a `now` that's always based on UTC.
The povr code also using `std::localtime()` confirms that this should
indeed actually work.
